01-10-2013, 05:58 PM | #141 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
| Re: Hittman's SWITCH build
ya i run alot of sag in my truck as well. well ill tell u if 3 holes down works lol
01-10-2013, 05:59 PM | #142 |
all my motors are at hh now getting new cans an rebuilds so im down for another few days
01-10-2013, 06:07 PM | #143 | ||
| Re: Hittman's SWITCH build Quote:
And for sure. I love my Holmes motors in all my rigs. I thought about trying the Broods and had them installed, but just couldnt | ||
01-10-2013, 06:14 PM | #144 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Hey since when did they let you drive with some screws and stickers and call it a chassis? Looking good bro |
01-10-2013, 06:16 PM | #145 |
| Re: Hittman's SWITCH build |
01-10-2013, 06:27 PM | #146 |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
Damn BRO!!!! That bitch looks planted. I have a question for ya. How are those upper CF links holding up? I just did something very similar to what you have. Did you pin the rod ends or did you just us an adhesive of some sorts? I used a 2 part epoxy and mine are on for good.
01-10-2013, 06:33 PM | #147 | |
And they are holding up great. No problems at all. I attached them to the rod ends with jb weld. Then I put a small bead of glue around the bottom of the end once the jb weld dried. They hold up just fine. On my sporty I run 1/8" carbon rod with 3mm rod ends. Suprisingly they have held stong too. They are significantly lighter, but have mild flex. And since this rig has dig, I didnt want to run into problems, So thats the reason I used the 4mm rod.. | |
01-10-2013, 06:51 PM | #148 |
Yea that is the same reason why I went with the 4mn rod. I really want to get mine out an run it in a really bad way. But every time I get a break in the weather I always seem to be working. On my days off it just does nothing but snow. The CF links really do lighten it up alot, when ya get into the lower part of the 4lb range it isn't easy or cheap to drop as much weight as I did when put those on. I think I lost around an ounce an a half. BTW that clear chassis looks bad ass. What would be cool as hell to do is paint it with that transparent paint like what Mr Vertical did on his lid and his poly wheels. Last edited by redrokin00XJ; 01-10-2013 at 06:54 PM. |
01-10-2013, 06:55 PM | #149 | |
They are very light comared to Ti links. When you get into the upper 3lb range that is when things get REALLY expensive.. but o well, its fun Thanks.. I was thinking about some paint.. but I just cant convince myself to add that much weight to it | |
01-10-2013, 07:50 PM | #150 |
01-10-2013, 07:55 PM | #151 |
01-10-2013, 07:58 PM | #152 |
i ran 1/8 ties on mine this week an beat the shit out of them with 3mm ends on them
01-10-2013, 08:18 PM | #153 |
01-10-2013, 09:27 PM | #154 |
RCC Addict Join Date: Jan 2009 Location: O.C
Definitely different. Hopefully all of the Poly holds up for you. Way to try a different setup and have it work for ya. |
01-10-2013, 09:36 PM | #155 |
| Re: Hittman's SWITCH build Thanks man The rig took another fall straight on the roof today.. This time only like 3ft or so.. And everything is fine. Dlux al. spacers are getting ordered tomorrow so that should help out some |
01-10-2013, 11:29 PM | #156 | |
I don't think you'll have a problem at all with that poly.... My guess is that poly is just fine. Other wise I don't think Erik would sell it if they wouldn't hold up. He sells that Hall Chassis in poly.... Nothing looks cooler then someone thinking outside of the box IMO Last edited by redrokin00XJ; 01-11-2013 at 12:18 AM. | |
01-11-2013, 12:35 AM | #157 | |
Exactly.. Why would they sell it if it didn't hold up.. I do have to agree with you there | |
01-11-2013, 03:22 AM | #158 |
01-11-2013, 11:24 AM | #159 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
| Re: Hittman's SWITCH build If they are TI you can electrically anodize them... ive done it before and the effect is stunning oh and it adds no weight! True fact: On formula one cars they use specially engineered "light weight paint" and put on like a FRACTION of the paint they put on a regular car. Its pretty insane. I can see Hittman doing the same |
01-11-2013, 12:02 PM | #160 | |
HAHA even that is still too heavy for him | |
Hittman's SMASH Build - Similar Threads | ||||
Hittman's Featherweight Sporty | Hittman | Axial AX-10 Scorpion | 104 | 05-19-2013 09:08 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
Hittman's mini | Hittman | Losi Mini-Rock Crawler | 17 | 10-01-2012 07:00 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
