05-19-2016, 10:13 AM | #141 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| Re: bilinvic's DMG IFS B1B Bomber Build
No, I didn't. The front drive axles that came in the kit are 92mm...it's my understanding that the previous version used 94mm front axles that caused binding. I'm using Incision Yeti axles now and the Axial Uni's are now spares.
05-19-2016, 10:54 AM | #142 |
How many runs would you say you have on your VDIs, Bil? I'm assuming the pins are staying put in the outputs?
05-19-2016, 11:24 AM | #143 |
Pebble Pounder Join Date: Jul 2012 Location: Overton
Sorry I meant the 103MM driveshaft, I found the binding in mine was caused by SSD 2speed transmission case being 2mm longer then stick wraith trans.
05-19-2016, 01:40 PM | #144 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: bilinvic's DMG IFS B1B Bomber Build Ya I tired the 103mm yeti center driveshaft as well and its to long for me too. My only guess is his adapter plate holes are drilled farther back allowing it to work on his. He's also running his spur cover and mine won't work since servo horn hits it too.
05-19-2016, 01:52 PM | #145 | |
| Re: bilinvic's DMG IFS B1B Bomber Build Quote:
I didn't modify anything with the stock Yeti front driveshaft. I used the Yeti dogbone carrier on the transmission output shaft. It's like it was made to work with this part using the spur cover. | |
05-19-2016, 04:59 PM | #146 | |
What 1.9 rig do you run? | |
05-19-2016, 07:54 PM | #147 |
| Re: bilinvic's DMG IFS B1B Bomber Build |
05-19-2016, 09:10 PM | #148 |
Very nice Bil. I've been wanting to do an Ascender build for a while. That just gave me a lot of inspiration.
05-20-2016, 03:53 PM | #149 |
Does your servo horn Rub on the spur cover?
05-21-2016, 12:45 AM | #150 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: bilinvic's DMG IFS B1B Bomber Build There's not much room in there but it shouldn't hit. My servo is mounted to the outside of the plate & the linkage is on the inside of the servo arm. Sorry, real hard to get pics now rig is together. |
05-21-2016, 08:35 AM | #151 |
I bet bilinvic doesn't hit cover since hes still running it. Also looks like his servo ears are mounted inside on the mount too. I have mine mounted on outside of the mount and it hits spur cover. I guess it depends how your tranny adapter plate was drilled. If you look at bils motor, its almost at the end of the skid plate and mine had probably 1/2-3/4" gap from end of the skid plate. Alt, you and screamer both have your linkage mounted inside of the servo horn. My linkage hits the cage if I try that. Does your linkage mount top or bottom on the steering post? |
05-21-2016, 08:39 AM | #152 |
I have mine mounted same as Alt. Clears everything lock to lock.
05-21-2016, 08:52 AM | #153 |
Another view. The drag link does get close to the chassis but clears through full sweep.
05-21-2016, 10:16 AM | #154 |
Thanks for the pictures screamer. You have your servo ears mounted inside as well, I think if I move mine inside, then put linkage behind the horn, it will clear. Since you were able to fit the 103mm center driveshaft in yours too, your adapter plate holes are drilled farther back. For me, the center driveshaft wont fit.
05-23-2016, 09:26 AM | #155 |
| Re: bilinvic's DMG IFS B1B Bomber Build Sorry, didn't have a pic & couldn't remember, had to wait till I was home to check, my steering link is on the underside of the arm on the steering post.
06-14-2016, 06:59 AM | #156 |
RCC Addict Join Date: May 2009 Location: Weston
Just wanted to let you know that because of this build I had to have one as well to compliment my bomber. I picked up the roller from the classifieds and my first batch of parts should be here soon. Gonna keep the wheelbase long for stability and hopefully out handle my Yeti! Thanks for helping me spend money. |
06-14-2016, 09:42 AM | #157 |
I'm sure you won't be diaspointed Rjohn929.....your welcome!
06-15-2016, 10:21 PM | #158 |
Finally got around to installing the EXO front bumper. Looks much better than the Yeti bumper IMHO. I had to add 5mm aluminum spacers behind the bumper brace mount on the shock tower to lean the bumper out a bit to clear the modified Bomber front bumper section. Last edited by bilinvic; 08-19-2017 at 10:33 PM. |
06-15-2016, 10:44 PM | #159 |
Excellent choice |
06-16-2016, 01:00 AM | #160 |
Quarry Creeper Join Date: Sep 2014 Location: pacific northwest
How do you like the pro4 compared to ROC? Also, why did t you get the 3100 to run 3s cooler? Sent from my iPad using Tapatalk |
bilinvic's DMG IFS B1B Bomber Build - Similar Threads | ||||
bilinvic's RR10 Bomber Build | bilinvic | Axial RR10 Bomber | 712 | 04-25-2020 08:09 AM |
bilinvic's R1 Build | bilinvic | G-Made Crawlers | 82 | 03-14-2018 07:52 PM |
Dmg b1b & b2b bomber demo | Jasper105 | Videos! | 0 | 02-22-2016 07:26 AM |
Video of bilinvic's RR10 Bomber | bilinvic | Videos! | 1 | 01-02-2016 07:20 PM |
