08-01-2013, 04:49 PM | #281 |
Pebble Pounder Join Date: Jun 2013 Location: Greenbrier
| Re: Harley's $50 Poison Spyder Wraith Budget Build
Will you be adding a winch to this wraith? What is the difference between the servo you use in this wraith vs your hit and run build? The G6 footage was great.
08-01-2013, 04:52 PM | #282 | |
| Re: Harley's $50 Poison Spyder Wraith Budget Build Quote:
The BLS157 is more powerful and has a stronger gear material. If I were ever to damage the gears in this servo I would upgrade the gears to the BLS157 gears. | |
08-01-2013, 05:00 PM | #283 |
Newbie Join Date: Mar 2011 Location: Redondo
Chassis mounted steering servo?
08-01-2013, 05:01 PM | #284 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build |
08-01-2013, 05:16 PM | #285 | |
08-01-2013, 05:21 PM | #286 | |
I will likely incorporate a HD front bumper setup from the DMG. I think my CMS/Winch setup would be very similar to my Hit & Run. I don't think I would need to do much modification to use that same configuration. | |
08-01-2013, 06:00 PM | #287 |
Rock Crawler Join Date: May 2012 Location: Upland
Is there a reason you would do a cms and not a light bar? Aren't they both for aesthetics? Sent from my PG86100 using Tapatalk 2 |
08-01-2013, 06:04 PM | #288 | |
And don't get me wrong, I'll add lighting but it just won't effect the budget because I consider it only cosmetic. Last edited by Harley; 08-01-2013 at 06:10 PM. | |
08-01-2013, 08:28 PM | #289 | |
Newbie Join Date: Jun 2013 Location: Corbin
08-01-2013, 08:35 PM | #290 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build While that isn't a set in stone decision, I have had a lot of luck with 3.5" shocks in the past. For now that is really just a place holder. I am not sure I will go with those shocks at all.
08-01-2013, 10:42 PM | #291 | |
When you did the fastback setup with lower plastic links, did you use the ball ends in them? From what I can see, you just sandwiched them with the two cage parts and screwed it back together? | |
08-02-2013, 12:26 AM | #292 |
Pebble Pounder Join Date: Dec 2012 Location: Belgium
Natedog, watch the videos. yes he used the ball ends. Everything comes clear in the videos!! |
08-02-2013, 12:44 AM | #293 |
Frakke, thanks will watch again been a long day working long hours.
08-02-2013, 12:47 AM | #294 |
What made you pick the Gmade or the proline shocks?
08-02-2013, 06:23 AM | #295 |
A light bar increases night time performance doesn't it?
08-02-2013, 07:16 AM | #296 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build The Gmades are cheaper is all. I actually HAVE the Prolines at home though and wouldn't have to buy them. The Gmades would effect the budget less but would effect my REAL budget much more That list is by no means final. That is just stuff I have thrown in there so I can work with prices and time lines. |
08-02-2013, 07:21 AM | #297 |
08-02-2013, 07:22 AM | #298 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build Yeah it was Week 5 when I did it. I did use the ball ends and I explained why I did it. I trimmed the cage to account for the difference in thickness.
08-02-2013, 08:35 AM | #299 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
Why would you use prolines or Gmade over bigbores?
08-02-2013, 08:49 AM | #300 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/450136-harleys-%2450-poison-spyder-wraith-budget-build.html | ||||
just bought wraith rtr, now what upgrades? - Pirate4x4.Com : 4x4 and Off-Road Forum | This thread | Refback | 08-05-2013 12:19 PM |
Harley's $50 Poison Spyder Wraith Budget Build - Similar Threads | ||||
Nikka's Poison Spyder Wraith Build | Nikka | Axial Wraith | 69 | 07-02-2016 01:55 PM |
Jeep Poison spyder wraith | allanon1965 | Axial Wraith | 33 | 08-14-2013 11:19 PM |
Poison Spyder Wreckluse Build | Guam_RC | 1.9 Scale Rigs | 39 | 02-26-2013 08:35 AM |
Billet's poison spyder wraith | Billet | Axial Wraith | 6 | 10-06-2011 10:35 PM |
