12-08-2020, 03:05 PM | #141 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: MaX-D's Wroncho Build
Does it matter what side the tie rod goes to. I had it in the stock position connected to the right wheel, but the chassis hits the tie rod not allowing full Flex on the right side. The chassis hits the truss right above the pumpkin on the left side which would be about the same spot that it would hit the steering tie rod. I had to flip the servo around, and I will have to put a Jato rod end on as the tie rod is a little short. Is this a bad thing to run your steering on the left side instead of the right? Does it matter? Sent from my LM-G710VM using Tapatalk |
12-08-2020, 03:49 PM | #142 |
I don’t think it matters as long as you get full lock to lock and the linkage clears. I swapped the servo location on my GCM J2 Skeleton and I didn’t have any problems. Sent from my iPad using Tapatalk |
12-08-2020, 04:13 PM | #143 | |
| Re: MaX-D's Wroncho Build Quote:
The chassis, the bumper, and the steering are the few hiccups that I've had with this project. Other than that it's been smooth. I'm also learning how to properly solder. I truly suck at it, so I bought 20 pairs of 4mm bullet connectors both male and female (Amass brand) to practice with as I need to solder on female connectors to my WP 1080 ESC. I figure if I screw up half of them, I still have 10 left. I tried 3 last night. The first one was horrible. I used way too much solder, but the second and third one got better. I'll do 4 or 5 tonight. Practice makes better. Sent from my LM-G710VM using Tapatalk | |
12-08-2020, 04:20 PM | #144 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
Soldering is definitely a developed skill. One I have not fully realized. Having a crappy iron can definitely impede the process. It’s so important to get the tinned connector or wire properly heated before hitting it with the solder. With a crappy iron(I have had too many) getting the heat can be challenging
12-08-2020, 04:28 PM | #145 | |
So far the soldering iron seems to work pretty well. Time will tell. If not, I'll upgrade to a better one, probably in the $80 range Sent from my LM-G710VM using Tapatalk | |
12-08-2020, 04:40 PM | #146 | |
12-08-2020, 06:12 PM | #147 | |
12-08-2020, 06:24 PM | #148 |
I’m fairly good at soldering, but I struggled with cheap irons until I bought this one. It heats up in seconds and hold temp. Super easy to use. Sent from my iPad using Tapatalk |
12-08-2020, 06:33 PM | #149 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
I struggle with soldering too, maybe my iron is the problem. It’s a non adjustable stick iron Weller. I’ll definitely need to upgrade soon as well. Sent from my iPad using Tapatalk |
12-08-2020, 06:33 PM | #150 |
| Re: MaX-D's Wroncho Build |
12-08-2020, 06:42 PM | #151 |
12-08-2020, 07:28 PM | #152 | |
Weller would typically be considered a good quality, but yeah could be it’s spent or just doesnt produce the required heat for heavier gauge wire | |
12-08-2020, 07:48 PM | #153 |
Quarry Creeper Join Date: Jan 2009 Location: WA state
I use this propane iron off Amazon. I also use a 2 clip stand to hold wires or whatever else. https://www.amazon.com/dp/B001DIE9BO...p_mob_ap_share Sent from my SM-G965U using Tapatalk |
12-08-2020, 07:58 PM | #154 | |
I got it new about 2 months ago and only used it about 3-4 times. Maybe it’s me? Who knows lol. Sent from my iPad using Tapatalk | |
12-13-2020, 06:08 PM | #155 |
Getting closer. Just have to paint the hood Satin black, and tint the windows. The Axial emblem will be gloss black. I trimmed around it with an Exacto knife to leave the overspray film on it. Don't know if I'm going to tint the windshield to hide the wires. I'm probably not going to put an interior in it. Any thoughts? Sent from my LM-G710VM using Tapatalk |
12-13-2020, 06:22 PM | #156 |
Looking good! I like the Axial emblem! As for windows, I would tint them since you’re not doing an interior. I personally hate seeing wires and I’m going to do an interior on my clear window body. Sent from my iPad using Tapatalk |
12-13-2020, 07:47 PM | #157 | |
12-13-2020, 08:14 PM | #158 |
I needed more steering while the suspension was under compression, so I took out the silver shock standoff. I've got about 2-3mm of clearance. It gave, but it gave me 5-6mm of more steering. Before Sent from my LM-G710VM using Tapatalk |
12-13-2020, 08:22 PM | #159 |
After. I also changed the steering tie rod to the drivers side Sent from my LM-G710VM using Tapatalk |
12-13-2020, 08:45 PM | #160 |
At post #128 I talked about droop and how I'm losing about half of my shock from the weight. Is this normal? Finally, here's some pics. First pic is full extension. Second pic is the truck sitting normally with a 3s 2200mah battery. Sent from my LM-G710VM using Tapatalk |
MaX-D's Wroncho Build - Similar Threads | ||||
Mike D's bomber upgrades/build | xmikedentx | Axial RR10 Bomber | 22 | 06-12-2016 05:57 PM |
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) | Irishchamp | 2.2 Scale Rigs | 45 | 10-09-2014 10:26 PM |
R|M|D's Yota Build (Pic Heavy) | R|M|D Photography | 1.9 Scale Rigs | 39 | 12-24-2012 12:33 AM |
C*H*U*D's New F-4 Build | C*H*U*D | Axial AX-10 Scorpion | 81 | 10-28-2010 10:35 AM |
