01-03-2013, 04:43 PM | #101 |
Pebble Pounder Join Date: Mar 2012 Location: Carrollton, IL
| Re: Just got a Venom Creeper (my first rc) and have a little bit of issues
ya i need some stronger drive shafts now
01-11-2013, 09:04 PM | #102 |
Got my rig fixed and ready to go with some different tires thanks to AxialJeepster who sent me driveshafts, axial wraith wheels and ripsaws, a novak m2 dig esc (which hopefully will be put in soon), along with some 1.9 flatirons and some mini beadlocks with no charge what so ever Got the package today thanks to the mailman the new driveshaft in the novak m2 dig esc Ripsaws on venom beadlocks what the truck looks like with ripsaws (which are huge) some metal work I did also some rock slider type things and some bed pieces And thanks again to AxialJeepster |
01-12-2013, 08:35 AM | #103 |
What is the best 2s lipo charger for $20 or less?
01-12-2013, 09:02 AM | #104 |
Newbie Join Date: Jan 2013 Location: Hungary
| Re: Just got a Venom Creeper (my first rc) and have a little bit of issues |
01-14-2013, 01:30 PM | #105 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
wow man that look really nice with the venom wheels and saws the size is perfect i think! that thing should hoss anywhere now oh and some info for you to take in. with those bigger tires now your going to want to keep an eye on your spider gears, they will let go very easily. get the cheap venom lockers if you can or make some... Im sure you will swap everything over to axial down the line. Last edited by AxialJeepster; 01-14-2013 at 01:37 PM. |
01-14-2013, 03:53 PM | #106 |
Woe! Easy on the creeper Ryan! It's the motor that puts power to the spiders you have to worry bout, not what tires are bein used! I do suggest lockers tho.. cheap an easy.. pack em full of mighty putty.. my favorite, Rmdw Lincoln lockers.. I here the venom one work good as well.. No need to switch to axial, anything! Not on a creeper.. |
01-30-2013, 09:02 PM | #107 |
What would be a good complete set of links with a wheelbase of 11-1/2" to 12" and all for around $20-$25?
01-31-2013, 06:40 AM | #108 |
A stick of all thread an length of 1/4" brake line... Cheap, easy, buy at any local hardware store, an make em whatever length ya want.
01-31-2013, 04:27 PM | #109 |
So i've been tinkering with the truck and have been taking it out on a few drives but I've noticed that it kind of gets boring when you are by yourself instead of like crawling or trailing with a friend. So I found a great deal here on rcc for a set of venom axles and venom trans. And hopefully gonna make another scaler for someone to go trailing with me. So far parts list: venom axles venom trans venom 55t fireball motor novak m2 dig esc 1.9 beadlocks with proline flat irons What I need: steering servo (probably another towerpro) links for 4 link ( Like to get some cheap ones for around $20-$25 shocks( some cheap ones also like $15-$20) radio and receiver If anyone has some links aluminum or plastic and wants to get rid of them or sell them for cheap just pm me. |
02-01-2013, 03:50 PM | #110 |
02-01-2013, 05:18 PM | #111 |
Rock Stacker Join Date: Jan 2013 Location: Alva/fort Myers
4-40 threaded rod and tubing that fits over the rod. 3/16 inch tube I believe but it may be 1/4 inch. Also traxxas rod ends will work on the 4-40 rod. Make sure you cut the tubing about 1/2 an inch shorter then the threaded rod so there's room to screw on the rod ends.
02-02-2013, 09:29 PM | #112 | |
02-02-2013, 09:50 PM | #113 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
Shoot me a pm i got like two complete stock creeper shock sets and a bunch of parts for em ill sell cheap
02-08-2013, 09:13 PM | #114 |
Since I've gotten the new axles and trans I have decided to do a new truck What I have: Venom Axles Venom Trans Venom Driveshafts '72 Chevy Body (for now) 1.9 proline flat irons and losi mini wheels custom made scale chassis What I am going to get and still need: wraith shocks homemade links servo tx and rx screw kit for the venom creeper Hopefully getting all this in the next couple of months Low Budget ): |
02-23-2013, 08:36 PM | #115 |
I got some things done on the truck like an interior and a hood scoop. Take a look. I also am starting a new truck if you read the earlier posts and all i am waiting on now is the tx and rx, servo, and the esc and the servo and esc are coming from china so iit will take awhile. Heres the pics Not the best interior or hood scoop but the best I can do at the moment and it works for me |
03-04-2013, 06:43 PM | #116 |
I found out today that in my new axles that I had a bad bearing in the outerside of the steering knuckle and my new truck is almost done just waiting on the esc and a new bearing so if anyone has a bearing for the outside of the steering knuckle ( the smaller bearings) I need one. thanks for looking
03-13-2013, 04:26 PM | #117 |
Newbie Join Date: Mar 2013 Location: Crawfordsville
| Help
I got a venom creeper and it has a 35t integy motor on it . i just bought a 55t novak terra claw to put on it but i cant get the screws on the motor plate to come out and they keep trying to strip out . please help and suggestions ? |
03-13-2013, 05:26 PM | #118 |
| Re: Help There could be lock tite on those screws. You could try fitting a pair of vise grips in the transmission case and see if u can get it out that way otherwise i have never seen this before.
03-13-2013, 06:13 PM | #119 |
i have a ? How much run time would I get with this 2s lipo battery ZIPPY Compact 2700mAh 2S 25C Lipo Pack |
03-30-2013, 08:40 AM | #120 |
What pinion gear should I run with a 15 turn motor and stock creeper gearing? Thanks
Just got a Venom Creeper (my first rc) and have a little bit of issues - Similar Threads | ||||
Venom Creeper Safari Front Driveshaft issues | xxROELKEYxx | Venom Creeper | 24 | 02-05-2012 07:33 AM |
venom torque twist issues | gsmall | Venom Creeper | 6 | 03-19-2011 07:52 PM |
Safari creeper issues | THEDUDE79 | Venom Creeper | 0 | 03-04-2011 07:28 AM |
New Creeper build issues - Not very good QC at Venom... | rwkhaussupply | Venom Creeper | 15 | 01-19-2010 06:56 AM |
Bit confuessed about the creeper. | MATT01234 | Venom Creeper | 4 | 11-06-2009 02:08 PM |
