04-06-2018, 03:48 PM | #261 | |
| Re: 3d printer for rc parts Quote:
The whole works is backed up offsite with another service so that I can recover it if something bad happens. Having cloud access allows me to use the same info for multiple computers so that I can do the design at other locations if needed. | |
04-06-2018, 09:46 PM | #262 |
Rock Crawler Join Date: Nov 2014 Location: Dells
Just picked up a monoprice mini v2. Time to have some fun... |
04-06-2018, 10:30 PM | #263 |
Looking around thingverse right now, are there any other good sources of stl files out there? Recomended program for making/editing STL files? paid or not.... |
04-06-2018, 11:27 PM | #264 | |
https://all3dp.com/1/free-stl-files-...-stl-download/ Makers Muse on You Tube has some good recommendations: Plus check out 3D Printing Nerd and Thomas Sanladerer on You Tube for information on 3D printing. | |
04-07-2018, 05:48 PM | #265 |
Been playing with it a bit today... been trying to make a milk crate, results haven't been spectacular, but it's getting better. I still haven't been able to get it to connect to a PC. Nether cura nor malyan will comunicate with it, even though it shows up in device manager. |
04-07-2018, 06:07 PM | #266 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
Went and purchased a Rasberry Pi 3 B+ today and loaded OctoPi on it. Printing the 1st job with it now. First thought is it makes like much easier. No more swapping SD cards between the printer and the PC. Did the slicing on the PC and uploaded it to Octoprint for printing. Also have a web cam hooked up so I can check on the print job from the recliner.
04-07-2018, 06:13 PM | #267 | |
Only issue is a power surge or failure, a low end Batt back up (UPS) will solve that. A blip will recycle the printer ...... happened to one print here when I was watching. Lesson learned Hang up and Drive | |
04-07-2018, 10:08 PM | #268 |
Well that was short lived, I was print a case for the Raspberry Pi and the Octoprint server crashed. On the bright side it was towards the begining. I thought that Octoprint could resume but it appeared it was going to start from scratch so I just dumped the gcode file to the SD card and printed from there. Might need to wait for a more stable version of Octoprint. I bought the Raspberry Pi 3 B+ which the stable version of Octoprint isn't compatible with yet.
04-07-2018, 11:41 PM | #269 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: 3d printer for rc parts |
04-08-2018, 09:28 AM | #270 |
Newbie Join Date: Jul 2007 Location: Northern New York
| Re: 3d printer for rc parts What's your baudrate set at in your slicer program? The wrong numbers in that setting for that and your PC will never connect to it.
04-08-2018, 09:47 AM | #271 | |
I found that I could communicate , but nothing would work. I solved it by also turning the AC on to the printer. The USB connection powered the lcd, but not the heat on the hot end or bed Hang up and Drive | |
04-09-2018, 06:39 AM | #272 | ||
My printer was set to AUTO for both Com and Baud, have you tried manually changing that? My baudrate was 115000 if that helps ya. I been playing around with Octoprint, after finally getting it to run, and like it but havent seen a upside to it verse Cura yet. I also found MatterControl and played a couple times. Basically wanted to get in and tune PID and some other stuff. MatterControl didnt have the extensive install like OctoPrint. Just more tools to try https://www.matterhackers.com/store/...ol/sk/MKZGTDW6 | ||
04-09-2018, 08:39 AM | #273 | |
Check to see if there are inactive com ports - Open device manager, under the View menu select "Show hidden devices". Now check to see what com ports are listed. If you have any that are greyed out, delete them, reboot the computer, and then try connecting your printer again. | |
04-09-2018, 04:00 PM | #274 |
It was all fun and games until the extruder plugged at hr9 on a 10hr print. Filament melted in the housing and stuck Waiting on my petg to print the upgraded dual fan housing/etc. I don't think PLA would work |
04-09-2018, 05:09 PM | #275 |
Apparently I'm not allowed in the monoprice mini FB group. Its been 2 days since I tried to join. Are there any good forums that cover them? |
04-09-2018, 05:29 PM | #276 |
04-09-2018, 05:47 PM | #277 |
Thingaverse has many groups, go look and see if enough activity to suit you. Hang up and Drive |
04-09-2018, 05:57 PM | #278 |
Most of the face book groups are nothing but partial clogs and people totally baffled over why the PLA is printing bad at 180c and 100mms speeds. You aren't missing much that a google search won't find, except 50 notifications a day of the same question. Ive had to unfollow every single group because of the sheer numbers of people that refuse to do any research or trial and error for themselves.
04-09-2018, 08:13 PM | #279 | |
My bs filter is finely tuned at this point The cooling fan had a bad connection on it causing it to run sometimes. The wire came right off as I was taking it apart to clear the clog. Fixed the fan for now, ordered 2 nautica fans and some petg to make a new housing for it. I'm planing on makeing this one, unless someone has a better idea. https://www.thingiverse.com/thing:1848402 | |
04-09-2018, 08:21 PM | #280 | |
Diii cooler, modified to see hot end. Hang up and Drive | |
3d printer for rc parts - Similar Threads | ||||
Can your printer do this? | CREEPERBOB | Chit Chat | 19 | 10-14-2011 07:33 PM |
Are you a printer in OH or know someone who is? | Phatmac | Ohio | 5 | 02-20-2009 02:14 PM |
