Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: Die-Laughing's 1st Class 2dr JK Build
Old 08-29-2013, 05:06 PM   #1
Default Die-Laughing's 1st Class 2dr JK Build
Well, I'm finally getting around to doing my next proper Class1 build.
It's in the early stages yet.. what better time to start a build thread.
Alright, here's what we're working with..
Placed my order for an RC4WD Gelande II.
Picked up a set of RC4WD K44 Axles & 4link mounts.
Received my 2dr Jeep JK hardbody in the mail today & slapped some 1.7 Iroks under it for pictures..
I don't have any big plans/ideas right now but, they'll come to me. I plan on probably ditching the fenders, doing a roll bar, some body work, paint it a different color, etc. I'd like to think that I can pull off a certain amount of uniqueness with this build even though these bodies might be flooding the BST here in a little while.
Stay tuned!
Die-Laughing is offline   Reply With Quote
Old 08-29-2013, 05:34 PM   #2
Default Re: Die-Laughing's 1st Class 2dr JK Build
Cannot wait to see what gets done with this combo.
Bananaclip is offline   Reply With Quote
Old 08-29-2013, 06:11 PM   #3
You wont need the K44 link mounts. The G2 kit ones will work just fine.
Katan is offline   Reply With Quote
Old 08-29-2013, 08:04 PM   #4
The more that I look at those bodies, the more I want one. So many scale points without any work involved. A minor bit of detailing w/ paint and those interiors will look like a million bucks.
BigSki is offline   Reply With Quote
Old 08-30-2013, 02:59 AM   #5
Rick,
I was thinking the same thing when I saw the jeep body that was floating around at ECSC. Subscribed...
Rckcrwlr is offline   Reply With Quote
Old 08-30-2013, 05:53 PM   #6
Thanks guys. I picked up a set of 1.55 pit bull growlers and a set of gearhead UTE beadlocks.
gonna get started on this thing soon.
Old 08-30-2013, 06:15 PM   #7
Just Amazing Bro........
Now that's what I call Scale
Subscribed
Regards Rick
v84x4 is offline   Reply With Quote
Old 08-31-2013, 01:45 PM   #8
Gelande II, K44, BTA Steering, Panhard bar.. Hell yes!
Old 08-31-2013, 02:07 PM   #9
Damnit.. I was so excited to have BTA steering but, I forgot theres nowhere for the drag link to hook to!!
RC4WD! I need a new K44 knuckle with ears coming off front & rear!
Old 08-31-2013, 03:21 PM   #10
Well, here's the problem.
I need this rod end to hook to the front of this knuckle.
I guess I have to make an arm. I decided to do something along the lines of how those red vp wraith arms bolt to the knuckle so, First step is to drill & tap the knuckle.
Then I found a piece of material.. Which was a axle servo mount for an scx10. I drew up the shape I wanted. Ended up using an existing hole and adding a hole.
Bam! Got it shaped out, countersunk the holes, drilled & tapped the outer hole and done.
That should work.
I wasn't going to let this thing beat me! I needed K44's & BTA setup! Needed it!
Old 08-31-2013, 03:54 PM   #11
Haha "needed it"
I like this build.
Mega Fattie is offline   Reply With Quote
Old 08-31-2013, 07:04 PM   #12
Why did you change out the axles. Not scale on a jeep?
sally1800 is offline   Reply With Quote
Old 08-31-2013, 08:05 PM   #13
Yeah, they just fit the build better.
Ok.. If this ain't some gangsta shit.. I don't know what is.
All my C1 trucks has been leaf sprung until this one. I must say, this is a pretty sweet setup for a C1.
Old 08-31-2013, 08:18 PM   #14
Oh no! it got run over by the lawn mower!
I feel like thats how my stuff looks after I hack it off with my technique. Compared to those of you that are using thread to cut plastic and it looks nice & clean. I used a cut off wheel and then a bench grinder and then a file. It actually doesn't take very long to get it finished up pretty nice. I'm not familiar with how long the thread technique takes.
Well, here's what we're dealing with so far. I got it in the stance I like and the floor boards are sitting against the chassis. To get it a little lower I'll be running a mostly droop setup. I had to ditch the rear shock towers and get creative with my rear shock mounting. I think it worked out ok. other than the exterior body chopping I did, I only had to modify the floor board a little bit at the feet of the rear passengers to fit the rail in there better..no biggie. I'll be running poison spyder flares.
I'm really diggin' this RC4WD Gelande II.. It's a really nice kit. I expected that after the success of the TF2. I really liked owning that one as well.
I'm going to do the tube bumpers & sliders on this one.. I'm excited for that. I might do a quick roll bar as well.
Old 08-31-2013, 10:16 PM   #15
Daily driver, and trail rig.
Make a scale garage for pics!
Old 09-01-2013, 10:45 AM   #16
Wild trial's Avatar
Love the 2 door JK!!!
Wild trial is offline   Reply With Quote
Old 09-01-2013, 10:49 AM   #17
There is 2 problem in your config....
1st the arm you made is too short, in my opinion and you will loose steering angle, that's why you needed to put a big spacer between the rod end on drag link.
A longer arm make the right distance to have clearance from the axle bow, and keep the maximum steering angle.
2nd the bta in the narrow axles like d35 k44 and so on are difficult to make if you are seArching the max performance for comp because the body of the tierod rod ends touch the ammo before reaching the maximum angle...
By the way nice project but pls change the wheels with the right 1,7 one
Tread Subscribed!
seychelles is offline   Reply With Quote
Old 09-02-2013, 07:01 AM   #18
Rick, build is looking fantastic. You had to go with the K-44's huh? I love those damn axles! Oh...........................I would consider this rig GANGSTA.
Old 09-02-2013, 10:12 AM   #19
Looking good man
2.slowduo is offline   Reply With Quote
Old 09-02-2013, 12:16 PM   #20
Thanks guys!
1.7 Iroks VS. 1.55 Growlers, that is the question.
Iroks:
Outer Diameter: 4.18"
Width: 1.6"
Inner Diameter: 1.7"
Advanced X3 Soft & Sticky Compound
Growlers:
Outer Diameter: 4.19"
Width: 1.43"
Inner Diameter: 1.9"
Komp Kompound
The Growlers have the better compound but also have an "all-terrain" tight lug pattern. New & cool tire. Must use 1.55 wheels.
The Iroks are meatier looking and wider with an aggressive tread pattern. Can use 1.7 or 1.9 beadlocks.
Hmm. I already have the 1.7 Iroks and I already have the growlers and some cool 1.55 gearhead beadlocks on the way but, If I use the iroks I can get the even cooler 1.9 Gearhead beadlocks I want with IMO a better looking tire.
Performance. The growler is a better compound, the irok is more aggressive & wider. I think they'd be very comparable in performance.
What do you guys think?
Die-Laughing's 1st Class 2dr JK Build - Similar Threads
Die-Laughing's Monster Truck.. Die-Laughing Axial Wraith 16 02-06-2013 06:27 PM
Die-Laughing's BadAss FJ Die-Laughing 1.9 Scale Rigs 89 09-28-2012 01:59 PM
Die-laughing's FJ40 TF2! Die-Laughing 1.5 Scale Rigs 62 08-21-2012 08:08 PM
NIRC Polar Series Die-Laughing's Class 2 run johnnyh66 Scale Videos! 4 03-28-2012 09:30 PM
Die-Laughing's Wrecktuber Die-Laughing 2.2 Scale Rigs 78 02-26-2012 09:54 PM
