09-13-2016, 03:08 PM | #181 |
| Re: Maslin's Bomber Not-Ready-To-Run Build
I'm enjoying them. You have quite the....eclectic taste in music.
09-13-2016, 03:24 PM | #182 |
RCC Addict Join Date: Aug 2013 Location: Missoula
You never know what you'll end up with, Still Fly gets in there just for the Benz references |
09-14-2016, 03:59 PM | #183 |
Daily bump Definitely bent that rear shaft. I'm really enjoying this thing, it's just a lot of fun. Ran 50 minutes straight, burned through 4200mAh, much more efficient than my Wraith was. |
09-16-2016, 04:02 PM | #184 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Man, bent a chromo axle. |
09-20-2016, 07:58 AM | #185 |
| Re: Maslin's Bomber Not-Ready-To-Run Build Both rear axles are bent now Driving along happily yesterday, steering suddenly went to crap. I just knew my servo case was broken... Flipped the truck over to see a lower link flopping around, whew. Front driveshaft pin at the transfer case split the threads, pushing the smooth side out the other side. Spun around long enough to mill a nice slot in the Jato end |
09-22-2016, 01:31 AM | #186 |
Newbie Join Date: Sep 2008 Location: La Barge
Great thread man! Love the low stance may have to set mine up the same. Curries are on the way for mine, can't wait Sent from my iPhone using Tapatalk |
09-23-2016, 04:12 PM | #187 |
| Re: Maslin's Bomber Not-Ready-To-Run Build Had a lot more video from last night with a bunch of 1.9s, but it was way too dark. Did manage to land that little flip off the concrete though. |
05-09-2017, 06:26 PM | #188 | |
Rock Stacker Join Date: Oct 2009 Location: Phoenix
| Re: Maslin's Bomber Not-Ready-To-Run Build Quote:
05-09-2017, 07:01 PM | #189 |
| Re: Maslin's Bomber Not-Ready-To-Run Build Just a standard GoPro suction cup on the roof. Had to buy a cradle to adapt the Cube to standard GoPro mount, works great. The Cube is small, even smaller than the Session I believe. It's super strong, holds on tight for wide open 5s backflips on my Kraton too Like this |
05-02-2018, 03:11 AM | #190 |
Pebble Pounder Join Date: Jan 2016 Location: Worthing, England
are you still running the trailmaster pro 3300kv? Hows it holding up? |
05-02-2018, 05:48 AM | #191 |
I believe Maslin has sold off his R/C vehicles...
05-04-2018, 07:44 AM | #192 |
Pebble Pounder Join Date: Aug 2017 Location: Home
What foams are you running?
05-04-2018, 05:08 PM | #193 |
Maslin or myself? As I said, I believe Maslin has left the crawler scene - and isn't likely to respond to you... He could prove me wrong, but I doubt it. Quote from a "Classified" post of his: "The time has come... Just no time to get out any enjoy the RCs anymore" |
Maslin's Bomber Not-Ready-To-Run Build - Similar Threads | ||||
bilinvic's RR10 Bomber Build | bilinvic | Axial RR10 Bomber | 712 | 04-25-2020 08:09 AM |
CFM drops a Bomb: Bomber Fab build and upgrades | CarterFab | Axial RR10 Bomber | 132 | 01-24-2018 09:42 PM |
KurseD build: the Brass Bomber Budget Bucket | KurseD | RC4WD Trail Finder 2 | 15 | 05-26-2016 04:40 AM |
Stealth bomber the Class 3 build | RockChuck | 2.2 Scale Rigs | 53 | 05-04-2015 07:15 PM |
Ax-10 Ready to Run ?? | SD333 | Axial AX-10 Scorpion | 6 | 12-13-2007 01:25 AM |
