05-10-2016, 09:37 AM | #141 | |
Quarry Creeper Join Date: Dec 2012 Location: Remember, wherever you go. There you are.
| Re: Poprivet's first full tuber named U.N.C.L.E. Quote:
I will try to find the closest silver I can find for the cage, and probably a gunmetal for the panels. We'll see. | |
05-10-2016, 09:41 AM | #142 | |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
You would have to be pro to make those tiny tig welds.. | |
05-10-2016, 10:32 AM | #143 |
| Re: Poprivet's first full tuber named U.N.C.L.E. |
05-15-2016, 02:25 PM | #144 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
05-15-2016, 02:30 PM | #145 |
| Re: Poprivet's first full tuber named U.N.C.L.E. Nice try. I'm not falling for that one. You need to put that on a trailer behind your new blazer.
05-15-2016, 02:56 PM | #146 |
05-15-2016, 06:28 PM | #147 |
Quarry Creeper Join Date: Dec 2014 Location: Goat farm
i do have a real 1;1 harly ill trade you. HEHEHEHE better becarefull what you ask for. you just might get it.
05-15-2016, 06:29 PM | #148 |
05-16-2016, 02:59 PM | #149 |
Rock Stacker Join Date: Apr 2016 Location: Meriden, CT
Just read through this entire thread, and I mist say, inspiring stuff. I also loved the movie and the 1:1 and your attention to detail and abilities have captured it fantastically. Keep up the good work, I cannot wait to see it completed |
05-16-2016, 03:10 PM | #150 | |
Thank you so much. I did make a little progress this weekend. I will try and post pics later. I have all the body panels mounted, and my own twist on a sway bar. | |
05-16-2016, 09:36 PM | #151 |
Oh yeah and a dash to cover the gap between the spawn interior and the cage. 24 gauge, cut with snips, flattened with a body hammer, and bent with hand seamers. I am a union sheet metal worker after all. And body panels. I drilled and tapped the tube where I could or had to, and made little tabs from 1/8" flat stock. Cut about 5mmx7mm on my bandsaw, then drilled and tapped 2mm. I wanted the screws to be as small as possible. I did strip one of the holes i put in the tubing, but a quik plug with some 56%, and a re-drill and tap later, and it's good to go. Then the sway bar idea. I couldn't think of a good way to mount a traditional torsion style sway bar, so I used one from my touring car. It's kind of stealthy I think. To make the mounts I cut two equal sized pieces of 1/8" and clamped them in some vice grips. Then drilled through both on one end and countersunk the top one then turned it on its side, and drilled a hole in between the two pieces to make like a clamp. Then separate them, and drilled the top one out to 1/8" for 3mm, and tapped the bottom one for 3mm. Then just brazed the bottom pieces in place. Now i think I'm really ready for final blast and paint, but I will probably stare at it for two more days trying to think of what I missed. That will give me time to get more sand and some paint. |
05-17-2016, 08:13 AM | #152 |
| Re: Poprivet's first full tuber named U.N.C.L.E. Quote: Is that sway bar going to be stiff enough to keep everything stable? |
05-17-2016, 08:20 AM | #153 |
No it isn't. But that is the softest of 3 sway bars that come in the tc4 sway bar kit. So I can go stiffer if I need to. I really don't think It needs a sway bar for the work I plan to do with it. It won't see a race track until I build one. It was just something I wanted to add before paint. Per the advice of my good friend Ernie. Last edited by Poprivet; 05-23-2016 at 07:43 PM. |
05-17-2016, 08:21 AM | #154 | |
Ahhhh I see. | |
05-19-2016, 11:22 AM | #155 |
Just wait till Poprivit post picks of the fair lead he fabed up. I think it cleans up the grill and does a lot to hide the stearing servo. Set it in place and see what everyone else thinks. ! And tell the boss lady I'm sorry for taking up your and her time again this week |
05-19-2016, 12:20 PM | #156 | |
Your trail finder will be wired and ready within a couple hours after I get home. | |
05-19-2016, 01:36 PM | #157 |
I forgot to leave you any servo horns!! I'd much rather have you work on uncle. I want to see that bad boy at Disney rc4wd! But thanks again for the three and a half hours you spent on my truck last night. I need to make you a shop hourly rate sign! I didn't spoil nothing I just ......... Ok maybe I did sory
05-19-2016, 01:48 PM | #158 | |
I thought all I was doing was Wiring? The rest has to be on you man. I have too much work to do. And as for the hourly rate...three and a half hours to do one and a half hours of work. I'm not sure how to charge for my chaotic methods. | |
05-19-2016, 02:05 PM | #159 | |
Ernie, Oh and the doc did say he wanted me up and moving around, so I was at the end of a little walk. | |
05-19-2016, 03:17 PM | #160 | |
I'm glad to hear your up and around though. | |
Poprivet's first full tuber named U.N.C.L.E. - Similar Threads | ||||
SUPER TUBER NAMED TSR-"tequila sun rise" | AxialJeepster | 1.9 Scale Rigs | 15 | 07-22-2012 08:12 PM |
Full Skin Tuber? | Double J | Chit Chat | 9 | 11-22-2006 02:45 PM |
4 link turned into FULL TUBER | dhoffroad | General Crawlers | 5 | 03-04-2006 04:59 PM |
