03-31-2017, 06:58 PM | #21 |
| The Slider
Getting close now, need to adjust the shelf for full clearance with the upper links, make a plate to hold the rx, and clean the wiring up. Ran a few circuits in the yard, loves to climb out of the lake banks, may drop the pinion back to a 19. Finished the fastback up, clearance the hood for the shocks, and threw a set of lights up front... Hang up and Drive |
04-01-2017, 07:37 PM | #22 |
| The Slider aka "OPIE"
Finished up rear inner tins Made a set for the pans, not sure though... Hang up and Drive Last edited by mikemcE; 04-01-2017 at 09:36 PM. |
04-02-2017, 08:59 PM | #23 |
Rock Stacker Join Date: May 2016 Location: seward
| Re: The Slider aka "OPIE"
LOVEEE Want that kinda flex! for my wraith. Ive got a Rs10 tho that gets over 90 degrees on cirtin circumstanced
04-05-2017, 05:21 PM | #24 |
Played in a dry creek...... Ruptures don't work well in mud Hang up and Drive Last edited by mikemcE; 04-05-2017 at 05:23 PM. |
04-13-2017, 03:50 PM | #25 |
Parts Thursday!! Thanks to Eddie at CI ! And Zack at RPP ! Just waiting on my Super Shafty top shaft to mount up that 32p Hang up and Drive |
04-13-2017, 04:23 PM | #26 |
Nice. My frame for my scaler project will come tomorrow if USPS runs.
04-27-2017, 02:54 PM | #27 |
They said diamonds are a girls best friend. What about OPIE ?? Hang up and Drive |
04-27-2017, 03:31 PM | #28 |
| The Slider aka "OPIE" Took the diamond from the Yeti and dropped a wide instead, and a matching front ! Just a comment on these SSD diamond axles. I have now built 3 identical axles, HD axial gears, VP shock mounts, Incision lockers, Delrin pinion protector. I was amazed how everything fit smoothly. Five Star Rating Hang up and Drive Last edited by mikemcE; 04-27-2017 at 08:00 PM. |
04-29-2017, 05:32 PM | #29 |
Well what a great Saturday ! New servo arrived . I liked the Savox 1256 but felt it was a bit slow and weak. It was and is perfect for a 2wd truck, like the one I grabbed it from. I popped it in and found no rib for my VP servo clamp , so slid the bushings in, loctited the screws and set the voltage at 8.0 finally . Went out to test, almost too fast and great response in the rip rap. I was used to portals with these ruptures, and knew they could grab. I do need to remember I lost center clearance, but between the Tekin and the Ruptures, OPIE rocked ! Could not get stuck! I did twist the servo mount, do to the donuts, so I removed them and kept crawling until I noticed a wobble, found I dropped a knuckle screw , and didn't have a short enough one with me so called it a day. Yeah I drove it......... Hang up and Drive Last edited by mikemcE; 04-29-2017 at 05:37 PM. |
04-29-2017, 06:00 PM | #30 |
| "OPIE"
After........ Still waiting on usps for my super shafty goodies, then bomb proof trans goes in and we are done !! Few current shots Tekin 17.5 gen3 and HH BLE with a CC bec wired in with Deans Futaba rx on a hinged tray.... everything meets here. Now I need to wrap the wires The SSD steering links were a major disappointment , but VP was not to be seen. The fix was to make my own drag link and use 16 mm setscrews to keep the tierod together.( First time a piss poor response from RPP) I will replace it with the VP as it matches the other links then My Savox worked well, but not enough 277* @.15 moderately fast with 2.2,6" tall tires at 8v I'm getting 388* @.06 With a $50. Taiwanese servo ! I'm waiting on a Promodeler 420, but found this Servo and took a shot.... WOW !! I am running the soft HR sway bar up front, but not out back.... Yes I have insane flex , thanks to 5" shocks front and rear, with the AMF brackets to get things working Hang up and Drive Last edited by mikemcE; 04-29-2017 at 11:03 PM. |
05-01-2017, 04:55 PM | #31 |
| "OPIE"
And now the new Heart..... Oh my !!!!! Sooooo Smoooooth !!! Thanks Mike !!!! Hang up and Drive Last edited by mikemcE; 05-01-2017 at 05:11 PM. |
05-04-2017, 06:29 PM | #32 |
| "OPIE"
Ok...... I'm beefed up and need new power.... Holmes PP3500 or Roc412 3100...... Which way to go ?? I love my 4x4HD but it's too big. I'm upgrading from a tekin17.5 gen 3 Because I need torque and wheelspeed faster than the two pole tekin Hang up and Drive Last edited by mikemcE; 05-04-2017 at 07:47 PM. |
05-05-2017, 01:16 PM | #33 |
Pebble Pounder Join Date: May 2016 Location: Warwick
| Re: "OPIE"
Looks sweet! Got my hands on a used Wraith yesterday which looks well used but pretty modded out. You're build is giving me some motivation for other ideas though keep it up!
05-05-2017, 03:00 PM | #34 |
| Re: "OPIE"
Looks like a PP is coming from RPP 3500 flava should keep things interesting |
05-08-2017, 05:39 PM | #35 |
| "OPIE"
WOW!!!!! Unbelievable difference, just as smooth as the Tekin, but 5 times the torque!! New word .... Violent! That is what this motor is, unbelievable power, thought about the 2700, I am totally happy with this one. I'm going to run it with the 12t and then swap in a 11t pinion. I'm thinking a bit slower, but still a monster. Hang up and Drive Last edited by mikemcE; 05-08-2017 at 06:14 PM. |
05-13-2017, 11:00 AM | #36 |
Rock Stacker Join Date: Dec 2016 Location: Las Vegas
| Re: The Slider will this extend the shocks the same as the one you used? Wraith Front Shock Tower - BGR Fabrications Wraith Rear Shock Tower - BGR Fabrications I just picked up a wraith and looking for more flex for sure. I really do not want to do the belly up mod due to keeping the interior. That is why I love the wraith for the scale. |
05-13-2017, 12:04 PM | #37 |
| Re: "OPIE"
Actually those are much nicer, should work great and look killer ! Hang up and Drive |
05-13-2017, 12:56 PM | #38 |
| Re: "OPIE"
To get the same flex would o gain anything by using a set if bomber shocks? Or do I need to go longer? Sent from my SAMSUNG-SM-N910A using Tapatalk |
05-13-2017, 01:10 PM | #39 |
| Re: "OPIE"
I'm using long , back shocks for a yeti on all 4 corners, 5" Hang up and Drive |
05-13-2017, 02:16 PM | #40 |
| Re: "OPIE" |
"OPIE" - Similar Threads | ||||
1/10 slider | c0astie31 | Non Crawler RC's | 1 | 02-28-2009 12:15 PM |
