07-26-2016, 08:45 AM | #261 |
Quarry Creeper Join Date: Mar 2016 Location: Ohio
| Re: New Incision wheels coming.... |
07-26-2016, 09:09 AM | #262 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
07-26-2016, 10:06 AM | #263 |
Pebble Pounder Join Date: Nov 2012 Location: Louisville
Raptor build perhaps?
07-26-2016, 11:18 AM | #264 |
Moderator Join Date: Jan 2004 Location: chicago
can somebody post a comparable width slw next to the incision hub? it looks like a much smaller (scale) bolt circle as i assume the recessed wheel nut area is the same diameter as an slw. that alone would be a valid selling point. what we would call a unique selling proposition... |
07-26-2016, 07:56 PM | #265 | |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
| Re: New Incision wheels coming.... Quote:
Bolts are now 2-56. Smaller bolt pattern. Smaller diameter and round hub for better scale appearance. Don't have one handy at the moment but can get picks later if no one can provide. | |
07-26-2016, 09:07 PM | #266 |
If I hadn't just recently put mine together and loctite everything...
07-27-2016, 06:33 PM | #267 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
Hub comparison pic. SLW on the right. |
07-27-2016, 07:10 PM | #268 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
I am assuming the Incision hubs will be quite cheap. So any kind of SLW to Incision adapter probably won't be worth it, no?
07-27-2016, 08:26 PM | #269 |
Thanks for sharing Hahns, that new hub doesn't really make me feel too good. 12.9 grade hardware will be a must if I get a set of these.
07-27-2016, 08:28 PM | #270 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
Soooo, why couldn't they have used the SLW drill pattern again? Doesn't look that different from where I'm at. Sent from my SM-N910V using Tapatalk |
07-27-2016, 08:54 PM | #271 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
I don't see why everyone is complaining so much. They bitch about how much SLW wheels cost, so VP makes cheaper wheels... then they bitch about the hardware and size. Can't please anybody.
07-27-2016, 09:03 PM | #272 |
Here they are on my CXT. Probably the easiest wheels for mounting tires that I've used. The width also just where I like it. The offset with the included hubs matches the old TrailReady beadlocks with 475 SLWs perfectly as well. |
07-27-2016, 09:59 PM | #273 |
That truck is pretty cool. What is a CXT? Edit: Nevermind, google'd it. Sent from my SM-N910V using Tapatalk |
07-27-2016, 10:01 PM | #274 | |
RCC Addict Join Date: Jan 2007 Location: Arkansas
IMO the better thing to do for the hubs would have been to ditch the stupid hex and just machine out a slot for the pin and used the SLW pattern. Probably would have been cheaper to machine too. ETA These hubs do look more scale though. | |
07-27-2016, 10:04 PM | #275 | |
Sent from my SM-N910V using Tapatalk | |
07-27-2016, 10:27 PM | #276 | |
Every large company has products under different lines, and they all don't share interchangeable parts. Something has got to give in order to keep you in that product line. | |
07-28-2016, 05:48 AM | #277 |
Smaller diameter hubs and pattern means more scale appearance and more detail in the wheel face. Is it a little inconvenient since many are used to and use the SLW pattern, sure. Is it an issue, no not really. I've been a ring a better looking hub since the birth of the SLW and now we have it. |
07-28-2016, 06:04 AM | #278 | |
You also talk about a more detailed wheel. What details do the Incision wheels have that the VP wheels do not? I'm not seeing any. These hubs should be half the cost of the SLW hubs or else the switch is really a bad idea. | |
07-28-2016, 06:26 AM | #279 |
I'm not saying the currently released wheels have more detail, it simply opens up the options for newer designs later.
07-28-2016, 06:52 AM | #280 |
New Incision wheels coming.... - Similar Threads | ||||
Narrowing Stock XR10 wheels to fit Vanquish Incision Knuckles | The gasman | Tires and Wheels | 8 | 01-13-2014 06:46 PM |
vanquish XR-10 Incision Steering Knuckles and wheels | bikeboy | Axial XR10 | 35 | 03-07-2012 09:51 AM |
VP Incision Steering Knuckles/Stock Wheels | Mysterious | Axial XR10 | 9 | 12-11-2011 05:18 PM |
New 1.9 wheels coming | Gozer | Losi Mini-Rock Crawler | 4 | 10-21-2008 02:59 AM |
