01-01-2017, 10:07 AM | #181 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
| Re: bilinvic's SCX10 II |
01-02-2017, 04:55 AM | #182 |
Pebble Pounder Join Date: Mar 2016 Location: Pacifica
One more time Bill....and i kinda like them. CNC Aluminum Front Shock Hoops Parts This one not so much. http://www.hot-racing.com/index.cgi?...XT28301;c=1020 ~D Last edited by Say what?; 01-02-2017 at 11:51 PM. |
01-14-2017, 05:39 PM | #183 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
It was beautiful sunny day for crawling up Mt. Work today. There were at least a dozen rigs out and only a handful made the whole journey to the summit and back. The only thing different for my 10.2 was that I used .350 SLW hubs vs. .475 SLW hubs today. Once again my machine killed it out there...there's lots of rigs to compare performance with and very few can match mine, including other 10.2 trucks...I'm so happy that I have my 10.2 dialed in for optimal crawling performance which results in pure driving satisfaction!!!! Last minute decision was to throw the KLR's back on because the foams in the P-L Flat Iron XL tires didn't feel right, there's too much side-to-side movement. I'll have to try them another day. After today's run I question why I am even building another 10.2 rig...I sure hope it matches the performance of this one. Ran into some kool ice formations today once we got up in elevation: In the distance is Mt. Baker in the good 'ole US of A...hello my American friends!!! Last edited by bilinvic; 11-11-2017 at 10:54 AM. |
01-14-2017, 10:40 PM | #184 |
| Re: bilinvic's SCX10 II Last edited by bilinvic; 11-11-2017 at 10:55 AM. |
01-17-2017, 03:26 AM | #185 |
One more for your viewing pleasure: for Axial SCX10 II #SCX2-6023GM, ,(SCX2-6023GM) by Samix Aluminum Front Shock Plate 1 pair Gun Metal ~D |
01-22-2017, 12:01 PM | #186 |
I got the foams worked out for the P-L 1.9 Flat Iron XL tires. I bought a set of the newly released P-L 1.9 2-stage foams; for the rears I used them as is and with the fronts, I used CI 4.5 soft outer foams with the blue P-L inners. The rears are slightly stiffer but still allow the tire to conform, the fronts feel perfect. Now I will finally be able to test out these tires and the added ground clearance may even make my phenomenally performing 10.2 even better...if that's even possible!!! |
01-22-2017, 09:38 PM | #187 |
Quarry Creeper Join Date: Dec 2016 Location: FL
Looking very nice. The Samix Shock Hoops look nice, may wind up picking them up whenever they get back in stock at amain, lol darn near all of Samix parts for the 10.2 are sold out . Good to hear about the Pro Line 2 Stage Foams, got a 4 of them coming tomorrow that I am going to pop into my Hyrax's. Should be interesting Comparing the Hyrax's to my Voodoo KLR's. Well, I should say once I get my VP Front Axle back from being fixed lol.
01-24-2017, 06:34 AM | #188 |
Bill i just want to thank you for all of your build threads that are packed with IMHO some of the best information on this forum and your willingness to help me and so many others. I have learned so much from YOUR work. . Thank You! Darris |
01-24-2017, 07:53 PM | #189 |
Thanxs for the thanxs Darris! I'm glad I can be helpful, because many others did the same for me when I got into RC's a few years back.
02-16-2017, 05:20 AM | #190 | |
Newbie Join Date: Jan 2017 Location: Australia
| Re: bilinvic's SCX10 II Quote:
Great build and thanks for posting so much detail! Very helpful! I realise I am reviving an old topic on this thread. I am trying to use the same Yeti bumper and Exo parts for my own build (which hasn't started yet). I noticed that you have a brace in the middle between the two ends of the chassis rails. Could you please share what parts you used to make that brace? Is that the same as the shock braces? Thanks a lot, Leo | |
02-16-2017, 04:00 PM | #191 |
Hey Bill, would you tell me how you setup your "slipper clutch"? And have you made any changes (tweaks) to your setup? Thank You for your time and help! ~D Last edited by Say what?; 02-16-2017 at 05:35 PM. |
02-16-2017, 08:45 PM | #192 | |
The shock braces are Axial 60mm posts with 2mm aluminum spacers on each side. This rule applies to all my rigs, I tighten down the 4mm Nyloc nut until it is snug and then loosen about a half turn. I find it holds the slipper really tight and only lets the slipper spin when there is an extreme bind. This 10.2 truck crawls so good that I haven't had to really tweak or tune anything. I still haven't run it with the new P-L Flatiron XL tires yet, hopefully soon. | |
02-17-2017, 05:16 AM | #193 |
Thanks a lot for the information Bill! Cheers Leo |
02-17-2017, 10:16 AM | #194 |
Newbie Join Date: Nov 2011 Location: Deltona
I love this truck. It's what inspired me to use my 10.2 axles for a 1.9 rig and find that body. I'm sure it's been mentioned but what foams are you running?
02-17-2017, 09:26 PM | #195 |
I'm running the the Voodoo "under 10lbs" foams with the silver compound KLR tires. I'm glad this has given you some inspiration J&JFab.
02-18-2017, 04:11 PM | #196 |
Hi Bill, What did you use to cut down the "Side Plates" ? And thank you much for your "slipper clutch" setup. ~D |
02-18-2017, 05:06 PM | #197 |
A very sharp 18mm utility knife and then sanding sticks to shape and smooth. Please be careful though...fingers can easily be lost if the knife slips!
03-14-2017, 09:56 PM | #198 |
Hey Bill, me being a "Newbie" to crawling do you run toe in, toe out, or zero toe ? Thank You for your time and help, Darris |
03-14-2017, 10:13 PM | #199 |
For my crawlers, I prefer zero toe but if there was any toe, toed in would be my preference.
03-26-2017, 10:39 PM | #200 |
Newbie Join Date: Mar 2017 Location: Richburg, SC
Love this thread just read it completely through - so happy to find a new part of RC!
bilinvic's SCX10 II - Similar Threads | ||||
bilinvic's R1 Build | bilinvic | G-Made Crawlers | 82 | 03-14-2018 07:52 PM |
bilinvic's Ascender | bilinvic | Vaterra Ascender | 169 | 11-14-2017 07:59 PM |
Video of bilinvic's RR10 Bomber | bilinvic | Videos! | 1 | 01-02-2016 07:20 PM |
bilinvic's Ultimate SCX10 '73 Bronco Build | bilinvic | Axial SCX-10 | 24 | 05-03-2015 05:55 PM |
bilinvic's Second Wraith Build | bilinvic | Axial Wraith | 11 | 10-14-2014 05:39 AM |
