07-25-2018, 02:26 PM | #21 |
Rock Stacker Join Date: May 2018 Location: northern illinois
| Re: TRX-4 2017 Jeep CRC JK
I'm running those HK special axles on my trx4. The only fitment issue I had was needing to remove some paint on the tabs the rod ends mount between. Sent from my SM-G950U using Tapatalk |
07-26-2018, 08:09 AM | #22 | |
Rock Crawler Join Date: Jul 2015 Location: Butler, Pa
| Re: TRX-4 2017 Jeep CRC JK Quote:
I did notice the same thing when I put everything back together last night after I read your post. How do you like them? Sent from my iPhone using Tapatalk | |
07-26-2018, 08:12 AM | #23 |
Got everything somewhat back together and really happy how it turned out Sent from my iPhone using Tapatalk |
07-26-2018, 08:24 AM | #24 |
They are holding up fine. No issues. Sent from my SM-G950U using Tapatalk |
07-26-2018, 10:25 AM | #25 |
| Re: TRX-4 2017 Jeep JK
It's hard to see but I have started trimming out the front fenders. There's a lot of material to be removed. The from grill will fit into the fender. There is a big difference in how much heavier the truck is with the new axles
07-26-2018, 07:45 PM | #26 |
One fender down and one to go. There was a good bit of removing plastic to get the light buckets on the grill to fit around the fenders. You can see the difference between the two. Sent from my iPhone using Tapatalk |
07-26-2018, 07:47 PM | #27 |
From the front view Sent from my iPhone using Tapatalk |
07-27-2018, 06:00 PM | #28 |
Was able to get some work done after I got home from work today. It's really starting to come together now. Just need to work on front bumper next. Sent from my iPhone using Tapatalk |
07-27-2018, 06:29 PM | #29 |
really liking the body swap. check out shapeways if you want to suck your front bumper mount back 11.5mm they have a 7v 0h mount from lockedup rc. used a 0v 0h on my swap and put my bumper just where I wanted. |
07-27-2018, 07:06 PM | #30 | |
| Re: TRX-4 2017 Jeep JK Quote:
I have been looking at those Locked up mounts. I have also been talking with Knight Customs making a direct fit bumper for the TRX rails. Basically wanted to take the Axial bumper and make it fit in the TRX rails. It should come out looking awesome. | |
07-27-2018, 07:16 PM | #31 |
Also the fit of the body is still rough. It will soon be all sorted out and straight. Then to finish up the chassis and run some wires. I have an idea for the wires but just not sure if I want to go that route just yet |
07-27-2018, 08:33 PM | #32 |
Like the bolt on bumper idea. I've been eyeballing that knight customs steel printed bumper for my sr5 but havent pulled the trigger on it yet. Sent from my SM-G950U using Tapatalk |
07-27-2018, 08:51 PM | #33 |
| Re: TRX-4 2017 Jeep CRC JK I have used his designs many times now. Very detailed and fit perfectly. I was trying for the Smitty MOD bumper that will hold the winch also. I have seen it used on his Jeeps. I really flows with the front grill IMHO. I was also trying for it plastic to help with the cost |
07-29-2018, 07:42 PM | #34 |
For my wiring idea I going to use some wire sleeve that I left over from when I made my charging leads. It might take a little bit to run all the wires through but I think it's going to look different. Plus the color scheme is American as a Jeep and apple pie. Any thoughts on it? My T6 is also with the same colors Sent from my iPhone using Tapatalk |
07-30-2018, 10:37 AM | #35 |
Rock Stacker Join Date: Mar 2016 Location: Santa Rosa
My thoughts on the colored wire loom is keep loom black so it hides the wires rather than makes them standout. I usually shrink wrap a good portion of my wiring black especially if you can see it through the windows. Just makes it look more scale if you can't see the wiring IMO.
07-30-2018, 10:43 AM | #36 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
I agree. I don't like wiring. Hide it when you can.
07-30-2018, 06:43 PM | #37 |
| Re: TRX-4 2017 Jeep JK I am nut when it comes to wiring. I will spend hours playing around with the wires. I thought about doing it in black but I already have the colors. Looking forward to putting in an interior so it won't be visible through the windows. I am stuck and not sure what to do.
07-30-2018, 11:59 PM | #38 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
That Jeep has quite a few windows, I agree with black as well. Could you use that to make some little scale rope bits or something? |
07-31-2018, 08:09 AM | #39 |
| Re: TRX-4 2017 Jeep JK I probably could to something like that never thought of it. With the interior and fenders you wouldn't see any of the chassis unless the body is off. Black is still a possibility since the sleeve is cheap.
09-04-2018, 06:44 PM | #40 |
I haven't forgotten about the JK. I have been busy with an awesomely side project build. I will be continuing the build on the JK
TRX-4 2017 Jeep JK - Similar Threads | ||||
TRX-4 Jeep Cherokee | carpetfuzz17 | Traxxas TRX-4 | 187 | 03-14-2021 07:28 PM |
Jeep JK TRX-4 Build | Crawler505 | Traxxas TRX-4 | 46 | 05-12-2019 07:16 PM |
2017 CRC Jeep Body | carpetfuzz17 | Axial SCX10 II | 10 | 07-22-2018 08:25 PM |
2017 Jeep body width | number9 | Axial SCX10 II | 2 | 03-31-2018 10:12 AM |
