01-03-2017, 02:53 PM | #201 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
| Re: Scale EB Build
he and his cat are pretty cool, but I was referring to detail. yeah, he may get his done, and yes his builds are stout.. but I don't see him using metal to fab his work with such detail.
01-04-2017, 12:51 AM | #202 |
Rock Crawler Join Date: Oct 2009 Location: Wasilla, Alaska
| Re: Scale EB Build
The K44 and yota axle are different gearing, I was planning on doing that for mine. It would work if the yota was a lower ratio so you could make the front pull. The K44 is closer in size to doing a one ton swap. I just tell myself mine is rolling on 60's lol.
01-13-2017, 10:45 AM | #203 |
RCC Addict Join Date: Apr 2007 Location: Murfreesboro
| Re: Scale EB Build
Wooooow. Ive stepped away for a bit and hopped back on today to see what all everyone has been up to and stumbled into this thread. I cant even add a compliment worthy and have deleted numerous attempts at this post so as not to bring down the value of the thread LOL. PLEASE keep it up and keep us posted, your talent and patience is above and beyond amazing. Matt |
01-14-2017, 05:13 PM | #204 |
Pebble Pounder Join Date: Dec 2015 Location: Essex
| Re: Scale EB Build
Matt, I literally just got done reading through your entire bronco build. I LOVE what you ended up with and thanks for documenting the whole journey for us all to enjoy! Glad you like my build too ;) I had a bunch of questions I planned on asking you about your axle setup and wanted more details on the flip. I am still trying to figure out how to get the correct width for my build as well and figured I was going to have to cut down a set. I love the detailing you gave the yota's to d44ify them. I'll be running the Steel Landie 5 lugs and a set of MT MTZ's. I hope to be able to get them to stuff in the rear wells. P.S. where the heck did you fit the battery? Last edited by 802Bronco; 01-14-2017 at 05:18 PM. |
01-15-2017, 08:50 AM | #205 |
| Re: Scale EB Build
PM sent! Oh, and I found a smaller 2 cell for a smaller scale slash I believe and tucked it under the driver's seat floor pan. It was either that or I was going to run it between the frame under the bed but that was too tight. During long trail rides I stick a bigger 3 cell between the seats and call it good enough Matt Last edited by 66sprint6; 01-15-2017 at 08:59 AM. |
01-15-2017, 11:00 AM | #206 |
| Re: Scale EB Build |
01-15-2017, 11:08 AM | #207 | |
| Re: Scale EB Build Quote:
Guess I need to learn solidworks and buy a 3d printer | |
01-15-2017, 04:36 PM | #208 | |
Newbie Join Date: May 2008 Location: Birmingham, AL
Hey you can just learn solidworks and send the file to shape ways to have printed. Even in metal. Sent from my iPhone using Tapatalk | |
01-15-2017, 05:02 PM | #209 |
| Re: Scale EB Build
I put my battery in the gas tank, seems only right |
01-15-2017, 06:19 PM | #210 |
Rock Stacker Join Date: Jan 2017 Location: Dixie
| Re: Scale EB Build
Great work man. Subscribed. Can't wait to see the more progress and the finished product. I built sliders and body mounts for my hardbody yesterday, nothing compared to what you've done and it was work. I appreciate the time you've put in. Keep up the great work. Logan Sent from my iPhone using Tapatalk |
01-17-2017, 01:03 PM | #211 |
| Re: Scale EB Build
Got a bit more Bits bitten off the to-do list over the weekend. Driver's side quarter panel... Check! Forming block made for the super tricky multi-compound curvy, bendy, how-the-%$@&^%-do-i-make-these bed corners... Check! First test bend with some scrap to see what I was up against. Not as horrible as I thought for the first try. I need to take some better measurements and get the stake pocket figured out as it is part of the bed corner and will require some figurin' to get just right. If it were a full cab, I may have just "accidentally" overlooked it but it's going to show with the half cab soooo... gotta get it right. Also need to make a press stamp for the tail light opening. I may need to press that in first before bending the corner. I think body filler will be my best friend on these ;) The final ones will get hammered on the form a bit cleaner and then silver soldered together before bending in the mounting flanges but this gives you an idea of how it comes together. |
01-17-2017, 10:13 PM | #212 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
| Re: Scale EB Build
Great progress! Yah, those corners are tricky for me and I'm using much softer aluminum. I ended up pre-stretching the metal right at the corner before forming over the mold. Keep it up! |
01-18-2017, 04:34 AM | #213 |
Newbie Join Date: Apr 2016 Location: Chile
| Re: Scale EB Build
Great Work
01-18-2017, 04:41 AM | #214 |
Pebble Pounder Join Date: Jan 2010 Location: Sydney, Australia
| Re: Scale EB Build
Wow, just wow. So keen to see this complete. Well done, mate.
01-25-2017, 06:42 AM | #215 |
| Re: Scale EB Build
Time to bust out some rocker panels. You can get aftermarket repro's that don't have the upturns at the end that meet the door posts but this is a high dollar build so i went for the factory OEM ones with the fancy bends and such So of course that means more forming blanks to build. The step actually curves upward but also narrows where it meets the inner door opening as well as having a second radius where it meets the hump on the door post. Basically another multi-compound bendy bit that needs to have crisp flanges on both sides without tearing the sheet metal. Here it is soldered to the lower rocker panel. Not as clean as i'd hoped but I should be able to tap it into submission once I get it tacked into place. Test Fit... Hmmmm. Still needs some hammer "love" |
01-25-2017, 09:27 PM | #216 |
Pebble Pounder Join Date: Feb 2010 Location: USA
| Re: Scale EB Build
This is just too cool. Great work.
01-26-2017, 04:50 AM | #217 |
Rock Crawler Join Date: Feb 2011 Location: Williston
| Re: Scale EB Build
I have a suggestion for your axles- Shoot me a PM, maybe we can get you some more super scale parts! Supercel isnt far off now! L.R. |
01-26-2017, 06:51 AM | #218 |
01-26-2017, 07:21 AM | #219 |
07-26-2017, 05:00 PM | #220 |
Newbie Join Date: Nov 2013 Location: Smoky Mountains
| Re: Scale EB Build
You didn't give up on this did you?
Scale EB Build - Similar Threads | ||||
~The Scale Shop~ 2008 Scale Nationals Rubicon 2.2 Tuber Build | STANG KILLA SS | 2.2 Scale Rigs | 103 | 12-10-2010 05:49 PM |
