10-28-2019, 01:17 PM | #1061 |
Pebble Pounder Join Date: Oct 2019 Location: Kula
| Re: The unofficial official axial portal buggy.
I’ve got this coming in hopefully today: POWER HD TR-4 Micro Waterproof Metal Gear 2.6kg / 0.10s Diff Lock/High Low Servo Sent from my iPhone using Tapatalk Pro |
10-28-2019, 02:35 PM | #1062 | |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: The unofficial official axial portal buggy. Quote:
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
10-28-2019, 02:53 PM | #1063 |
At neutral my dig slides back and forth with no effort so I’m hoping at $20 a pop it will be an inexpensive HV and waterproof option to the sx107. Sent from my iPhone using Tapatalk Pro |
10-28-2019, 03:32 PM | #1064 | |
Quarry Creeper Join Date: May 2019 Location: North Highlands
10-29-2019, 09:54 AM | #1065 |
Quarry Creeper Join Date: May 2019 Location: Knoxville
I've had zero problems with my SX107. The programming of the my DX5C took some effort but it's working. I'm not sure that a stronger servo is needed, as long as the linkage and internals operate smoothly.
10-29-2019, 05:47 PM | #1066 |
The TR-4 is 36oz-in, close enough for the specs not to matter to the Spektrum... and if we have reports of the Hitec HS65MG working, it's really a wash. Sounds like there are several servo options here - maybe even the TowerPro MG91 would be a good choice - metal gear, digital, 2.6kg torque (6v), double ball bearing, alloy center case. 22.8x12x31mm measurements. |
10-30-2019, 10:12 AM | #1067 |
The DIG servo problem had been resolved. I still can't explain why the Traxxas 2065 worked on Ch1 (steering), but not Ch4 (DIG), but it no longer matters (it will be returned to the LHS later this week. The replacement Hitec micro servo was delivered yesterday, so, first thing this morning (technically third...making coffee was 1st, getting yesterday's mail was 2nd), I tested the replacement servo...it's functioning 100% spot-on. Have the 'center', and already lowered endpoints to '20'. Now, have to partially disassemble (sorry Johnny-5) the goat, remove the defective servo, install the replacement, and get the endpoints correct before reassembling. Glad this little "hiccup" is over. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
10-30-2019, 10:35 AM | #1068 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
My TowerPro MG90D has been shifting fine thus far. The only thing I don't like is that I don't have a metal horn so i used one of the included plastic ones, which are pretty small.
10-30-2019, 12:03 PM | #1069 |
Quarry Creeper Join Date: Nov 2015 Location: US
I got the spektrum to setup just fine but I would like to get one with a bit more power, get rid of the servo saver, and put a correct length metal horn on. I will wait til this one burns up but I can see something better on the horizon
10-30-2019, 12:14 PM | #1070 |
Replacement installed, 'center' (0) perfectly set, and endpoints (-100 & +100) perfectly set. Center sub-trim set to "-30", -100 set to "40", and +100 set to "35". 3-position DIG performing optimally. Than you to all those who provided helpful info, and thank you to all those who even attempted to help. Even those who attempted to help still provided bits & pieces of info that, in the end, did help. It had been an "interesting" journey, and a good learning experience. If, by chance, I cross paths with any of you at some point in the future, I will gladly thank you in-person. ~ More peace, love, laughter & kindness would make the world a MUCH better place Last edited by Panther6834; 10-30-2019 at 12:16 PM. |
10-30-2019, 01:41 PM | #1071 | |
10-30-2019, 01:52 PM | #1072 | |
10-30-2019, 03:39 PM | #1073 |
Id sell the extra cage and use the funds for another front axle.....
10-30-2019, 04:05 PM | #1074 | |
11-01-2019, 03:28 PM | #1075 |
Rock Stacker Join Date: Jun 2018 Location: Florida
So I installed a holmes 13T Magnum motor and an 11T pinion to try it out...slipper slipping bad. I definitely see the need for a slipper eliminator on the capra. First off, you need to put grease in the slipper and pinion gears, second, the slipper plates are like mirror finish, and thirdly, the spacer that holds pressure on the slipper is plastic...and the clutch is half the size of an scx10. Maybe a short traxxas spring would fit, idk, I’m going to put some washers in for now and crank it down.
11-01-2019, 04:24 PM | #1076 | |
11-01-2019, 05:00 PM | #1077 | |
11-01-2019, 05:03 PM | #1078 |
If the nut isn't cranked down hard enough and the slipper spins once the spacer is likely done for. I cranked mine down hard from the start and it's still solid. Most any slipper spring or solid spacer with a 5mm inner bore and 4-7mm length should be fine too.
11-01-2019, 05:42 PM | #1079 |
Meh. I switched the plastic spacer over to a spring a week or so ago and it still squeels in a light bind, even when cranked down to the point of coil bind. I'd rather just disable it altogether so it's consistent, it's just not urgent enough to do so right now.
11-01-2019, 05:44 PM | #1080 | |
The unofficial official axial portal buggy. - Similar Threads | ||||
portal axials on ax10 axial............... | bob1961 | Axial AX-10 Scorpion | 8 | 04-03-2018 04:45 PM |
Gmade R1 Rock Buggy Portal Axle any good | mudd_slinger | General Crawlers | 3 | 12-20-2011 08:25 PM |
RC Adventures - Axial Wraith - Unofficial Running Video | RCSPARKS | Scale Videos! | 13 | 06-08-2011 07:21 AM |
official duratrax vendetta buggy and st thread . | snowball50 | Chit Chat | 7 | 02-10-2007 12:47 AM |
