05-06-2011, 09:43 PM | #121 |
RCC Addict Join Date: Mar 2009 Location: hawaii
I'm gonna try. I've still got a few things to do to finish my truck and I'm doin a full make over on my brothers f350. I'm gonna bust my ass tryna get it all done.
05-06-2011, 09:57 PM | #122 |
RCC Addict Join Date: Aug 2010 Location: wherever paypal sais.
| i seen that was wonderin if you were tryin to get it done for the event hows the rebuild comin?... but thats also why were planning it a month in advance so everyone can have there rigs ready and not break in the first five mins on the trail |
05-06-2011, 10:56 PM | #123 |
got the tekin fxr with 35t tekin pro motor all runnin on 3s all hooked up.. and wow thing has some pretty decent wheel speed im def happy with it and was able to rearange some things electronics wise and made it to where i was able to mount the batt down lower... yay i love the LCG on this thing... thats really all for now gonna take her out on maiden voyage this weekend to give her a whirl but after that no more till scale day dont wanna break anything... for funding reasaons or lack there of...
05-06-2011, 11:02 PM | #124 | ||
05-07-2011, 12:09 AM | #125 |
Quarry Creeper Join Date: Mar 2007 Location: Sneads Ferry
I didn't notice you painted your shock hoops black, why'd you do that?
05-07-2011, 12:45 AM | #126 |
i didn paint them. Its the original powdercoat. He used a soft paint and it peeled right off w/ out effort, so gonna light sand, primer, and use some metallic silver with clear coat to try and see if that works better.
05-16-2011, 02:00 AM | #127 |
05-16-2011, 05:25 AM | #128 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
Very nice work mang......looks spot on!! Question for you on F shocks...did you get the soft set of springs with that delrin slider? If so how much softer are they then stock?. I am using the same shocks on my build and the stock springs are stiff as hell. Have been searching and playing around with different springs trying to get the ride height where I want it. thx |
05-16-2011, 05:42 PM | #129 |
Quarry Creeper Join Date: May 2010 Location: Kaena Point, Hawaii
nice vid, cant wait to run mine |
05-16-2011, 05:47 PM | #130 |
05-16-2011, 05:50 PM | #131 |
Rock Stacker Join Date: May 2011 Location: RC room
wow..this is a scaler btw, what kinds of foam u use now? |
05-16-2011, 07:27 PM | #132 |
05-16-2011, 07:45 PM | #133 |
Knowing this guy, he's probably running expandable foam that comes in a can from the Home Depot. |
05-16-2011, 09:54 PM | #134 |
05-16-2011, 09:55 PM | #135 | |
05-16-2011, 11:30 PM | #136 |
I wanna be Dave Join Date: Oct 2007 Location: 801
ive read this build thread a couple times now! this rig is SICK!!!!!!! great work!!! now you must tell me, how is your cage mounted to the rig?? i thought it was brazed to the frame, but i just noticed that this is probably not true!! i'm about to start my TJ build, and would love to know your secret! thanks! |
05-16-2011, 11:40 PM | #137 | |
So what i did was on the front where the origional cage mounted i filled that area in with styrene fill peices.. put a lower styrene plate on the underneath side. and drill a hole big enough for a bolt in the back just drilled a hole in the 2 back corners where the tube meets the body on the front and rear down tubes i tapped the tube to 6/32 thread then just put the screws throught the body and into the tube and bam interchangable cages! the center down tubes slide into the body between the door and door panel so hidden from view but look built in... rear front Last edited by kaneohecrawler; 05-16-2011 at 11:51 PM. | |
05-16-2011, 11:53 PM | #138 |
05-17-2011, 12:00 AM | #139 |
Rock Stacker Join Date: Mar 2006 Location: Las Vegas
05-17-2011, 12:05 AM | #140 |
KC's C2/G6 TJ BUILD... - Similar Threads | ||||
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
KC's commemorative build (ACTION PICS!) | kaneohecrawler | 1.9 Scale Rigs | 87 | 07-31-2012 12:16 AM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RC ADVENTURES - KC's BEETLE JUICE V3 Enroute Berg Crawler | RCSPARKS | Videos! | 7 | 06-16-2010 12:30 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
