12-16-2012, 01:47 PM | #601 |
Newbie Join Date: Apr 2012 Location: van wert county
| Re: Project true scale - Aluminum Toyota body!
I just read every page, and was looking forward to see'ing the completed truck! Everything in this build is awesome.
01-02-2013, 01:01 AM | #602 |
Rock Stacker Join Date: Aug 2010 Location: nanoose bay, bc, canada
well not a single update for this build in 2012........i hate it when life gets in the way of projects lol. awesome work on this truck, after taking this long to complete i would think this thing would put put under glass and out on display inside a coffee table or trophy case! hopefully you get the time to finish it this year ;)
03-06-2013, 09:43 PM | #603 |
Quarry Creeper Join Date: Mar 2009 Location: Central WA
Cant wait for more updates! I tell all my friends about this thread.
03-07-2013, 12:11 PM | #604 |
Newbie Join Date: Feb 2013 Location: Pomona
Oh fargh! I just read 31 pages just to find out i have to wait longer! fargh! I know you have heard it a million times over but, I will say it one more friggin time. AMAZING SCALE BUILD! |
03-28-2013, 08:28 AM | #605 |
Newbie Join Date: Oct 2012 Location: Malaysia
Simply an amazing work of art.... Your attention to detail is simply amazing!
03-29-2013, 04:30 AM | #606 |
Rock Crawler Join Date: Jul 2005 Location: MD
Search for his other builds to get that final product high. Sent from my iPhone using misspellings due to fat fingers |
04-29-2013, 06:06 PM | #607 |
Newbie Join Date: Apr 2013 Location: Near Flat Rock
I'm new to the forum here and I just got back into rc after being out for the last twenty years. I wanted to do a metal bodied 79 Ford but then i saw this build lol. Now i really need to step up my game. Great build. I can't wait to see it take some hits on the rocks to give it character.
04-29-2013, 07:40 PM | #608 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
^^ i've started on a chassis a couple years ago and was planning to build molds and stuff of a 79 ford f150 and shape body panels like metal masher does.. i know it'll be a lot of work but should be worth it. i'll get back to it eventually had some stuff come up that takes prority |
05-30-2013, 10:38 PM | #609 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
Ok guys it's finally that time! yes i'm going back onto this build! My other obligations are starting to wrap up and i recently got some inspiration from a good fried of mine the helped me out with the front axle. A little recap, the front axle is a hybrid of original Bruiser and Axial parts with custom adapters made by Rob. The axle worked great but the problem was the pinion. pointing strait back i kept busting shafts when the suspension droops out. i filed the perches to turn the pinion up but if course now the caster was way off. I decided i needed a way to adjust the caster and devised a plan to make new C's that would allow my knuckles to rotate on the axle. Here is the design i made And here is the motivation. A package from Rob The workmanship is outstanding! Now It takes some commitment to use them as it's necessary to remove the last remaining ears on the end of the axle. Rob cleaned up the ends and matched the C to the axle the fit is spot on Now i am able to put the caster exactly where i want The next step is to install some threaded inserts. I looked at buying a kit but the $60 plus price tag kept me away. Then when i found out i could buy just the tap for $15 i devised a way to install them by using an old broken Allen wrench A simple slot in the end and i'm in business the knuckle test fitted and on the axle i still have gobs of steering I don't have the correct set screws yet so i threw a cap screw in and mounted the axle under the truck. the other bonus with this set-up in the ability to locate the tie rod over the springs for more clearance. Here is how it works. fully extended the pinion is just above horizontal. there is lots of caster but the steering won't bind At full compression the knuckle is just at vertical And at ride height the caster and pinion are right about where i want them The only wheels and tires i had were some small MTZ's but it let me take a look at the stance The obligatory flex shot and just for fun threw the body on Yep! That's all for now but i hope to show more progress now that i have some motivation! |
05-31-2013, 02:05 AM | #610 |
Would a set of high steer knuckles help with the caster? Like these http://www.vanquishproducts.com/vp-h...ackermann.html It's good to see your back on it! Rob, you sir are a awesome machinist! |
05-31-2013, 02:05 AM | #611 |
05-31-2013, 11:17 AM | #612 |
Rock Crawler Join Date: Apr 2005 Location: Upland
I just got butterflies in my stomach! I'm glad to see you haven't given up on this project. You've motivated me to finish up my build. Time to head out to the garage and get my hands dirty!
06-01-2013, 06:43 AM | #613 |
Quarry Creeper Join Date: Apr 2010 Location: Wagga Wagga Australia
It's so great to see some progress man it's looking .....well like a 1.1 hilux of course ...Just totally awesome man...... |
06-01-2013, 09:26 AM | #614 |
Quarry Creeper Join Date: Feb 2008 Location: chico
I have a reason to wake up again |
06-04-2013, 06:24 PM | #615 |
Rock Stacker Join Date: Feb 2011 Location: Los Angeles
Holy cow! On behalf of everyone on here, we can't wait to see this thing completed. I wish I could shrink myself just so I could get in this thing and drive it.
07-29-2013, 01:21 PM | #616 |
Newbie Join Date: Feb 2013 Location: Oshkosh
Awesome built you sir inspired me to build a metal body Jeep MJ. I would like to know what you use to make the grill and lenses?
07-29-2013, 01:41 PM | #617 |
Dude that steering set up is SWEET! Those make the Rummy Cs look Stone Age keep up the good work !
07-29-2013, 07:19 PM | #618 | |
| Re: Project true scale - Aluminum Toyota body! Quote:
I like the design better than the rummy C's as well but it does take commitment to perform the mod since you are cutting off the remaining ears that hold the axle halves together. I won't have time to test it before the Scale challenge so hopefully they hold up I wish i would have come up with the design years ago when everyone was modding these axles. I probibly could have made some money. | |
07-31-2013, 12:40 AM | #619 |
Pebble Pounder Join Date: Jul 2009 Location: Australia
Best thread in the world.
07-31-2013, 10:24 PM | #620 |
Newbie Join Date: Jul 2013 Location: Seattle
What did you shape the fenders on?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/147988-project-true-scale-aluminum-toyota-body.html | ||||
Кузова,все о них и для них - Страница 5 | This thread | Refback | 10-05-2011 08:25 PM | |
Wow, Amazing Scale RC Toyota - Tacoma World Forums | This thread | Refback | 10-04-2011 06:14 PM |
