Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: New Vanquish Chassis Kit
Old 09-23-2019, 03:09 PM   #161
Go Buckeyes!
B-MOW71's Avatar
Default Re: New Vanquish Chassis Kit
Originally Posted by DukeMinnix View Post
I have some theory about trx4 axle being offset enough. You all may get an update about that sometime, depends on if I can bring myself to actually pull the trigger.
I think the TRX-4 axle will work.
Ok, go ahead and pull the trigger! I need to see what you are cooking up!
B-MOW71 is offline   Reply With Quote
Old 09-23-2019, 03:45 PM   #162
Originally Posted by Topher Builds View Post
do itttt
which one of you want to do the math on all the gearing so I don't end up with a truck that runs like a terd and looks amazing? vfd overdrive, trx4 rear underdrive. Pinion and spur you ask... damn good question
DukeMinnix is offline   Reply With Quote
Old 09-23-2019, 04:09 PM   #163
Go Buckeyes!
B-MOW71's Avatar
Well, I suck at all that gearing math! I need to sit down and figure mine out someday!
Harley just posted videos on YouTube explaining how to calculate gearing. You should check that out.
Old 09-23-2019, 04:16 PM   #164
Im Brandon
Brandon's Avatar
Josh did a very similar build and just last week did a video covering all the math. Here is the gearing video: https://www.youtube.com/watch?v=N1F-wfq4d44&t=895s
The VFD Transmission kit includes an updated skid plate with just enough material removed to allow for perfect driveshaft clearance when using the offset TRX4 Front axle.
I recommend getting the TRX4 VS4-10 Panhard and Drag link kit to help locate the axle properly due to the shorter links required with the position of the panhard mount ont he TRX axle.
https://www.vanquishproducts.com/inc...rd-for-vs4-10/
Brandon is offline   Reply With Quote
Old 09-23-2019, 04:22 PM   #165
Gold Star Baby!
Topher Builds's Avatar
Since i just learned this over the weekend I'll give it a shot...
Stock pinion = 15t
Stock Spur = 56T
VFD Trans = 2.95 Front / 3.15 Rear
TRX4 Axle = 34/11 Front, 35/10 Rear, 2.3 Portal
Soooo...
Front (56/15)*2.95*3.09*2.3 = 78.29 FDR
Rear (56/15)*3.15*3.5*2.3 = 94.67 FDR
This gives you 17.3% overdrive at the front axle.
17t pinion gets you to 69.08/83.53 F/R
19t pinion gets you to 61.81/74.74 F/R
DO IT! (Or I will too ( I might anyway since I have these axles sitting around))
Topher Builds is offline   Reply With Quote
Old 09-23-2019, 04:24 PM   #166
indybama's Avatar
Heck yeah, just wat ive been waitin for! N $110 bucks?! Lovin it VP! Like topher said, great deal for the chassis kit n VFD kit. This just keeps gettin better n better!
Sent from my SM-J327VPP using Tapatalk
indybama is offline   Reply With Quote
Old 09-23-2019, 04:26 PM   #167
I already have a cart loaded haha, just need to pull the trigger
Stock pinion = 15t
Stock Spur = 56T
Soooo...
This is what I came up with too and is WAYYYYYYY deep I think. Now if I did comp crawling I think it may be amazing, but as much of my use is trailing as crawling, but just for the sake of doing it, I may have a mountain goat sooner than later haha, I need to stop getting ideas.
Old 09-23-2019, 04:58 PM   #168
Gold Star Baby!
If you overdrive the front instead of underdrive on the rear you’ll still have 16.7% OD and can get to a 54.99/66.00 F/R fdr with a 19t pinion.
Doing both OD and UD gets you 54.99/74.74 F/R with a 26.4% OD.
Old 09-23-2019, 05:26 PM   #169
Gold Star Baby!
Originally Posted by svt923 View Post
The motor plate and support braces are plastic instead of aluminum and the gears are sintered instead of machined.
Machined gears and motor plate are up now
https://www.vanquishproducts.com/vfd...um-motorplate/
https://www.vanquishproducts.com/vfd-machined-gear-set/
Old 09-23-2019, 05:33 PM   #170
Stock pinion = 15t
Stock Spur = 56T
Soooo...
Another consideration is going to a smaller spur to fit a larger pinion. The VS410 Pro manual lists 56/17 as the largest gearing which produces the same gear spacing as 50/23. Going 1 tooth smaller on the pinion (50/22) for a little wiggle room would have the same gear spacing as 56/16 so it should fit within the available mesh space and give you a 47.6:1 ratio at the front and a 57.6:1 ratio at the rear.
svt923 is offline   Reply With Quote
Old 09-23-2019, 05:34 PM   #171
What does "sintered" mean in the gear description?
Sent from my LM-G710VM using Tapatalk
MaX-D is offline   Reply With Quote
Old 09-23-2019, 05:38 PM   #172
Metal powder melted together with a laser.
txbart is offline   Reply With Quote
Old 09-23-2019, 05:41 PM   #173
So can sintered gears strip easily?
Old 09-23-2019, 05:43 PM   #174
Gold Star Baby!
Love it.
Old 09-24-2019, 08:10 AM   #175
God you must have a math job
Old 09-24-2019, 08:35 AM   #176
Im Brandon
Brandon's Avatar
They are extremely durable. Only second to machined hardened steel gears.
Old 09-24-2019, 08:37 AM   #177
Thank you for the clarification. This is the first I've heard of sintered Gears, so this is new to me.
Old 09-24-2019, 09:03 AM   #178
Im Brandon
Brandon's Avatar
Most manufactures that use this type of gear will advertise them as "Metal Gears". We wanted to make sure to provide all the information so there is no confusion between the different options available.
Here are the machined steel gears that would be an option for the VPS10152 VFD Transmission Kit: https://www.vanquishproducts.com/vfd-machined-gear-set/
Old 09-24-2019, 09:18 AM   #179
Are the machine gears necessary in this transmission?
Old 09-24-2019, 09:29 AM   #180
I'm going to say the sintered gears will last the life of the truck for 95% of the people.
New Vanquish Chassis Kit - Similar Threads
Pre-Order Now - New Vanquish VS4-10 Chassis Kit RPP Hobby RPP Hobby 1 05-20-2019 04:31 PM
VP Chassis Mount Servo Kit/ Panhard Kit? Pita Axial Wraith 54 05-23-2014 09:24 AM
