05-30-2013, 01:30 PM | #61 | |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
| Re: Everett's NCD SuDu "Pro"totype Quote:
TOM | |
05-30-2013, 01:45 PM | #62 | |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Now I just need more shrink tube and to get this programmed and I'll be out running some more Last edited by EverettY; 05-30-2013 at 01:47 PM. | |
05-30-2013, 04:18 PM | #63 |
RCC Addict Join Date: Jun 2009 Location: Australia
Hey mate. Now you tuning and programing youy new radio. A tip Hulksta once gave me that is good and as you using MSW's i thought might be worth doing if you usibg Harleys vid thread to help program is. When setting the proportional increments of the variable drive, instead of using 10% increments use 5% with the MSW's as you get better fine control. I used it after Dan advissed me and it helps alot. Ben Sent from my GT-I9300 using Tapatalk 2 |
05-30-2013, 07:12 PM | #64 | |
Agreed! I run mine at 5% increments with my BRXL's | |
05-31-2013, 08:11 PM | #65 |
OK so got a question... Put in the new RX programmed up the 4PKS according to Harley's guide but now I gotta a few problems... First I turned it back on and the servo is jittering slightly and it got really hot in less than 30 seconds (so hot I could burn my hand on it) Also the rear motor isn't working... It's acting like it's in dig when it's not anyone know what the problem is? Thanks |
05-31-2013, 08:25 PM | #66 |
When you armed the esc's did you do both together or front tand rear seperatly? Some people for some reason where others dont need to have a common negative bond to prevent a jittering servo Sent from my GT-I9300 using Tapatalk 2 Last edited by Oz Bruiser; 05-31-2013 at 08:29 PM. |
05-31-2013, 09:12 PM | #67 |
| Re: Everett's NCD SuDu "Pro"totype |
05-31-2013, 09:49 PM | #68 |
Try doing it with just the rear esc. So its the only one being controlled. I and a mate had an issue with a MSW where the rear wouldnt arm correctly. By isolating the front you only worrying about one esc. Sent from my GT-I9300 using Tapatalk 2 |
05-31-2013, 11:42 PM | #69 | |
I've got a STUBBY! Join Date: Apr 2011 Location: Newcastle Australia
When you first turned it on did you push the front dig button as the radio will only signal th channel until you push the button. Hope this makes sense. Josh | |
05-31-2013, 11:54 PM | #70 | |
Also one thing... When adjusting variable dig on mine it's reversed so it only works when in reverse but not forward... How do I reverse that so it works when it's forward? | |
06-01-2013, 12:08 AM | #71 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
You gotta great deal but since you already have & know the 4PL...why not sell the PK & make a little extra cheddar on the side? BTW I have no idea whats wrong with your setups. I follow Josh's thread & its always worked fine for me. Did you get some play-dough on it or maybe when you were playin GI Joes, you dropped it on your Toy Story bed & it broke when it hit your Mickey Mouse slippers. Ha! Ya kid!!!! JD |
06-01-2013, 12:18 AM | #72 | |
I have no idea... I'm thinking I'll try setting it up again and see if I missed something And noo never had a themed kid bed Ha! Ya Adults!!! | |
06-03-2013, 11:06 AM | #73 |
06-03-2013, 11:34 AM | #74 | |
| Re: Everett's NCD SuDu "Pro"totype Quote: Ok... I'll try this RX again and see what happens... I ran the RX in a different truck yesterday with absolutely no issues... My bro was thinking my BEC might be overvolting the servo... Cool I'll try it how it is and if I need it I'll put one on | |
06-05-2013, 03:16 PM | #75 |
Ok so got it all back together again and everything works but the servo... (Thanks Ben for the advice about arming it individually that fixed the ESC problems ) The servo still jitters though... It got warm but not hot... Could it be the RX? Or maybe BEC overvolting it?
06-05-2013, 03:42 PM | #76 |
Did you try making a common negative between the esc's, servo and bec. I did'nt have to do this. Others i know have had to. I dont know why some rigs are effected and others not. Sent from my GT-I9300 using Tapatalk 2 |
06-08-2013, 04:12 PM | #77 |
Quarry Creeper Join Date: Feb 2012 Location: Alphen Aan Den Rijn
Hi everett do you have a list of the aluminium screws i need for the xr 10? Thanks for your time
06-08-2013, 04:18 PM | #78 |
Yes made this up last year... I think this is just for the axles if I remember correctly M3x18m Button Head 16x M3x10mm Button Head 12x M3x8mm Button Head 1x M3x15mm Button Head 2x M3x20mm Button Head 4x Button Head = x35 M3x12mm flat head 4x M3x10mm flat head 7x M3x15mm flat head 3x M3x16mm flat head 3x M3x18mm flat head 4x M3x20mm flat head 1x Flat Head x22 M3 Hex nut 25x |
06-11-2013, 11:11 AM | #79 |
Quick update... Haven't gotten the servo issue fixed cause I haven't had time as I am now working over the summer but still getting mail and got these in the mail 1.9 Rovers Made into 2.2's... Pitbull Rock Beast II sidewalls on it with custom C.I. DD Foams. Comp Cut inners with soft outers front and medium outers rear... Rusty (Rockpayne) needed some motors from me so we worked out a deal for the motors for some 3 piece wheels so I'll be putting these on about .6" wheels... Looking forward to trying them I still need to make the 2nd pair when I get a chance... I flipped the pics but they are still showing up sideways for some stupid reason Last edited by EverettY; 06-11-2013 at 11:13 AM. |
06-11-2013, 11:27 AM | #80 |
I was just talking to CI about foams. I asked if comp inners with soft outers in the front and medium in the rear would be good and he told me soft rears and medium fronts. You seem to think like me...
Everett's NCD SuDu "Pro"totype - Similar Threads | ||||
LaaLaa's NCD SuDu Pro-totype | laalaa | Axial XR10 | 124 | 06-12-2014 02:59 PM |
NCD SuDu Pro Down Under... OB New Pro Build. | Oz Bruiser | Axial XR10 | 142 | 10-02-2013 03:50 AM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
"brushless review "ccmicro pro" vs "novak mong". | ROLANDROCKSHOP | Losi Mini-Rock Crawler | 22 | 11-15-2009 08:27 PM |
