06-18-2018, 09:46 AM | #261 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Ascender Build |
06-18-2018, 09:49 AM | #262 | |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
| Re: Ascender Build Quote:
Sent from my ZTE A2017U using Tapatalk | |
06-18-2018, 03:36 PM | #263 |
| Re: Ascender Build
That exact thing happened to a guy my friend and I crawled with a few weeks ago - happens when crawling the shoreline of waterways... A real mess to get rid of! |
06-18-2018, 05:04 PM | #264 | |
06-18-2018, 06:15 PM | #265 |
| Re: Ascender Build
Got a package in the mail. All the way from China. It's the 1.45:1 ratio. Sent from my ZTE A2017U using Tapatalk |
06-18-2018, 08:21 PM | #266 |
| Re: Ascender Build
Lazy fishermen are bad for everything, aquatic life, land animals and crawlers. :( Overdrive the front axle with the transfer case? |
06-22-2018, 10:53 AM | #267 |
| Re: Ascender Build
So I got some parts in the mail today. My mishap with the missing springs was actually a good thing. I found a set of springs with mounts for $22. I decided to go that route even though they don't come with u bolts. I can make my own with some piano wire and a small dye. Or I might have some rc4wd style axle mounts printed or fab something. I also got the trans I'm going to be using. I picked up a r4 scale trans. Sent from my ZTE A2017U using Tapatalk Last edited by mgputer; 06-22-2018 at 10:57 AM. |
06-22-2018, 01:08 PM | #268 | |
06-23-2018, 12:47 PM | #269 |
| Re: Ascender Build
Making a little progress. Working on getting everything to fit. I might have to run a stock trans. It looks like if I cut under the seat I could get it to fit. Sent from my ZTE A2017U using Tapatalk |
06-23-2018, 01:37 PM | #270 |
| Re: Ascender Build
I think that's the way I'm going to do. I trimmed it out and the trans fits under the seat perfectly. Sent from my ZTE A2017U using Tapatalk |
06-23-2018, 01:41 PM | #271 |
| Re: Ascender Build
Amazon is getting sloppy. First my springs were missing and now the inner rings on 3 of the bead locks I bought. Was planning on painting them. Only color they had in stock. Now I have to reorder lol. Sent from my ZTE A2017U using Tapatalk |
06-23-2018, 01:45 PM | #272 |
| Re: Ascender Build
Now that I have the cab pretty much trimmed to fit it's time to start putting on the leaf springs and shorten the frame a little bit. Sent from my ZTE A2017U using Tapatalk |
06-23-2018, 02:01 PM | #273 | |
Sent from my SM-G930R4 using Tapatalk | |
06-23-2018, 02:29 PM | #274 |
| Re: Ascender Build
Well the body is the same length pretty much as the f100 and the width is only different by 1/8th inch. Is it tight? Yes. Can I make it work? Yes. Sent from my ZTE A2017U using Tapatalk
06-23-2018, 02:45 PM | #275 |
06-23-2018, 02:48 PM | #276 |
| Re: Ascender Build
I can make anything fit. It just involves more effort lol. My biggest problem is the body is designed for a flat frame. If I have to I'll be going to the hardware store and picking up some c channel. But I think I can make it work. Sent from my ZTE A2017U using Tapatalk |
06-24-2018, 11:09 AM | #277 |
| Re: Ascender Build
That’s a great looking hardbody with separate fenders and, love it! Yes you could always go with flat straight c-channel frame. |
06-24-2018, 12:34 PM | #278 |
| Re: Ascender Build
Another little update. Front springs on. Sent from my ZTE A2017U using Tapatalk |
06-26-2018, 06:40 PM | #279 |
| Re: Ascender Build
Transmission installed. It's starting to come together. When my box of parts show up I should have the chassis ready to go Sent from my ZTE A2017U using Tapatalk |
06-26-2018, 07:05 PM | #280 |
| Re: Ascender Build
I forgot to mention that I picked up a GCM lrt2 transfer case instead of the original plan to have overdrive front. I figured this small tired rig is going to need all the help it can get so I ordered one. The engine and trans sit nice and low in the chassis. Sent from my ZTE A2017U using Tapatalk |
Ascender Builds - Similar Threads | ||||
New build ascender | jmarsh1976 | Vaterra Ascender | 32 | 01-05-2016 01:14 PM |
Ascender build | Markeje | Vaterra Ascender | 13 | 09-24-2015 09:08 AM |
Ascender Build | seth556 | Vaterra Ascender | 12 | 01-05-2015 03:13 AM |
My Ascender Build | wax | Vaterra Ascender | 1 | 10-22-2014 05:38 PM |
