Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: MaX-D's Wroncho Build
Old 10-20-2020, 07:56 AM   #41
Slow is the new Fast
smog's Avatar
Default Re: MaX-D's Wroncho Build
It’s coming along nicely. While not ideal, I don’t expect out-mounting the shock should necessarily be an issue. I (and many others)have done it on an Ascender without fail. I gather your Wroncho is gonna is push some decent speeds so that mount may see a little more stress. Personally I wouldn’t worry about it.
Enjoying the thread!
smog is offline   Reply With Quote
Old 10-20-2020, 08:34 AM   #42
Thanks smog. I'm building this to primarily be a crawler, but if it does need to see a little speed, I want to have those bases covered. The last thing I wanted to do was out Mount the shocks, but had no choice. Oh well, if something breaks I'll just fix it.
Sent from my LM-G710VM using Tapatalk
MaX-D is offline   Reply With Quote
Old 10-20-2020, 08:37 AM   #43
Does anyone have any idea on what is the best way to put some weight on the front end of this thing.? I'm putting the battery tray right behind the front shock Towers like the Element Enduros, but I know from when the truck was a Wraith it needed more weight up front.
Old 10-20-2020, 08:46 AM   #44
I use wheel weights. I run ssd wheels with vanquish hubs and brass weights. My battery is also mounted just behind the front shock towers.
Sent from my SM-G965U using Tapatalk
andrewjurena83 is offline   Reply With Quote
Old 10-20-2020, 04:55 PM   #45
Getting closer. Will be putting the tranny back together tonight, and replacing all the bearings.
Old 10-20-2020, 06:11 PM   #46
smog's Avatar
Brass steering knuckles and/or c-hubs are a really nice way to add unsprung/non rotating weight down low and in the front corners. Not sure who makes them for the AR60 axles( I think you are using these) Would have to look into that.
Old 10-20-2020, 08:38 PM   #47
Yes, I am using AR60 axles. I would prefer brass knuckles or c-hubs. I don't know who makes them either. My next research project I reckon.
Old 10-21-2020, 12:53 AM   #48
XtraSpeed makes "steel" (they're really just potmetal) AR60 axle housings that weigh 5oz, XtraSpeed, Beeftubes, Boom Racing, etc also make stainless steel axle tubes (can fit inside of the "steel" housings) that add 2oz. Locked UP rc makes a heavyweight spool that weighs 2oz. Beeftubes has a brass diff cover that weighs 2oz. Dlux can build you knuckles that weigh 10+oz. There are also no-name Chinese brass knuckles that weigh about 9oz. My front AR60 on my Wraith weighs in the neighborhood of 2lbs. How heavy do you want to be? The parts are definitely out there.
Here's some links: https://www.ebay.com/itm/2PCS-Intern...EAAOSwfVhaMXWH
https://www.ebay.com/itm/Xtra-Steel-...YAAOSwBxpfiXcu
https://www.ebay.com/itm/Axial-Wrait...cAAOSwNJxeb5nt
https://www.rpphobby.com/product_p/bt004dcb.htm
https://www.rpphobby.com/product_p/loc0821-hw.htm
https://dluxfab.com/Knuckles-Dlux-p83364230
TheLetterJ is offline   Reply With Quote
Old 10-21-2020, 08:46 AM   #49
WOW! Thanks for doing the research for me. This definitely gives me a lot to go on. I have no idea how heavy I want the front end to be.
Old 10-21-2020, 09:30 AM   #50
What is everything that you have on the front of your Wraith that adds 2 lb of weight?
Old 10-21-2020, 10:44 AM   #51
I have a steel housing, stainless steel inner axle tubes, VP clamping c-hubs, VP knuckles, VP brass knuckle weights, 2 per side: Dlux add-on brass rings (these aren't meant to fit the VP weights, but I made them work), LURC heavyweight FI spool, Axial hardened steel ring & pinion, Dlux U4 axle truss/servo mount, Savox 2290sg servo (mounted behind the front axle), stainless steel tie rod, Axial universal joint axles, 10mm wide clamping wheel hexes, some random aluminum diff cover, diff packed FULL of grease, and probably some other junk I'm forgetting. It all adds up!
That's not necessarily 2lbs MORE than a stock axle assembly, but 2lbs(ish... it might have actually been a little heavier) total axle weight. That's easily more than a full pound over stock, and my wallet is much lighter too! With that amount of weight down low, out front, it never leaves me wanting more even on an 8lb car. Besides, it's cheaper/easier to lose weight from the rear and/or from up high now than it would be to try to figure out how to add weight out front/down low. All else equal, a lighter car generally performs better.
Old 10-22-2020, 09:14 PM   #52
Ever since I put the metal tranny gears in it feels knotchy, not smooth. I tried just about everything to fix it and came up empty. I put the plastic gears back in, smooth as butter. The plastic gears have lasted this long (6 years) with zero wear, they're staying for now.
I've also decided that I'm going to keep the Robinson Racing metal spur. The slipper pad hardly looks worn and it's thick as hell. I'm hoping to have it running by the end of the weekend.
Then I'll need to figure out a paint scheme for the Honcho body and how much, or little of the rear cage I actually want to use. I'll either use part of the Honcho cage, or hack up my leftover Wraith cage.
I'm also trying to decide if I want 4 wheel steer or not. From threads that I've read, guys with 4ws more often than not end up taking it off. I'm on the fence. Any thoughts on this?
Old 10-23-2020, 01:56 AM   #53
Unless you're in it for the novelty, I'd skip 4ws. If you want to turn sharper, dig will do a much better job of it than 4ws. OD/UD and some minor steering mods on the front axle can cut a pretty tight turn without dig or 4ws.
Old 10-24-2020, 11:06 PM   #54
I'm going to skip 4ws. I've always thought dig was cool. OD/UD I know works well. I'm going to try UD first to see how it goes, then add OD if I feel it's necessary. At my local course, there's only a couple of spots that I need sharp turning.
Old 10-25-2020, 11:44 AM   #55
More progress made. Tranny built and installed.
Old 10-25-2020, 11:48 AM   #56
Spacers for the sway bars made and in stalled. There's only 1mm of space between the sway bar button head screw and chassis.
Old 10-25-2020, 11:53 AM   #57
Battery tray installed. No problem running 2200mah 3s batteries, but full size packs will have to be on their side. They won't fit because of the tranny.
Old 10-25-2020, 11:59 AM   #58
I've got enough space to mount the ESC and receiver in front of the battery tray on a piece of aluminum that I'll cut to size and attach to a couple of crossbraces.
Old 10-27-2020, 12:49 PM   #59
I could go with either lexan or aluminum. What do you think?
Old 10-27-2020, 01:28 PM   #60
I mocked up the electronics. I don't know if this is going to work though. At full suspension compression, the top links hit the back cross brace for the electronics. I don't know how often both shocks are at full compression at the same time
MaX-D's Wroncho Build - Similar Threads
Mike D's bomber upgrades/build xmikedentx Axial RR10 Bomber 22 06-12-2016 05:57 PM
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) Irishchamp 2.2 Scale Rigs 45 10-09-2014 10:26 PM
R|M|D's Yota Build (Pic Heavy) R|M|D Photography 1.9 Scale Rigs 39 12-24-2012 12:33 AM
C*H*U*D's New F-4 Build C*H*U*D Axial AX-10 Scorpion 81 10-28-2010 10:35 AM
