Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: 3d printer for rc parts
Old 12-20-2017, 06:24 AM   #61
Moderator
Default Re: 3d printer for rc parts
I'm liking the idea of trying some PETG also, but I want to make some upgrades to my printer first. Most of what I'm reading about PETG indicates that it's going to want extruder temps that are at or above what I feel comfortable doing with mine until I get an all metal extruder. I also want to get the MOSFET in before I raise my bed temps up. I should probably get a 2nd MOSFET for my extruder too.
Jim85IROC is offline   Reply With Quote
Old 12-20-2017, 06:32 AM   #62
Moderator
JatoTheRipper's Avatar
I haven't seen this mentioned. A quality filament brand is key to good printing. I prefer Hatchbox and a local company called Filament Innovations.
Old 12-20-2017, 07:14 AM   #63
Custom Carbon Fiber
Robbob's Avatar
Another thing that helped me was wrapping my extruder in an insulator and Kapton tape. When I got the kit the heat block wasnt covered with anything and would never seem to get hot enough.
Theres also a write up Ive seen of doing the same to the bottom of a heated bed. I havent done it to mine but I havent had any temp problems on the bed yet either.
I like the Hatchbox stuff, only problem I have with it is breaking. If I dont use the printer for a while it seems the filament breaks where it feeds into the stepper block. I could be chaffing it there too but dont think its from that.
Ive also used the 3D Solutech stuff and liked it. The normal color stuff worked well, the fancy neon colors are ok but Im never happy with the finish/appearance of them. Just look messy, not smooth like the other stuff.
I havent tried these guys yet, MatterHackers, but want to. Ive read good things about them in the past, little higher priced then others but it seems like it might be worth it.
Ive also printed in CF using the stuff Proto-Pasta. Real easy to print and setups like normal PLA. I liked it better in non stress/low stress areas, it can def be brittle to handle and if the parts small it can be too easy to snap. But it is a little lighter in weight then normal print.
Robbob is offline   Reply With Quote
Old 12-20-2017, 07:21 AM   #64
Moderator
Which type of Hatchbox breaks on you - ABS, PLA, or PETG?
I've been meaning to try Proto-Pasta.
Old 12-20-2017, 07:26 AM   #65
Custom Carbon Fiber
Robbob's Avatar
PETG ..... its about 5mm up from where it gos into the stepper block. Ive tried leavign the head centered thinking it was pressure from the twirl from being spooled up, still breaks. Its more of a pain the ass re-feeding the filament but it works fine when Im using the machine.
I liked using the Pasta stuff, plus they're a small company it seems thats in the filament business because of passion for it and not the dollars. Seems like they got some new stuff since I last looked too.
This looks interesting.
https://www.proto-pasta.com/collecti...ant=1204196648
Old 12-20-2017, 07:44 AM   #66
Moderator
Hmm I've never had that problem with PETG. I have had it with PLA, but PLA gets brittle when you leave it out because it takes on moisture.
That's why I like Filament Innovations. Small, local company and the guys are nice, responsive and passionate about 3D printing. Plus the filament I've tried works very well.
These two items were printed with their Diamond Line blue filament. No post processing.
Old 12-20-2017, 07:58 AM   #67
Custom Carbon Fiber
Robbob's Avatar
Those are pretty clean for sure. Could be the colors Ive use too, neon green and yellow. That blue is sharp.
Old 12-20-2017, 08:48 AM   #68
ABS sucks IMHO. You need to put your printer in an enclosure or have it in a tightly environmentally controlled area. I prefer PETG over ABS by a long shot. And yes, the Select Mini will print PETG.
What heat settings do you use ?
Speed and thickness ?
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 12-20-2017, 08:55 AM   #69
Moderator
Hang up and Drive
For the print above? I'm honestly not sure. I typically print slow and use thin layers on most things unless I don't care about the look. I can share my generic settings when I get home if you'd like. Most prints don't vary too much off of my standard settings.
Old 12-20-2017, 09:23 AM   #70
Sorry, I meant between PLA and PETG
Hang up and Drive
Old 12-20-2017, 09:28 AM   #71
Moderator
Hang up and Drive
I think I mostly use the same settings except for the extruder and bed temperatures.
Old 12-20-2017, 09:45 AM   #72
Custom Carbon Fiber
Robbob's Avatar
For me I use 190/205 on PLA with bed temp 60-70 .... PETG I use 215/230 and found 70-80 works for my bed.
Same here too all my other settings are the same, just change the temps.
Old 12-21-2017, 08:57 PM   #73
Reread and am stoked......I will wait until the 27th, but an messing with cura , so I know my way around
Hang up and Drive
Old 12-22-2017, 06:26 AM   #74
Custom Carbon Fiber
Robbob's Avatar
Checked out my reel of Hatchbox after reading this and realized it was PLA, I been printing that with my PETG temps with out realizing it. Its actually printing really really good too lol.
But didnt know PLA took on water that bad, makes sense. I keep the rolls Im not using in a dry box (wood desk drawer) next to the heater and the silica packets in there with them.
Old 12-22-2017, 06:52 AM   #75
Moderator
That'll do it. I store my PLA in rubber sealed totes with silica packets. Moisture turns PLA to junk. You can supposedly bake the water out, but I haven't had much success in getting it to print well afterwards. Hopefully you can save yours.
Old 12-22-2017, 07:59 AM   #76
Custom Carbon Fiber
Robbob's Avatar
When I was looking at trying nylon I read about baking it and the moisture problem. I saw one idea I thought was great, food dehydrator.
Something like this that the roll would fit into.
https://www.amazon.com/Presto-06300-...ood+dehydrator
Saw a picture of a spool mod on Thingiverse one day and in the background I could see they had a roll inside a dehydrator.
My PLA has been good, its still near the heater and being winter I always have it on around 70. Summer Ill change it up though.
Old 12-22-2017, 08:32 AM   #77
I like the dehydrator, I actually use one for drying paint that I’ve airbrushed on styrene bodies
Hang up and Drive
Old 12-24-2017, 06:53 AM   #78
Hi guys, I`m in
Bought a Wanhao Duplicator 6 and started fiddling around.
Testobject: spring perch
and trying different printing orientations with different results:
Overhangs seem to cause problems. Maybe a cooling problem. Printinga new blower fan duct now
Stollenritter is offline   Reply With Quote
Old 12-24-2017, 10:56 AM   #79
Originally Posted by Stollenritter View Post
Hi guys, I`m in
Ninety degree overhangs usually require supports to print without sagging.
I would check your slicer software and find the option for printing supports and try it again.
Here is one my favorite articles on learning to make good prints.
https://forum.lulzbot.com/viewtopic.php?f=7&t=1709
k7zpj is offline   Reply With Quote
Old 12-24-2017, 11:20 AM   #80
Hello K7,
Thank you for help! I will go trough the article, seems a good write up for beginners
3d printer for rc parts - Similar Threads
Can your printer do this? CREEPERBOB Chit Chat 19 10-14-2011 07:33 PM
Are you a printer in OH or know someone who is? Phatmac Ohio 5 02-20-2009 02:14 PM
