06-10-2015, 06:03 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| RC4wd portals
worth the 200+ to get them? looks like you get a good bit more ground clearance.. thanks guys have a good one |
08-09-2015, 09:54 AM | #2 |
| Re: RC4wd portals
I would like to hear some first hand experience with these portals as well. Can't believe there isn't more talk about them at least.
08-09-2015, 10:32 AM | #3 |
Quarry Creeper Join Date: May 2009 Location: India
| Re: RC4wd portals
I love portals. They make a rig look good. The only issue I see is, center of gravity goes up. IIRC back in 2012 I used to see a lot of buzz about portals. Wierd, people don't discuss them as much. |
08-09-2015, 11:09 AM | #4 |
| Re: RC4wd portals Partly correct imo to center of gravity. If you build the suspension correctly it doesn't have a high center of gravity.
08-09-2015, 05:36 PM | #5 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: RC4wd portals
They definitely look nice but wow $240 for all 4 portals without axles. Why not R1 portals? You could get R1 portals with the steering knuckle swap mod,some aluminum C hubs and end up with a whole extra set of axles for $80-$100 less. Keep your previous axles for another build or sell them for cash. I picked up a used set of R1 portals and bought the parts for 4WS with all 4 aluminum knuckles and stronger CVDs for about $140 shipped. Do some notching & file some spots and you have lots of free steering angle. Tap a hole and use a spare set screw for a cheap secure locker. |
08-09-2015, 07:56 PM | #6 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: RC4wd portals
the portal gears in the Gmade R1 Axles are super weak. to the OP....My buddy had them, ran em for a little while and then removed them cause he kept braking the pins in the cv shaft going into the portal box on the stub shaft. Takeaway is that portals are great for a scale truck/Unimog etc, but not really the best for any performance or high power rig. Pick good lines and you wont even need the extra bit of axle clearance |
08-09-2015, 09:10 PM | #7 |
| Re: RC4wd portals
I didn't see a mention of the kind of power he plans to put down,but I've seen 8-10 lb 2.2 builds on here here with 4S brushless not have issues. The CV shaft would also be replaced for a few $ like i suggested. I suppose the gears could be weak in some cases, but the only single issue I've read or heard about with the gears was due to the small bearing going bad. Much like the small AR60 pinion gear that can be solved with better better bearings,a bushing,or a bigger bearing. There is also the "Wraptor" C-hubs that let you use AR60 knuckles & axles. I'm running a Brood HHK R/T 35T on 4S. Not a monster but I can bash and beat the hell out of it without issue. For the price difference I think it's great bang for the buck. Especially if you get to keep the old axles or even sell them for $65+ to get some money back. You could potentially have upgraded R1s for less than half the cost of the RC4WD and save about $150. If money isn't concern I'd get the RC4WD but for many it is and the modded R1s offer great bang for the buck comparatively.
08-10-2015, 09:19 AM | #8 |
| Re: RC4wd portals
I have read the r1s are not that strong. motor will be a tekin roc, mmp esc in a scx10 with ar60 axles. maybe 4s 3s for sure
08-11-2015, 10:14 AM | #9 |
| Re: RC4wd portals
Damn. Tapatalk lost my reply...oh well. There are multiple R1s and 8lb-10lb scale rigs with R1 axles using using the tekin,T8s,pro4s ect on 3s & 4s. Do a Google forum search and you'll find a few. IMO the R1 axles with the wheely king CVD mod or in your case even the "Wraptor" adapter are plenty strong. Those that have done the mods with a bushing or bearing upgrade have no fears or concerns with it. AR60s have been known to have diffs & pinions fail and they are still popular and considered durable. IMO I'd rather spend half as much $ on something I know or at least have seen work over something almost twice as much that I haven't seen handle any serious power. At the end of the day it's your $ Either way post a link to a build when you decide |
08-21-2015, 01:42 PM | #10 |
Pebble Pounder Join Date: Feb 2011 Location: Office Space
| Re: RC4wd portals
I bought a set! But....... had to sell them(New baby= daycare $$$x2 kids) before I was able to run them. How ever the guy I sold them to loves them. standby and I'll upload the photos he sent me. |
09-08-2015, 06:35 AM | #11 |
| Re: RC4wd portals
I have other things to take care of now. whens funds get back up. going to look for a set of r1 instead of laying out 200 +
09-08-2015, 08:50 AM | #12 |
| Re: RC4wd portals
Here are some helpful links for the R1 portals I've saved over time. Gmade R1 bearings Gmade shafts alternative fix? (Pic heavy) GMade R1 Axle Shaft to XVD mod Szczerba's JK (Minus some doors) R1 Knuckle-mod R1 Steering Revisited Poor Man's HD locker Underdrive for the R1... Finally Reducing Backlash/Slop In Drivetrain Anyone Interested in Knuckle Weights for the R1? DravTech presents a sneak peak on the Gmade R1 Wrapter DravTech presents... The Wrapter for the Gmade R1 Portal Axles Narrow R1's |
09-09-2015, 06:51 AM | #13 |
| Re: RC4wd portals
great information. thanks a lot
RC4wd portals - Similar Threads | ||||
rc4wd portals for scx | Meatwad | General Crawlers | 9 | 12-25-2014 06:33 PM |
RC4WD Portals, | gunder463 | Axial Wraith | 7 | 12-04-2014 09:29 PM |
rc4wd portals...arrrgh! | keala | General Crawlers | 5 | 10-21-2008 09:14 AM |
