05-13-2017, 06:50 PM | #41 |
| "OPIE"
bit of practice time
05-16-2017, 07:08 PM | #42 |
| "OPIE"
I've now run 6 full packs. Tightened the slipper up all the way, still doing that as it's still seating, getting better and better. Running a 12/56 with the 3500, I just watched Josh/aka Coleman set up his, tried a few things and got more violent !! I had a tremendous tendency to do a torque wheelie before, even with the centered rear, Now it just does violent controllable wheelies on full throttle, but will walk with a blip! JRH actually recommended the 3500 over the 2700 except for crawling only ... I can see why.I look forward daily to just waste a battery running the creek bed and jumping the bank All this is now being caught with my GoPro , will edit some footage soon,once I figure out the technical end of video( I'm a stills guy) but sure is fun Hang up and Drive Last edited by mikemcE; 05-16-2017 at 07:10 PM. |
05-17-2017, 06:26 AM | #43 |
Rock Stacker Join Date: Dec 2016 Location: Las Vegas
| Re: "OPIE"
are these the shocks you are using up front? Pro-Line 6275-00 PowerStroke XT Shocks 5" Axial Yeti Rear / Axle Monster Truck |
05-17-2017, 06:30 AM | #44 |
| Re: "OPIE"
Yep, I also have the spring kit for it Hang up and Drive |
05-17-2017, 06:31 AM | #45 |
| Re: "OPIE" |
05-17-2017, 06:36 AM | #46 |
| "OPIE" http://www3.towerhobbies.com/cgi-bin...aTmxoCFLPw_wcB Great shocks, they will work well on all 4 corners I have these also on my Yeti , I think I'm running dual blues but can't remember. I have them set quite soft and love the feel. I'm using the stock Yeti rears with metal caps out back, not quite as smooth, but work well w/o a sway bar. Hang up and Drive |
05-17-2017, 03:11 PM | #47 |
| Re: "OPIE"
Yup I thought so. Double blues ( softest sets) The upper is preload, mine is perfect Hang up and Drive |
05-17-2017, 06:03 PM | #48 |
| "OPIE"
Had a bit of time before dinner, ran the railroad tracks, saw a mountain (Hey it's Florida!) And went up ..up....up... and over ! Holmes Powah ! Hang up and Drive |
05-20-2017, 02:47 PM | #49 |
| Re: "OPIE"
Well I'm in a quandary , but quite pleasant ! I was out today running OPIE by the tracks again, and I had a blast trailing at speed. The front sway bar worked great, but was curious about flex and my rocks. Went over to a rock with a steep pitch , but a dent for pumpkin clearance , BOOM .... up we went ! Now I was curious,so I disconnected the links, tucked the arms up, and had full flex, great on the rip rap ! This rig will creep up a loose hill or fly over the ridge and land and go. Hang up and Drive |
05-26-2017, 06:17 AM | #50 | |
| Re: "OPIE" Quote:
05-26-2017, 06:31 AM | #51 |
| Re: "OPIE"
Thanks, but always changing. Installed a WertyMade stinger with side rails and will lose the front mount for now, I did put it out back, time will tell. I'm just tryin to have fun, this build is a gas to drive so far, with the exception of the servo. I'm being patient on the ProModeler , but really need it Hang up and Drive |
05-26-2017, 08:46 AM | #52 |
Quarry Creeper Join Date: Oct 2016 Location: Hanover
| Re: "OPIE"
Looking good bro! I may have missed it, but how much articulation can you get with those long shocks? I'm running much shorter shocks, 93mm, and was surprised to get 5.5" of flex with them. And I'm telling you bro - look into the Savox 2290SG. It's a beast! |
05-26-2017, 08:55 AM | #53 |
| Re: "OPIE" Hang up and Drive |
05-26-2017, 09:38 AM | #54 |
| Re: "OPIE"
Thanks! I was actually looking for the measurement. How tall is that WD40 can?
05-26-2017, 09:43 AM | #55 |
| Re: "OPIE"
Not at home now Hang up and Drive |
05-26-2017, 07:03 PM | #56 |
| Re: "OPIE"
That's got 6 3/4" the front has a smidge less Hang up and Drive |
05-27-2017, 01:16 PM | #57 |
| "OPIE"
Made a servo choice. Went with the Holmes HV500. I put the ProModeler in the truck, and honestly need 500 oz with these ruptures to wiggle on a high traction surface. I was very surprised , to put it mildly ! Between the Savox 2290, Futaba 9177 I could get 600oz for $150. got 500 for $85. With RPP's Memorial Day sale 15% off. Hmmmmm this is really getting HEAVY, I have to weigh in, I'm close to 9lb easy That does explain why the PM is struggling a bit, no I'm not going to diet ! All the aluminum , MIPs Robinson slipper , Werty front ...... yup ! Hang up and Drive Last edited by mikemcE; 05-27-2017 at 05:59 PM. |
05-29-2017, 02:18 PM | #58 |
Rock Stacker Join Date: May 2017 Location: London
| Re: "OPIE"
Great build mikemcE. Lots of interesting and useful details I have picked from it. Thank you for taking the time to share.
05-30-2017, 08:37 AM | #59 |
| Re: "OPIE" |
05-30-2017, 09:13 AM | #60 |
| Re: "OPIE"
Nope no bars at all Hang up and Drive |
"OPIE" - Similar Threads | ||||
1/10 slider | c0astie31 | Non Crawler RC's | 1 | 02-28-2009 12:15 PM |
