08-14-2016, 12:35 AM | #341 |
Rock Stacker Join Date: Feb 2015 Location: Vancouver, BC, Canada
| Re: New Incision wheels coming....
I am still loving the new Incision Method wheels, zero issues with my Proline Flat Iron XL tires. But I am wondering if anyone else is having an issue with the wheel nut backing out? I am doing all sorts of crawling to speed runs but I to have tighten the nuts after a bit. Happens randomly to some or all tires. I have tried new wheel nuts and still an issue. Don't recall this being a real issue before. I have added some washers tonight to give the nut more to grab onto and will try it out tomorrow. Not blaming the wheels, just can't figure out why the nuts keep backing out. Sent from my SM-G900W8 using Tapatalk |
08-14-2016, 01:54 AM | #342 |
That's normal. Sent from my VS986 using Tapatalk |
08-14-2016, 06:03 AM | #343 | |
Quarry Creeper Join Date: Mar 2015 Location: Castle Rock, Colorado
| Re: New Incision wheels coming.... Quote:
I have been having that issue too. I had it with the stock beadlock wheels that came with the kit as well. I think the fact that my Bomber can go so much faster than my other trucks is the cause. I bought some Traxxas serrated wheel nuts. I use them and put a little blue thread lock on the axle threads. Seems to have solved the problem. Sent from my iPhone using Tapatalk | |
08-14-2016, 08:46 AM | #344 |
| Re: New Incision wheels coming.... |
08-14-2016, 09:14 AM | #345 |
Hmm, I haven't noticed any play with my stock axial 12mm hex's with the Incision hubs yet but did see one of bearings might need to be replaced as it does seem to move around in the knuckle. Edit: ok, so took off one wheel and see there is a tiny bit of play with the Hex in the hub. I didn't notice that before. Still like the wheels a lot, will try the blue thread loc and see if that helps. Sent from my SM-T320 using Tapatalk Last edited by woody131; 08-14-2016 at 09:40 AM. |
08-14-2016, 10:13 AM | #346 | |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
08-14-2016, 09:50 PM | #347 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
Can someone who has an unmounted Incision 2.2 Method wheel please weight it for me, with hubs. Thanxs very much.
08-15-2016, 02:28 PM | #348 | |
Yes. Hmmm. Good luck and let us know how it goes. | |
08-15-2016, 04:00 PM | #349 | |
On these wheels the nut doesn't touch the wheel, just the hub, so the serrated nut doesn't harm the wheel. Same as with an SLW hub. I ran the truck pretty hard yesterday and had no problems with the wheel nuts. Don't know if it was the serrated nuts, thread locker or both, but it worked! Sent from my iPhone using Tapatalk Last edited by Sammy J.; 08-15-2016 at 04:03 PM. | |
08-15-2016, 04:21 PM | #350 |
Ah, yes you're correct, but I'm still not a fan of the serrated nuts, they chew up the hubs. On other wheels I've found the smooth flanged nuts with blue loctite did the trick. |
08-15-2016, 05:24 PM | #351 |
Pebble Pounder Join Date: Jan 2010 Location: CA
08-15-2016, 06:43 PM | #352 |
| Re: New Incision wheels coming.... So maybe a stupid question but would a washer help to get more surface on the wheel and the hex for the nut to go againt with loctite help ? Or would a washer be useless and just the loctite help?
08-15-2016, 06:50 PM | #353 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
I don't think that will remedy the fact that the male hex wiggles inside the female hex on the wheel slowly working it lose. I was thinking about filling the female hex with something that would harden. Make a sort of cast of the hex inside the wheel. Not sure if anyone has tried that or if the amount of slop in the wheel and hex is enough to be filled. What about wrapping the hex tightly with electrical tape? One wind may fill the gap? Sent from a device in my hand that is smarter than me, and I don't know WTF I'm doing. Last edited by DowntownScience; 08-15-2016 at 06:55 PM. |
08-15-2016, 06:59 PM | #354 | |
Sent from a device in my hand that is smarter than me, and I don't know WTF I'm doing. | |
08-15-2016, 07:15 PM | #355 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
08-15-2016, 07:35 PM | #356 |
Thank you Drm31078...is that one wheel sitting on a mirrored surface or two wheels stacked?
08-15-2016, 07:37 PM | #357 |
08-20-2016, 06:29 AM | #358 |
Hubs are now available. $10 per pair. |
08-29-2016, 12:26 PM | #359 |
My Method 1.9s came in last week and I finished up sanding the outer lip yesterday. The wheels came out pretty great, these will be finding a home on my SCX10 II. I started with 320 grit (it took a while to get all the anodizing off) then I hit the wheels with 600 and 1500 grit for a super smooth finish. You can stop at 600 and still get a finish that is smooth enough for most people. Even just using the 320 grit left a finish that looks good unless you are really close and in the right light. I tried to take a picture at each stage but the camera on my phone isn't good enough to capture the differences. |
08-29-2016, 02:05 PM | #360 |
The 1.9's are less than 1" wide, correct? If so, is there anyway to get them to 1.2"?
New Incision wheels coming.... - Similar Threads | ||||
Narrowing Stock XR10 wheels to fit Vanquish Incision Knuckles | The gasman | Tires and Wheels | 8 | 01-13-2014 06:46 PM |
vanquish XR-10 Incision Steering Knuckles and wheels | bikeboy | Axial XR10 | 35 | 03-07-2012 09:51 AM |
VP Incision Steering Knuckles/Stock Wheels | Mysterious | Axial XR10 | 9 | 12-11-2011 05:18 PM |
New 1.9 wheels coming | Gozer | Losi Mini-Rock Crawler | 4 | 10-21-2008 02:59 AM |
