04-21-2016, 03:12 PM | #101 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
| Re: Maslin's Bomber Not-Ready-To-Run Build No issues with the scale Cs on the SSD housing. I wouldn't hesitate to use SSD housings, I quite like them.
04-21-2016, 03:24 PM | #102 |
Quarry Creeper Join Date: Nov 2014 Location: WA
maybe this Bomber/CMS/Prototype can be your way to go. I'm also not happy with the servo position on my Bomber, even moved back a bit still too exposed. |
04-21-2016, 03:40 PM | #103 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Maslin's Bomber Not-Ready-To-Run Build Good to know, if I can't find the VP housing locally I may go that route. Those updated mounts look good, should be much more secure with screws going through them in to the truss, rather than spinning on to studs.
04-21-2016, 04:07 PM | #104 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Yup no isses with my VP scale chubs on SSD. Plus SSD is dual 5x13 bearings.
04-22-2016, 07:48 AM | #105 | |
Pebble Pounder Join Date: Sep 2014 Location: Hamilton Montana
| Re: Maslin's Bomber Not-Ready-To-Run Build Quote:
This looks like overly aggressive driving habits. Maybe you should slow down. And stop picking on that orange AX10, it looks like a nice rig. | |
04-26-2016, 11:41 AM | #106 |
Just got the $150 phone call from the hobby shop F9 pics soon! |
04-26-2016, 12:05 PM | #107 |
| Re: Maslin's Bomber Not-Ready-To-Run Build |
04-26-2016, 12:57 PM | #108 |
Excited to see you put these to the test, Maslin.
04-26-2016, 02:03 PM | #109 |
This thing is sweet While the hardware supplied is bagged with individual pieces, instructions that aren't for the scx10 would nice. Call VP... goes to voicemail, mailbox full, hangs up on me. Sweet. Keep guessing at the 100 or so tiny pieces of metal in front of me, not sure what some things are for, lots of extra screws, lots of mounts/holes in parts that don't go anywhere But man this thing is nice. I think it's all together correctly? The left link mount looks suspect, only 2 screws far away from the actual link holding it on. Did I mention it looks nice Next step, get it on the Bomber... It's beefy, 360g as pictured. Extra hardware. Servo mounts/upper links are in there, not sure on the rest. |
04-26-2016, 02:10 PM | #110 |
RCC Addict Join Date: May 2009 Location: Weston
I had a bunch of leftovers after I put mine together as well. It's funny about the instructions. Seems VP is having some trouble with QC lately. Lots of people seem to be sharing issues all of a sudden. I hope they come out with a delrin skid of some sort. The aluminum likes to get hung up on stuff.
04-26-2016, 02:11 PM | #111 |
Convinced my phone to focus |
04-26-2016, 02:14 PM | #112 |
Damn, that looks badass. Trying real hard not to reach for my wallet. I have at least three trucks that could use a set of these.
04-26-2016, 02:19 PM | #113 |
I haven't been excited about a part in a while. It's seriously nice, not sure on all the extra holes and stuff though. There's an additional link (shock?) mount over the normal mounts, facing sideways. I believe the long set screws would be for that. More mounting options are always a good thing.
04-26-2016, 02:24 PM | #114 |
Yeah VP stuff is always top shelf. I remember the first time I got their Currie rock jock axle I was blown away at the detail and quality. I beat on mine pretty good and haven't had a single issue. They are definitely stout axles.
04-26-2016, 11:01 PM | #115 |
Late night, all back together. Seriously impressed, it came together really well. |
04-26-2016, 11:05 PM | #116 |
Very very nice man, I'm jealous. You mounted your servo upside down. |
04-27-2016, 12:47 AM | #117 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
04-27-2016, 12:50 AM | #118 |
Any clearance issues up front with the new gear? Looks like you lost a ton of uptravel with that giant truss! Sent from my SM-N910V using Tapatalk |
04-27-2016, 07:10 AM | #119 | |
I did lose ~2mm of up travel on the drivers side, the truss over the pumpkin hits the frame. The clearance of the right is actually better, 3 or 4mm of air between the truss and frame with the shock bottomed out. I have my drag link running behind the tie rod, with the servo moved back. Everything tucks in nicely. I'll add some pics in a bit to show it. | |
04-27-2016, 08:01 AM | #120 |
That's not to bad. Just now realizing that pic was at full compression! Originally I was like holy crap! Looked like you had about a 1/4 to 1/2" of travel! Sent from my SM-N910V using Tapatalk |
Maslin's Bomber Not-Ready-To-Run Build - Similar Threads | ||||
bilinvic's RR10 Bomber Build | bilinvic | Axial RR10 Bomber | 712 | 04-25-2020 08:09 AM |
CFM drops a Bomb: Bomber Fab build and upgrades | CarterFab | Axial RR10 Bomber | 132 | 01-24-2018 09:42 PM |
KurseD build: the Brass Bomber Budget Bucket | KurseD | RC4WD Trail Finder 2 | 15 | 05-26-2016 04:40 AM |
Stealth bomber the Class 3 build | RockChuck | 2.2 Scale Rigs | 53 | 05-04-2015 07:15 PM |
Ax-10 Ready to Run ?? | SD333 | Axial AX-10 Scorpion | 6 | 12-13-2007 01:25 AM |
