11-11-2012, 12:38 PM | #161 |
Quarry Creeper Join Date: Dec 2011 Location: Colfax, NC
| Re: Dual Dingo build thread-My first build thread
Here's a couple of more up close shots. |
11-14-2012, 06:48 PM | #162 |
Started to finish the second set of wheel wells. This time I made the fenders out of one strip of styrene. Clamped and glued. Used some heat to help with the bends. I kept them clamped while applying heat and then let cool. When the glue set, I went back over the seams with thick crazy glue. Adding the strip of cut inner tube rubber to fender well with the thick glue. |
11-22-2012, 09:21 AM | #163 |
Finally got the second set of wheel wells done. I found that installing with a power driver or just over tighten with hand tool, the screw holding the styrene to the shock tower will push through the plastic. Shock tower is recessed for flat head screw. You'll see that I added washers which are a little bit wider than the recessed screw hole. I would like to put in a plug for Tony's Screws, very good prices and fast shipping. Here are some side by side shots |
11-22-2012, 10:13 AM | #164 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
Wow! These things look great! I can't believe how little some people look at this thread Happy Thanksgiving by the way |
11-22-2012, 10:35 AM | #165 |
| Re: Dual Dingo build thread-My first build thread |
11-23-2012, 08:49 AM | #166 |
Quarry Creeper Join Date: Feb 2012 Location: Texas - just outside of Austin
Dang your making me want to redo the wheel wells on my dingo....those look factory!
11-24-2012, 02:52 PM | #167 |
If any are interested, I'm starting a new build in the 1.9 scale section. Tamiya Hummer with aluminum chassis |
12-08-2012, 05:25 PM | #168 |
Sorry for no new posts lately. Been very sick and just haven't the energy to doing anything or concentrate on these. I'm ready to paint the second Dingo so I might do it real soon. Did a lot surf'n on the site and saw a lot of good stuff being done. Makes me want to expand my talents.
12-22-2012, 04:03 PM | #169 |
Finally got the base coat paint on second Dingo. I painted the inside and the yellow coat will be on the outside. I going to trim some of the outside overspray film to allow some of the black to show through on the interior. Found some cool driver and passenger heads to go with this rig. |
12-22-2012, 06:18 PM | #170 |
Rock Crawler Join Date: Aug 2009 Location: Thomasville, NC
very nice looking truck! i live in thomasville and there is a hobby shop 5 min from my house call anderson rc. theres a lot in front of it that i crawl on not much but its something..
12-22-2012, 06:26 PM | #171 |
12-23-2012, 07:49 PM | #172 |
Well, my driver is so pleased that his rig is all painted up! I'm sure he's smiling under that helmet. It's not the best paint job, but it's good enough for a trail rig that will get used. |
12-23-2012, 07:55 PM | #173 |
I took a sharp blade and trimmed the overspray film and peeled it off everywhere you see yellow. The black you see is the undercoat and that's why is has a good shine. Still need to do some touch up and mount his navigator. |
12-23-2012, 08:21 PM | #174 |
I like that color scheme looks slick |
01-02-2013, 07:03 AM | #175 |
Rock Stacker Join Date: Mar 2011 Location: London
man i really like the way u mounted the bodies .....my kit comes today from rpp i WILL BE DOING THIS to every body from now on verry good job man
01-03-2013, 12:56 PM | #176 |
| Re: Dual Dingos build thread. First build thread! |
01-05-2013, 04:46 PM | #177 |
| Re: Dual Dingos build thread. First build thread! When I bought them I planned on using only on the lower joint. I forgot that when I installed them. The info you give I never saw when researching. Thanks for the heads up. |
01-13-2013, 05:45 PM | #178 |
I got the Drivers in thier rigs now. Yellow Dingo is ready to have the grill and light bezels installed. Then I'll get the lighting installed. I forgot I had an old adjustable monitor arm, so I dug it out and used it hold my laptop. Work area has taken shape lately. Last edited by juswin24; 01-13-2013 at 06:45 PM. |
01-23-2013, 09:01 PM | #179 |
Finally started installing the light bezels and grill on Dingo 2. Test fitting parts. |
01-24-2013, 11:50 PM | #180 |
Pebble Pounder Join Date: Aug 2005 Location: Monticello
Great looking pair of dingos you have there
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/398956-dual-dingo-build-thread-my-first-build-thread.html | ||||
I don't want to grow-up, 'caus if I did... DINGO Build - RC Rock Crawlers & Scalers @ URC Forums | This thread | Refback | 03-06-2013 09:58 AM |
Dual Dingo build thread-My first build thread - Similar Threads | ||||
Dual dually project thread... | truckerbuddy2 | 1.9 Scale Rigs | 20 | 07-10-2013 11:38 AM |
Axial scx10 dingos in the sun | crazycrawler94 | Videos! | 3 | 04-10-2012 02:03 AM |
Axial scx10 dingos in the sun | crazycrawler94 | Scale Videos! | 0 | 04-01-2012 03:26 PM |
Axial Dingos with GOPRO Hero2 | crazycrawler94 | Scale Videos! | 4 | 01-28-2012 09:40 PM |
Axial dingos having some fun! | crazycrawler94 | Videos! | 9 | 01-18-2012 12:41 PM |
