10-23-2013, 05:57 AM | #221 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread
I've done the bushing update (HPI ones) with plastic housings and was originally concerned about the heat from the bushing/shaft wear causing the housing to deform. I took a closer look last night and I have a decent amount of slop after 4 hours of run time and its all in the pinion to bushing (more than with bearings). I grabbed a new bushing and its not very tight on the pinion shaft either. I also have the traxxas oilites so I test fit one of them and its the same looseness. For grins I put a new fast Eddie bearing in there and it's nice and tight. Anyone else had a similar experience? It doesn't look like the vanquish ones made it to market as they can't be found on the web except for Harley's review. Last edited by dna4engr; 10-23-2013 at 06:00 AM. |
10-23-2013, 12:12 PM | #222 |
Newbie Join Date: Feb 2005 Location: N/A
Vanquish, or Harley any update on these? Have Currie axles, and those thing are nice, but a mother to keep pulling apart:( |
10-23-2013, 12:14 PM | #223 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread They just have too many other products to get caught up on. Not sure when these might find their way into production. Still running my original set though and no issues.
10-23-2013, 02:51 PM | #224 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
Harley, are you using anything special for grease on your bushings?
10-23-2013, 04:15 PM | #225 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread |
09-07-2014, 12:42 PM | #226 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
any word on this bushing upgrade for the pinion shaft? Where can I purchase some?
09-07-2014, 12:53 PM | #227 | |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Quote:
Just as a frame of reference, I am still running the very first set I ever installed in my Wraith axles. I have no idea how much run time is on them now | |
09-09-2014, 12:48 PM | #228 |
Quarry Creeper Join Date: May 2012 Location: Baja, Mex / Calexico, Ca.
so.. traxxas , HPI silver ones, or thrust bearing? I already have the traxxas bushings but I dont mind spending another $5 for a better option. my stock bearings are still running good but thats because I have just a few hours with the 3656sd 3400kv 4-pole on 3s..before that it was just a 3300kv 2-pole on 8-cell nimh. now that summer is about to end I will have my Baja wraith running again (cant running it with temps above 115 everyday) and want to prevent to crash the pinion bearing like most with 4-pole motors and 3s.. even without been one of the "select-few" ... even though, Im still worry |
09-09-2014, 05:04 PM | #229 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
I tried pinion bushings. Created to much heat for my liking. The drive shafts actually got pretty warm from this. Also there was as much slop as a bad bearing after only one day of trailing. I have since swapped to a set of dlux housing with bearing mod. Even after some pretty hard bashing I have not had any issues. |
09-11-2014, 07:50 PM | #230 |
Oilite bushings |
09-11-2014, 09:37 PM | #231 |
Rock Stacker Join Date: Nov 2013 Location: Meridian, Idaho
09-12-2014, 10:16 AM | #232 |
linear slop will kill a bearing or bushing, no doubt about it. There's also 'wag the tail' syndrome at play here: think about it as the axle wagging the drive shaft and the bearing or bushing is the pivot. As the axle moves, the drive shaft must follow which puts a huge amount of stress on the pivot point...bearings don't like that sort of thing...that's what bushings were developed for.
09-12-2014, 11:46 AM | #233 |
09-12-2014, 02:48 PM | #234 |
Yup, big is certainly better with this |
09-12-2014, 03:00 PM | #235 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread what is the part # for the shims that you used and where can I get them?
09-12-2014, 03:24 PM | #236 |
It's an associated sc10.2 SCT part # 7933. It's called a bearing crush tube. This is not a part that fits perfectly and all is good. I had to open the inner diameter with a small round file and cut the tube to length to fit so there was no in and out play. Sorry it's not just a bolt on item but with a bit of sanding and cutting to fit it should solve your problem Tower hobby sells them. |
09-12-2014, 09:34 PM | #237 |
Rock Stacker Join Date: Aug 2014 Location: Somerset
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Can you machine the VP AR60 housing to accommodate the larger bearing?
01-10-2015, 11:06 PM | #238 |
Quarry Creeper Join Date: Jul 2014 Location: North Florida.
And how much do you charge for this mod ?
01-11-2015, 01:59 AM | #239 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread You can find 5mm ID shims in various thickness and outer diameter at A-Main, Tower and other hobby suppliers. Just stack a few on the input shaft until you have the shaft free of slop, but not overly tight. If you get it too tight this can wear-out the bearings quicker.
02-16-2015, 07:35 PM | #240 |
Rock Crawler Join Date: Dec 2013 Location: Tuxedo NY
So, is there any final analysis of the thrust bearings? Or the VP bushings?
AR60 Pinion Bushings vs Bearings vs Bushings Thread - Similar Threads | ||||
Bearings vs. Bushings | Lentsnh2012 | Axial Wraith | 47 | 11-23-2013 09:55 AM |
Bushings>Bearings | sundayface | Axial SCX-10 | 7 | 02-29-2012 09:40 AM |
bearings or bushings ??? | 48machinerulz | Tamiya TLT Crawlers | 4 | 03-31-2007 02:28 PM |
