07-06-2012, 11:58 AM | #441 |
Rock Crawler Join Date: Jan 2012 Location: st.louis
well my dads brother has a waterjet and cnc machine. looks like i can get some good.chassis. wjere can.i get aluminum or delrin thick eniugh. rmdw? Sent from my SPH-D700 using Tapatalk 2 |
07-06-2012, 01:16 PM | #442 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| Re: Masonis1's project creeper
online vendor...maybe some place like onlinemetals.com for aluminum...2-3mm thick and maybe mcmaster-carr or professionalplastics.com for delrin 3-4mm thick
07-06-2012, 04:29 PM | #443 |
thanks for the.site. ill.give those a try. also what would be a good design for a chassis. i k.ow you have a couple that ive heard are amazing. help.on designing one for.foff Sent from my SPH-D700 using Tapatalk 2 |
07-06-2012, 10:02 PM | #444 |
Wow! Between ur two young brilliant minds an ideas, I can't wait to see this thing come alive! Ideas are all over the place an sound wild! Let's get a build on mason!
07-07-2012, 03:20 AM | #445 |
hah ill try. is this the first creeper foff? if so we need to make it BA Sent from my SPH-D700 using Tapatalk 2 |
07-07-2012, 03:31 AM | #446 |
been thinking about the.chassis. would it be like rmdw chassis or would it be stretched out amd.lower and if so how would i go.about designing.one.like that Sent from my SPH-D700 using Tapatalk 2 |
07-09-2012, 08:08 PM | #447 |
so the.build.begins. just started tearing the truck.down. got everything electronic off and now taking the tranny.off. Sent from my SPH-D700 using Tapatalk 2 |
07-09-2012, 08:16 PM | #448 |
tranny is out. Sent from my SPH-D700 using Tapatalk 2 |
07-09-2012, 08:45 PM | #449 |
well first problen. the motor shaft is a lot bigger. its a 4mm shaft. the 5900kv i.have has the same size shaft as the 55t. what should i put in? i do.see people putting mamba 5900 setups.in foffs Sent from my SPH-D700 using Tapatalk 2 |
07-09-2012, 11:57 PM | #450 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
you can put that in but your tranny ant going to last long. i run with guys that have them in short course trucks and they fly but there tannies dont last long as well if they have the slipper clutch just a little to tight.
07-10-2012, 07:15 AM | #451 |
so.do.they make a 4mm linion Sent from my SPH-D700 using Tapatalk 2 |
07-10-2012, 07:25 AM | #452 |
do.i want my motor spinning at almost 30000rpm or 44000rpm? 30000rpm on 4s with the 2030kv and 44000rpm on 2s with the 5900kv Sent from my SPH-D700 using Tapatalk 2 |
07-10-2012, 08:07 AM | #453 |
should i go with the 5900 and gear down and put a 15t pinion on and then just run one 2s? that would be lighter and easier. i will try drilling a pinion for.the.2030kv but im.not.sure which.motor to.choose. Sent from my SPH-D700 using Tapatalk 2 |
07-10-2012, 09:48 AM | #454 |
got the motor in. the 5900kv with a 15t pinion. tested it in the air sounds good on 2s. looks good. my phone isnt workibg very.good now so i cant upload pictures. Sent from my SPH-D700 using Tapatalk 2 |
07-10-2012, 11:34 AM | #455 |
glad i.choose 5900. it seems it wouldnt be very.quick.with the 2030 Sent from my SPH-D700 using Tapatalk 2 |
07-10-2012, 01:39 PM | #456 |
well with the 2030 you could gear up a little more than with the 5900. even thou there is 14000rpm difference the 2030 is a little more torque motor than the 5900.
07-10-2012, 04:13 PM | #457 |
but the pinion would need tl be.drilled. i will try that later Sent from my SPH-D700 using Tapatalk 2 |
07-10-2012, 04:15 PM | #458 |
what size pinion should i drill for the 2030? i have 13,15,17,19,20,21,23,26,28 Sent from my SPH-D700 using Tapatalk 2 |
07-10-2012, 06:13 PM | #459 |
start with a 19t pinion right now and go from there
07-10-2012, 08:05 PM | #460 |
ill change from the 15.and move to 19. Sent from my SPH-D700 using Tapatalk 2 |
Masonis1's project creeper - Similar Threads | ||||
project creeper | santa cruz crawler | Venom Creeper | 218 | 08-19-2012 09:40 AM |
adale4130's creeper scaler project | adale4130 | Venom Creeper | 13 | 06-19-2010 08:50 AM |
Project C-10 Creeper | brianw | 2.2 Scale Rigs | 0 | 04-08-2010 01:00 PM |
Project Creeper | mastathug0 | Venom Creeper | 13 | 01-16-2010 09:40 PM |
project creeper input wanted | badtodabone | General Crawlers | 16 | 07-30-2004 02:47 PM |
