01-09-2015, 06:48 AM | #81 |
Rock Crawler Join Date: Mar 2012 Location: UK, Hampshire
| Re: Axial SCX10 Jeep Chero-Manche
NEW TIRES: Vaterra Interco Super Swamper TSL Got my new tires in today, WOW these thing are insane!! They were a little difficult to mount on the axial beadlocks however they mounted up to the Proline titus a little easier. I think it's the dual stage foam being quite wide that makes it difficult to mount. The compound of them feels brilliant as well, sticky and pliable. The dual stage foams are decent as well which is great The size is perfect in my opinion, the diff clearance is a big plus. Also with them being a larger diameter, the low speed control is so much better. Overall I am super happy with them and can't wait to try them out on the trail. Comparison to Proline TSL. Aggressive side wall On the truck mounted to axial 1.9 beadlocks I had to test them, this is the same log/rock climb in the previous lot photos only it's wet from some recent rain. I was expecting them to be slipping a sliding but NO!! These things climbed it better in the wet than the Proline TSL's did in the dry!! Absolutely no wheel spin, the truck walked right up A little bit of trimming is going to be needed but I expected there would be. My Gmade sr02 should be here either tomorrow or Monday. Thanks for looking |
01-09-2015, 10:01 AM | #82 |
Pebble Pounder Join Date: Nov 2013 Location: Toronto, Ontario, Canada
Great looking rig. Love the color.
01-10-2015, 08:24 AM | #83 |
| Re: Axial SCX10 Jeep Chero-Manche Thanks man, yeah gun metal looks great on anything NEW WHEELS: Gmade SR02 black Got my new wheels today, fantastic quality and super easy to mount the tires to once I perfected the technique. Took no longer than 5-10 minutes per corner. I know I said I was getting the silver ones but they weren't in stock so I got black instead, I'm quite glad the silver ones weren't in stock haha Even lip all the way round Overall I couldn't be happier with the look of my truck. Also within the next couple weeks I will be gathering parts to make the move over to 3s LIPO, super stoked with that!! Thanks for looking |
01-10-2015, 08:39 AM | #84 |
Quarry Creeper Join Date: Apr 2006 Location: SLC, Utah
| Axial SCX10 Jeep Chero-Manche Quote: Looks great reminds me of my previous mj body. Which my buddy now runs on his wraith . I do agree gunmetal looks great on everything my frame and beadlocks are gunmetal |
01-10-2015, 02:06 PM | #85 |
| Re: Axial SCX10 Jeep Chero-Manche Yeah I've seen pics of your old body, really like your truggy version as well. Gun metal is great haha
01-10-2015, 03:08 PM | #86 |
Rock Stacker Join Date: Nov 2011 Location: Carrollton
Nice truck man what kind of bumpers are you running? They fit great!
01-10-2015, 03:24 PM | #87 |
| Re: Axial SCX10 Jeep Chero-Manche |
01-25-2015, 12:41 PM | #88 |
Took the truck out the other day with my cousin, unfortunately the stock servo in his gave up the ghost so he's now got a nice new Savox waterproof jobby. He's also got the Proline 2 door Dodge Ram body that needs painting and mounting, he's loving this hobby Anyway on to the Comanche, by next weekend I will be buying the bits for the 3s LIPO conversion. Here's what I intend on buying, can't wait!! Novak Eiger Pro Crawler Brushed Esc And Bec Unit Team Orion Rocketsport 3200mAh 25C 11.1V LiPo Pack (2) Team Orion Advantage One 406 AC/DC 50W NiMh/LiPo Charger Core RC Pinion Gear 48DP 16T (7075 Hard) Core RC Pinion Gear 48DP 15T (7075 Hard) DEANS PLUG WITH GRIPS (1 MALE/1 FEMALE) And here are some pictures Thanks for looking |
02-05-2015, 12:38 PM | #89 |
Went and picked up my new bits from my LHS today after work, super excited for the weekend to get this all plumbed in I will be ordering some new HD Axial ring and pinion for both axles as well, thinking I will go overdrive in the front and standard in the rear. Here's some pictures of my new bits Pinions, gear down volt up I think the saying goes Got a new 80w soldering Iron as well Got two 3s batteries for those long trail runs I thought this was cool, the batteries come with a Vennom Uni Plug so I don't need to solder the deans connectors on, WIN Charger, need to learn how to use this thing The new Novak Eiger Pro ESC Novak BEC included with it This thing is small compared to the trusty Rooster ESC it is replacing Representing!! Stripped down ready for the conversion Thanks for looking and keep an eye an out over the weekend for the install update Edit: Just ordered Axial HD ring and pinions, got standard gear ratio for both axles simply because the Over Drive set wasn't in stock. Should be here within a few days seeing as they're on a 24 hour courier service Last edited by pobrockcrawler; 02-07-2015 at 07:13 AM. |
02-07-2015, 07:37 AM | #90 |
Got everything plumbed in last night. ESC battery wires and BEC wires soldered to the deans connector. BEC plugged into the bind port of the receiver and red wire removed form the ESC to receiver. I wanted the BEC to go in the electronics box, that meant that the light controller unit has to live outside, it got a generous amount of electrical tape. Made a bracket to mount to the gearbox to rotate the axial cable holder 90 degrees, This also gets the deans connector in the air away from water and dirt/dust. Left switch turns the BEC/servo on and the Right switch turns the ESC on. Ready for her maiden voyage. I've been running it around the house using the 16t pinion with 87t spur (35 turn motor) and it seems pretty good. Low speed control is great and top end speed is more than enough, it's quite fun actually!! Everything runs cool which is a bonusIt's also extremely smooth. I set the drag brake to it's maximum setting, had to go on the Novak website to work out how to change it's setting. Very easy to do with the touch setting Novak uses. The charger is brilliant, easy to use and the battery does not increase in temperature what so ever. Overall i'm really happy that I have finally made the move over to LIPO batteries, 3S ones an all!! Just got to wait for the HD ring and pinions and this truck for once will not need any parts for a long while....hopefully!! Anyway thanks for looking . Last edited by pobrockcrawler; 02-07-2015 at 07:40 AM. |
02-08-2015, 06:00 PM | #91 |
Newbie Join Date: Feb 2015 Location: flag pond
Very very sweet ride
02-09-2015, 02:09 PM | #92 |
02-09-2015, 02:19 PM | #93 |
Got my Axial HD ring and pinions today (standard gearing front and rear). Really nice quality and I like that the pinion and output is all one piece. Being helical cut they mesh very nice indeed. Got them fitted this evening so here are some pictures Made some pins for the CV joints as the original ones were very worn, I made them out of a drill bit of the same diameter I have also neatened up the wiring and managed to fit the light controller in the radio box. Can't wait to go test it all out |
02-10-2015, 12:27 PM | #94 |
So the drill bit pin idea wasn't working, I have now ordered new axial universal joints and some axial 12mm hex hubs Some of you may have noticed I have bought a substantial amount of parts recently, the reason being is because I have got a full time job now, my first one ( I'm 18 ) so I finally have a nice income coming in Anyway thanks for looking . Last edited by pobrockcrawler; 02-14-2015 at 07:41 AM. |
02-15-2015, 12:04 PM | #95 |
Got the truck out today and I am speechless... This whole 3s lipo battery business is no joke, the truck literally went everywhere I pointed it!! Nothing broke however the pins in my drive shafts kept baking out so I have put my 3racing shafts on, problem solved Here are the pictures from today Flexing I hope you enjoyed these pictures |
02-18-2015, 12:53 PM | #96 |
02-18-2015, 04:29 PM | #97 |
Rock Stacker Join Date: Feb 2013 Location: montreal
The trimmed flares look very well done, I would like to do this to mine but I'm terrified to ruin them! how did you get the corners so smooth and natural looking? I'd like to open mine up like that rather than trim the corners.
02-19-2015, 03:31 AM | #98 | ||
| Re: Axial SCX10 Jeep Chero-Manche Quote:
. Last edited by pobrockcrawler; 02-19-2015 at 03:34 AM. | ||
02-20-2015, 05:16 PM | #99 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
What's your track width with the new rims? I just ordered 2 sets. I really like the look. I hope they will clear my 8 degree vanquish knuckles |
02-21-2015, 01:31 PM | #100 | |
Inside tire to inside tire is 142mm They are a nice wheel especially for how little money they are. If you want anymore info just ask mate and i'll try help you out . Last edited by pobrockcrawler; 04-27-2015 at 03:38 AM. | |
Axial SCX10 Jeep Chero-Manche - Similar Threads | ||||
SCX10 Jeep Cherokee | Bissett | Newbie General | 17 | 11-06-2015 10:43 AM |
Axial SCX10 Jeep Cherokee Scaling | MXRac3r545 | Videos! | 0 | 08-09-2012 07:57 PM |
