06-15-2013, 01:24 PM | #21 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
| Re: ***DERWOOD DESIGNS Double D Steering Kits*** Thanks! Just in time for me. After a day of creekbed crawling my steering is SUPER sloppy. The paint is rubbed off the hr steering rack I bought so those things are a waste of $$. They probably don't work as well as the stock piece. Steering is just a bad design for a car meant to run in the dirt, too much friction going on
06-15-2013, 03:43 PM | #22 |
Rock Crawler Join Date: Sep 2009 Location: The BYB Compound
Great work on getting these out Daren. For those that have preordered you will be stoked to put this on. The product is well built and easy to install. No need to worry about anything with this steering rack. My buddies and I drive the crap out of our cars with no issues. I have jumped mine onto the roof of the house and fell off with total confidence in the rack. We havealso done some down hill jumps the didn't work out to well and ended up cartwheeling 30 or so feet before coming to rest with no failure. If ur on the fence just jump off and order ur double D steering rack. It's a great upgrade. Thanks Daren
06-19-2013, 12:14 PM | #23 |
Quarry Creeper Join Date: Aug 2007 Location: Rocklin, CA
| Re: ***DERWOOD DESIGNS Double D Steering Kits*** Thanks for all the orders Everything has been shipped out in the past 2 days. I have 5 more ready to ship out if you didn't get in on the preorder. The shock mount is still in the works but should have it nailed here soon. And for all the guys with concerns about this working with the BMRC shock tower, I have a steering kit on the way to a customer that is going to check the fitment and post up results. After looking at it closer, I'm pretty sure the tower will fit with the steering kit with alittle clearancing of the shock tower for the 4mm bellcrank bolts. We'll know for sure soon. |
06-19-2013, 04:59 PM | #24 |
Quarry Creeper Join Date: Aug 2010 Location: Brisbane Australia
Sweet. Can't wait to get mine.
06-20-2013, 09:52 AM | #25 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
if there is clearance issues with the nut why dont you put the nut on the bottom and the screw on top? just an idea. Also great looking product, glad people are still working on the TH! Thanks for the great product, hopefully products soon!
06-20-2013, 10:17 AM | #26 |
Quarry Creeper Join Date: Feb 2010 Location: Knee deep in a creek with a fish on the line
| Re: ***DERWOOD DESIGNS Double D Steering Kits*** I am the customer he is talking about, and flipping the nut to the bottom is the only issue i see for clearance. I was planning on that anyway just for ease of assembly/dis-assembly. I think stacking the BMRC shock tower will actually help with the shock length you can use (right now you are limited to about 80-90MM. not a lot of good shocks in that range without limiting them internally). The only other issue is going to be clearance for batteries. I don't race and i use slim 1000-1300 Mah batteries anyway so for me it is a non issue. Once i get the parts I will post up in this thread with the results.
06-20-2013, 11:35 AM | #27 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Payment sent Can't wait for some slop free steering. I race my hammer around a track and this will be a huge improvement. |
06-20-2013, 12:03 PM | #28 | |
| Re: ***DERWOOD DESIGNS Double D Steering Kits*** Quote:
06-21-2013, 08:10 AM | #29 |
Rock Stacker Join Date: Mar 2013 Location: Gainesville
Wahoooo.. it's on the way!!! Expected Delivery By: June 22, 2013 |
06-21-2013, 01:11 PM | #30 |
Newbie Join Date: Feb 2013 Location: Louisville
Money sent for my kit. Thanks and God bless!
06-21-2013, 06:52 PM | #31 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Got mine installed today it tightened up the slop. Be sure you guys reverse your steering before hitting the dirt. notice the bolt for the tie rods is upside down, it needs to be this way for clearance at the chassis. |
06-22-2013, 09:06 AM | #32 |
Pebble Pounder Join Date: Sep 2011 Location: Oceanside Ca
Can you sell everything except the top plate? I have a GCM shock mount and think I could drill some holes to make the bell cranks fit and work ok.
06-23-2013, 06:25 PM | #33 |
Just finished putting together this kit, and the BMRC shock tower. I only needed a small amount of modification to the BMRC tower to make it work. I also added 6mm spacers between the chassis, and the plate to create more clearance. this eliminates the need to trim the chassis, and a clearance issue with the chassis/diff bolts, and the tie rod bolts. 3-4MM is probably enough, but all i had was the 6mm in my parts box I have to say this totally eliminated the steering slop, and fixed a problem with the steering binding to the left. This is a great product. every thing in black needs to go on the rig The dog bones at full droop with 90MM powerstrokes |
06-23-2013, 08:19 PM | #34 | |
06-23-2013, 09:51 PM | #35 |
Rock Stacker Join Date: Apr 2012 Location: Arundel ME.
Got mine installed tonight, looks like its going to work awesome, test it tomorrow. Thanks derwood designs. |
06-23-2013, 10:16 PM | #36 |
I just bought a shock brace because I noticed mine was cracked and then found this!! Nice work! I will be picking one up for sure!! |
06-24-2013, 06:12 PM | #37 |
Pebble Pounder Join Date: Nov 2011 Location: modesto
Great job!! glad to see your intrest in the hammers, i my self did it all the hard way trusty dremil, glad to see u have fixed one of the biggest issues of the hammers
06-25-2013, 09:32 AM | #38 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
I like innovative thinking! Solves the biggest issue I have with the TH. If it weren't for the steering being so sloppy I'd probably drive it more often, because if it's not wandering around it's really fun. I'll be picking up one of these for sure... |
06-25-2013, 11:55 AM | #39 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Is there a way to adapt this to the BMRC upright mount without stacking it on top? My servo winch touches the cage now, so I have no room to go up.
06-26-2013, 12:33 AM | #40 |
Just wanted to post up some pics of my install using one of the tube upright shock towers from one of RCC's vendors. Went on smooth and pain free. Just need some slightly longer hardware to compensate for the beefy bellcrank/shock mount plate. The Double D steering setup is Tits and you can't go wrong |
***DERWOOD DESIGNS Double D Steering Kits*** - Similar Threads | ||||
***Derwood Designs Double D steering kit for Twin Hammers*** | derwood21 | Chassis and Suspension | 72 | 02-17-2016 07:39 PM |
Steering linkage kits | simon170 | HPI Wheely King | 24 | 01-27-2008 02:19 AM |
BTA steering kits? | LIKES2CRAWL | Tamiya Clod Buster | 35 | 06-26-2007 11:07 AM |
Clod Steering Kits ??? | TIMZKRAWLER | Newbie General | 1 | 04-17-2007 07:25 PM |
bta steering kits | andrewmp6 | Tamiya Clod Buster | 14 | 11-12-2006 11:45 PM |
