10-24-2017, 08:51 PM | #61 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS
I love this build, skimmed it once or twice before and now it’s really coming along. I like the D rings. Not sure about a winch on a mudder like this, at least not an exposed one on the bumper. The “snatch strap” looped on the rings or even some hooks would suit it nice. But of course it’s your truck, just thought I’d share. Watching this one for sure, already gave me some great ideas and how-to. |
10-25-2017, 09:22 AM | #62 | |
Quarry Creeper Join Date: Nov 2015 Location: Walkerton
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS Quote:
If I can ever afford it I'm gonna get it. That winch would b a perfect fit on Bruticus. I also found it at my job.... The perfect scale chain. Planning on getting some hooks for each end. That's gonna be my "snatch strap". Sent from my VS995 using Tapatalk | |
11-11-2017, 11:26 PM | #63 |
Something I always wanted to try but was hesitant. Metal work. Had some 1/2 inch brass tube laying around so I pulled out my torch and start bending. After a few minutes I had some new frame rails. Also soldered on the front leaf shackle mounts. First time attempting soldering and it's harder then I imagined so it looks rough but it's strong. Now I have to get the dremel and a cut off wheel to split it in half to create the rails. Sent from my VS995 using Tapatalk |
11-12-2017, 09:30 AM | #64 |
Got to do a little more work on the chassis this morning. Got the rear leaf spring mounts soldered on and the frame rails cut in two. Decided to mount the suspension and put the cab before on before I go any further to see if I like the look of it. I not only like it I LOVE it. Still have to figure out how to mount the other shackles to the frame. Time for brainstorming. Tell me what you think. Til next time Thanks for looking. Sent from my VS995 using Tapatalk |
11-12-2017, 10:22 AM | #65 | |
Pebble Pounder Join Date: Feb 2015 Location: Kansas city
Might need to look into a set of these wheels for mine. Look pretty good with the rock stompers. Are they beadlock? Mine will never be completely done haha. Keep going dude. Be pretty badass someday when it's finished, or atleast moving haha. | |
11-12-2017, 10:45 AM | #66 | |
11-12-2017, 03:29 PM | #67 |
Looks good Rick, might need a few extra crossmembers in there to keep the frame from twisting, but other than that |
11-13-2017, 01:01 AM | #68 |
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS |
11-18-2017, 02:04 AM | #69 |
Back again doing more work on this piece of junk lol. Soldering is tedious but fun once you get the hang of it. I was having a hard time with my parts not staying together until I realized I was using TOO much heat. I used the trail finder 2 servo crossmember to mount the servo. Also switch the servo around so the servo arm will be on the drivers side with the steering link going to the passenger side like it should. Soldered on the leaf spring mounts. Then realized I miscalculated and the rear shackle mounts were back too far. There was no articulation in the rear. Installed new mounts to solve this problem. Now I can adjust it so if I'm pulling or carrying a heavy load, I can make the leaf springs stiff for less sag. Got one rear crossmember soldered in. Finally the part that gave me the most headache and joy. The transfer case crossmember. Figuring out how to design this part took a while. Then I remembered I had a roll of brake line laying around. I used a paperclip to make a rough template of the crossmember. After a lot of bending, test fitting, and soldering I had it finished. Now all I have to do is drill the holes to mount the transfer case. As you can see I got great ground clearance. The transfer case barely shows below the frame. So this is where my hunk of junk sits right now. Don't look like much is done but it's major progress to me being this is my first time trying all this. Lots more to do but that's for another time. Until then thanks for looking. Sent from my VS995 using Tapatalk |
12-04-2017, 01:44 AM | #70 |
Started scratch building another Cummins engine. This one is going to hold the motor and planetary gearbox inside. Sent from my VS995 using Tapatalk |
12-05-2017, 03:07 PM | #71 |
Progress on the Cummins. Worked on the front section (made it removable), intake and exhaust manifold, and the valve covers. Very tedious work but loved every second. Still got a lot to do to the engine and then after that the big step..... A scratch built transmission! Sent from my VS995 using Tapatalk |
12-05-2017, 03:07 PM | #72 |
Mocked Sent from my VS995 using Tapatalk |
12-06-2017, 11:53 AM | #73 |
Awesome build, the engine is going to look spectacular |
12-08-2017, 02:31 AM | #74 |
Cummins progress. Worked on the diesel fuel pump (aka p-pump), fuel lines, and the little nuts and bolts detail. If I knew scratch building was this fun I would have been doing it a long time ago. Still have to build the intake tubes, exhaust manifold tubes and turbo. But that's for another time. My hands are tired lol.Thanks for looking. Sent from my VS995 using Tapatalk Last edited by Rickleo; 12-08-2017 at 02:42 AM. |
12-08-2017, 07:24 AM | #75 | |
Quarry Creeper Join Date: Apr 2012 Location: Harrisburg
Sent from my HTC Desire 626 using Tapatalk | |
12-08-2017, 08:17 AM | #76 |
That looks really good!
12-08-2017, 08:30 AM | #77 | |
12-08-2017, 08:37 AM | #78 |
12-08-2017, 01:51 PM | #79 |
Cummins progress. Exhaust headers, turbo, and intake tube installed. Sent from my VS995 using Tapatalk |
12-08-2017, 04:18 PM | #80 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Very nice work, that's a lot of awesome detail! |
Rickleo's Chevy Crew Cab Dually: BRUTICUS - Similar Threads | ||||
K30 Chevy Crew Cab Dually Wrecker by Trailworx Garage | H2Micr0 | 1.5 Scale Rigs | 24 | 02-19-2017 08:47 PM |
chevy crew cab dually | S10XtremeSR | Micro Scale Rigs | 4 | 03-22-2015 05:18 PM |
Chevy Crew Cab Dually | makaveliks | 1.9 Scale Rigs | 222 | 11-17-2014 08:32 AM |
