11-30-2020, 05:08 PM | #121 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: MaX-D's Wroncho Build |
11-30-2020, 06:31 PM | #122 |
Body mounts look great! I like the mounts you designed for the rear of the cab! Here is a tip I learned years ago for making perfect body mount holes. I use a Dremel with a stone cone bit. Slowly push it into the body where you want the hole until you get the size you want. Then just use a hobby knife to remove the little bit of lexan flash around the hole. It makes perfectly round holes every time! Sent from my iPad using Tapatalk |
11-30-2020, 06:38 PM | #123 | |
| Re: MaX-D's Wroncho Build Quote:
Great tip! My reamers always make oval holes, making me have to do the holes bigger than I need. Sent from my iPad using Tapatalk | |
11-30-2020, 06:52 PM | #124 | |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
Sent from my LM-G710VM using Tapatalk | |
11-30-2020, 06:52 PM | #125 |
11-30-2020, 07:01 PM | #126 |
11-30-2020, 07:10 PM | #127 | ||
I’ve never had luck with body reamers. They seem to always grab to hard and make the holes too big. Sent from my iPad using Tapatalk | ||
11-30-2020, 07:36 PM | #128 |
There's one thing I've noticed when the truck is actually sitting on its tires, because it's front heavy I lose half of my front shock from the weight. Is this normal? 30wt Losi oil in 100mm Traxxas big bores. Stock gray Wraith Springs. I haven't taken it for its maiden crawl yet. I could move the shock one hole forward on the tower and one hole down if necessary. Heavier oil or Springs? Thoughts? |
11-30-2020, 07:51 PM | #129 | |
If it doesn’t bother you, I’d just leave it. Ever since I relocated my shocks on the TRX4, it squats, but it doesn’t bother me too much. It’s only noticeable when your ground level with it. Picture for reference If it does bother you, I would start by moving it around on the tower and see if it helps. If that doesn’t help, heavy shock oil should do the trick. https://postimg.cc/Dm1hHk4C Sent from my iPad using Tapatalk | |
11-30-2020, 07:59 PM | #130 | |
11-30-2020, 08:02 PM | #131 |
WHO'S YER DADDY!? John Holmes, that's who! I'm convinced that John is Santa Claus, and he also included a sucker in the package! Nice touch. Sent from my LM-G710VM using Tapatalk |
12-03-2020, 06:42 AM | #132 |
Hey MaX, here are some better pics of the Honcho body. I'm going to add more of these along with how I made the bedsides to my Sport build thread soon. |
12-03-2020, 08:27 AM | #133 |
12-03-2020, 09:42 AM | #134 | |
I liked the look of the black when it was new, but as it got more rock rash, it started to get ugly! I thought about shooting it with some Tamiya flat clear to knock down the glare and hide some of the scratches. I kind a like the dull flat black look I've seen on some other rigs. | |
12-05-2020, 04:12 AM | #135 |
Pebble Pounder Join Date: Dec 2008 Location: Eastern, Oregon
Admittedly I didn't read every post in this thread, and I've not built a wroncho but why would a person not bend this chassis to clear the shocks and have the front and back of rails to come to be the same width as an scx frame? To me this seems to make more sence than adding standoffs and spacers. You could also purchase any bumpers out there and bolt them right up. Just wondering if I was missing something.
12-05-2020, 05:30 AM | #136 | |
12-05-2020, 10:30 AM | #137 |
12-05-2020, 01:53 PM | #138 |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
Seems like that would be a lot of bending in a very small space. I run spacers to clear the frame on my SCX10 based mud truck (flat rails) and have had no issues.
12-05-2020, 02:55 PM | #139 | |
12-05-2020, 02:57 PM | #140 | |
MaX-D's Wroncho Build - Similar Threads | ||||
Mike D's bomber upgrades/build | xmikedentx | Axial RR10 Bomber | 22 | 06-12-2016 05:57 PM |
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) | Irishchamp | 2.2 Scale Rigs | 45 | 10-09-2014 10:26 PM |
R|M|D's Yota Build (Pic Heavy) | R|M|D Photography | 1.9 Scale Rigs | 39 | 12-24-2012 12:33 AM |
C*H*U*D's New F-4 Build | C*H*U*D | Axial AX-10 Scorpion | 81 | 10-28-2010 10:35 AM |
