09-17-2016, 08:42 AM | #101 | |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| Re: bilinvic's SCX10 II Quote:
IIRC, I used Traxxas TRA 1985 shims (5x8x0.5mm). Yes, VooDoo foams (under 10lbs). I haven't run the SCX10 II with the new wheels yet, but I anticipate side-hilling will be just as good as the 1.9 SSD wheels, maybe even slightly better? | |
09-18-2016, 06:52 PM | #102 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
| Re: bilinvic's SCX10 II |
09-20-2016, 02:41 PM | #103 |
Quarry Creeper Join Date: Dec 2015 Location: ossipee
How do you like the new servo so far?
09-20-2016, 08:12 PM | #104 |
I haven't had a chance to test out the Promodeler servo yet...hopefully soon.
09-22-2016, 07:08 PM | #105 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Re: bilinvic's SCX10 II I just did this on mine today as im still in the build process of a kit that I've had sitting around for months
09-29-2016, 04:39 AM | #106 |
Pebble Pounder Join Date: Mar 2016 Location: Pacifica
Hi Bill, What size SLW wheel hubs did you use with the new 1.4 wide wheels? Have you had a chance to run that "SWEET" truck of yours? If so would you tell us about it? Thank you Sir. ~D Last edited by Say what?; 09-29-2016 at 06:09 AM. |
09-29-2016, 08:23 AM | #107 |
As it sits now, I'm using .600 SLW hubs but I will probably go down to .475 hubs to narrow the track width just a bit. No, I haven't ran it lately....it's killing me! |
09-29-2016, 10:46 AM | #108 | |
Quarry Creeper Join Date: Mar 2016 Location: juneau
Sent from my SAMSUNG-SM-G891A using Tapatalk | |
09-29-2016, 11:27 AM | #109 |
Quarry Creeper Join Date: Aug 2016 Location: The Netherlands
09-29-2016, 12:31 PM | #110 |
10-01-2016, 03:49 AM | #111 |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
Nice build!
10-04-2016, 07:14 PM | #112 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Re: bilinvic's SCX10 II Quote: Anyhow I also discovered my problem with limited suspension travel with both wheels in the rear. Don't laugh, but I had the upper 2 rear links reversed from side to side, causing it to bind on the transmission mounts. It looks as though it would be easy for anyone to do. Sent from my SM-N920V using Tapatalk |
10-04-2016, 07:24 PM | #113 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
Hey Bill, I just built a Kit Wraith, and it uses the same Axial style ends on the links. I'm finding them to be a pita as they always seem to pop off the pivot balls causing limited travel or slightly binding the travel. Not sure whats up with them, but I'm currently looking for a proper replacement end. Wasn't sure if you noticed yours doing the same or not, but maybe keep an eye for it, as I constantly have to "re-pop" mine back onto the pivot balls while I'm out on a hike.
10-04-2016, 08:50 PM | #114 | ||
10-05-2016, 10:27 AM | #115 | |
Sent from my SM-N920V using Tapatalk | |
10-05-2016, 09:08 PM | #116 |
Revo link ends TRA5347 Jato link ends TRA5525 You can also go with RPM link ends which also come in Revo and Jato lengths....they are even better, but slightly larger diameter. |
10-07-2016, 06:33 AM | #117 |
Thanks Bill for the quick responses Sent from my SM-N920V using Tapatalk |
10-07-2016, 01:17 PM | #118 | |
Quarry Creeper Join Date: Nov 2008 Location: The land of bagged milk
10-08-2016, 10:41 AM | #119 |
I use 2200 mAh 3S batteries which fit under the front shock hoop crossbar. I can easily get 2.5 hours of run time per battery.
10-08-2016, 07:59 PM | #120 |
Bill are you running the stock kit springs?
bilinvic's SCX10 II - Similar Threads | ||||
bilinvic's R1 Build | bilinvic | G-Made Crawlers | 82 | 03-14-2018 07:52 PM |
bilinvic's Ascender | bilinvic | Vaterra Ascender | 169 | 11-14-2017 07:59 PM |
Video of bilinvic's RR10 Bomber | bilinvic | Videos! | 1 | 01-02-2016 07:20 PM |
bilinvic's Ultimate SCX10 '73 Bronco Build | bilinvic | Axial SCX-10 | 24 | 05-03-2015 05:55 PM |
bilinvic's Second Wraith Build | bilinvic | Axial Wraith | 11 | 10-14-2014 05:39 AM |
