11-07-2011, 09:42 PM | #261 |
RCC Addict Join Date: Aug 2010 Location: wherever paypal sais.
so i had this crazy idea for the easiest, most rediculiously amazing max shaft mod. mostly cause im sick and tired of the sloppyness that mip's develop. and that they weight a ton. so bought a set of max shafts and they came in today. stay tuned to see how amazing this mod is gonna be. its so simple its rediculious. ive seen some of the mods people do and it just doesnt seem worth it. with my design you DO NOT have to mod the 5mm output shaft. or the 6mm yoke.... all im doing is having a sleeve machined with a 5mm inner and 6mm outter diamater with a hole drilled in it so the set screw can pass through and clamp on the existing output. while the sleeve centers the drive shaft on the output shaft. i will do this for both the axle and trans side so i dont have to mix match yokes n such. and do all them rediculious mods. now thats max shafts made easy!! ill post pics of the install process when i get them. Last edited by kaneohecrawler; 11-07-2011 at 09:47 PM. |
11-07-2011, 10:37 PM | #262 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
Now that's thinking with your dipstick Jimmy! |
11-08-2011, 07:28 AM | #263 |
Quarry Creeper Join Date: Oct 2009 Location: melbourne, australia
nice jeep you got here man. i may have missed it but where is your battery mounted? any chance of some pics showing how your electronics and battery are mounted?
11-08-2011, 10:47 AM | #264 |
Quarry Creeper Join Date: Mar 2007 Location: Sneads Ferry
11-08-2011, 12:33 PM | #265 |
11-08-2011, 12:36 PM | #266 | |
my electronics setup. finally got the clutter under control. for a nice low cg. and a front weight bias inside is mmp esc receiver servo battery winch controller cc bec .... a whole lot packed into not much lol.. i swear its all in there if i had the center skid mounted on main chassis rail every thing would be below the spur gear. but i dropped it 1/2" so you can see how low everything is Last edited by kaneohecrawler; 11-08-2011 at 03:08 PM. | |
11-08-2011, 07:42 PM | #267 |
How're you liking that MMP? I thought you were having issues with it last time we spoke? Digging the aluminum inner wells man, looking real nice.
11-08-2011, 10:19 PM | #268 | |
Yah I made those up and they turned out pretty good. The pics are froma while back but the one guys asked for em n I knew I had em stashed somewhere on here. But its all still the same. Gonna take a chapter out of your book and make the change to flat fenders as soon as I get back home. I got it all planned out its gonna be sweet. | |
11-08-2011, 10:57 PM | #269 |
You really shoe horned the crap out of that engine compartment! Nice job! Let us know how you get the 5/6 mm sleeve for the drive shafts figured out. It would be nice to find something off the shelf (from somewhere) that a dremel could cut to size.
11-08-2011, 11:16 PM | #270 |
| Keep a look out in the vendor section. They are being made of stainless as we speak. |
11-08-2011, 11:28 PM | #271 |
thanks for posting those pics. you sure do have a lot crammed in there
11-08-2011, 11:39 PM | #272 |
11-09-2011, 11:52 PM | #273 |
11-12-2011, 05:09 PM | #274 |
so i got a new winch on order just waiting for it to come in it has a 7lb dead lift capability and its all metal. with integrated fairlead on the base plate. and it has free-spool action! and was curious as to how tall my truck was in relation to width. so i run sprung and but the shocks droop a bit in the front and the rear is pretty much full sprung w/ maybe 1/2 of drop while its sitting rig comes in at under 8 1/2" if i run my mayhem monsters with the .750 hubs in G6 mode my rig is 10.5" wide if im running in C2 mode its only 9.5 wide outside to outside of front tires. it def helps out that im wider than i am tall. really helps me keep the tires planted to the ground. Last edited by kaneohecrawler; 11-12-2011 at 06:30 PM. |
11-12-2011, 06:37 PM | #275 |
Chassis & Tubework Vendor Join Date: May 2006 Location: Portland, OR
Sweet winch! I'm waiting to see your new drive-shaft setup |
11-12-2011, 06:42 PM | #276 |
| ha ha me too! my maxx shafts are home in hawaii and i just sent my rig back there too. as soon as highlandcrawler has the sleeves made and sent my way ill be sure to post pics of the install process. only issue is i wont be back in hawaii till dec. 10th ish.... i miss my truck already |
11-12-2011, 06:45 PM | #277 |
RCC Addict Join Date: Mar 2009 Location: hawaii
What kind of winch is that?
11-12-2011, 06:46 PM | #278 |
11-12-2011, 06:50 PM | #279 |
Nice setup!! Pretty costly though lol def looks good
11-12-2011, 10:19 PM | #280 |
Pebble Pounder Join Date: Feb 2008 Location: 808
Nice and neat electronic birdnest you have there. So thats why you said your winch was up for grabs. Looking good bro!!
KC's C2/G6 TJ BUILD... - Similar Threads | ||||
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
KC's commemorative build (ACTION PICS!) | kaneohecrawler | 1.9 Scale Rigs | 87 | 07-31-2012 12:16 AM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RC ADVENTURES - KC's BEETLE JUICE V3 Enroute Berg Crawler | RCSPARKS | Videos! | 7 | 06-16-2010 12:30 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
