10-21-2012, 03:46 PM | #121 |
Quarry Creeper Join Date: Dec 2011 Location: Colfax, NC
| Re: Dual Dingo build thread-My first build thread
Here's how the bumper looks before installing. |
10-21-2012, 03:47 PM | #122 |
If you all have any questions fill free to ask. I'll try to answer the best and fast as possible.
10-21-2012, 03:51 PM | #123 |
Here I'm making the rear body mount bracket out of styrene. The rear screw neat the Axial logo, I had to drill a hole in the frame and use a screw and nut. |
10-21-2012, 06:56 PM | #124 |
This is the first test of all front lights lit up at once. They sure lit up the garage. Can't wait to get this baby out at night. |
10-26-2012, 07:04 PM | #125 |
I got the rear bumper wired up. Since I had a long run of wire to the front I used 1/8" spiral wrap to cover the wires. Once I'm happy with everything I finalize the wiring and shrink the tubing that needs shrinking. |
10-26-2012, 07:18 PM | #126 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
that looks great man! |
10-26-2012, 07:23 PM | #127 |
I have only one mini DPDT toggle switch installed right now. It's for the headlamps and bumper lights. Second switch will be for rock lights and maybe light bar. |
10-26-2012, 07:28 PM | #128 |
| Re: Dual Dingo build thread-My first build thread |
10-30-2012, 08:15 PM | #129 |
Since I've finished most of the lighting on the red rig I've started working on rig 2. Need to finish the body mounts. Got the front done. Once they are done, I will pull the wheel wells and body mounts and get them painted. Once they done and remounted I will get the body painted. |
10-30-2012, 08:34 PM | #130 |
Dingo 2 is going to get painted a yellow color similar to this. The only I Haven't decided is to paint the inside or outside. The red Dingo I painted the outside. So I'm leaning towards the outside for realism. Last edited by juswin24; 10-30-2012 at 08:39 PM. |
11-01-2012, 07:18 PM | #131 |
Test fitting the red Dingo on chassis #2. This chassis has wheel wells and I wanted to make sure they clear the lights I installed. Had to make a few adjustments and it fit very good. |
11-01-2012, 07:27 PM | #132 |
Few pics of wheel wells and flexing a little. Still need to clean up wiring on chassis one. |
11-01-2012, 07:41 PM | #133 |
These bad boys are turnin out great!
11-01-2012, 07:45 PM | #134 |
Yeah! They are starting to shape up. Need to finish up second set of wheel wells and get all the styrene painted black.
11-03-2012, 06:15 PM | #135 |
Got the rear body mount bracket made. All that's left is the wheel wells. |
11-03-2012, 06:25 PM | #136 |
I'm stating to clean up the wiring. The Hitec servo must have had 12" wires and then on top of that is all the wire from the Castle BEC. Really hard to ditch or hide all this. I might have to cut and splice wires to make it look cleaner. I did try to put the BEC in the box and if I remember right, it caused glitches. |
11-03-2012, 08:17 PM | #137 |
Newbie Join Date: Oct 2012 Location: Lebanon
Great idea on the inside fenders! I have a dingo kit coming in a few days and was thinking of trying to make some inner fenders to help keep off road debris (dang fir and pine needles!) and rocks being thrown from the tires all over the inside of the body. PS +1 for firefly sig quote :-) |
11-03-2012, 09:01 PM | #138 | |
| Re: Dual Dingo build thread-My first build thread Quote:
Firefly was/is a great show! | |
11-04-2012, 11:25 AM | #139 |
After looking at my wiring while organizing it, It came to me that I had or could require power from chassis connection to body. I had two connectors, one for power and one for bumper lights to switch. Realized I didn't need to do that. Got it down to one. Went from this: To this: |
11-04-2012, 07:17 PM | #140 |
Front bumper looked empty. It needed something hanging from it. So I made a tow rope from some old string line I used fence building. I opened up the rope and weaved the end of the rope into itself and then added heat shrink. I pulled as hard as I could and it only tightens on itself. Even if it didn't work, it looks good. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/398956-dual-dingo-build-thread-my-first-build-thread.html | ||||
I don't want to grow-up, 'caus if I did... DINGO Build - RC Rock Crawlers & Scalers @ URC Forums | This thread | Refback | 03-06-2013 09:58 AM |
Dual Dingo build thread-My first build thread - Similar Threads | ||||
Dual dually project thread... | truckerbuddy2 | 1.9 Scale Rigs | 20 | 07-10-2013 11:38 AM |
Axial scx10 dingos in the sun | crazycrawler94 | Videos! | 3 | 04-10-2012 02:03 AM |
Axial scx10 dingos in the sun | crazycrawler94 | Scale Videos! | 0 | 04-01-2012 03:26 PM |
Axial Dingos with GOPRO Hero2 | crazycrawler94 | Scale Videos! | 4 | 01-28-2012 09:40 PM |
Axial dingos having some fun! | crazycrawler94 | Videos! | 9 | 01-18-2012 12:41 PM |
