08-31-2014, 08:09 PM | #101 |
Rock Crawler Join Date: Mar 2012 Location: bel air
| Re: Got my Yeti today, not impressed at all so far...
id rather just get the right hub so i dont have 2 sets of bolt holes.. if possible. do you remember when cragers came double drilled for chevy and ford bolt circles? i always thought they were silly and i dont wanna have em' on my truck... thats what i meant dude... i ground the holes pretty close. another idea would be a cheesy track widener hub to just use 12mm hexes |
08-31-2014, 08:23 PM | #102 | |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
| Re: Got my Yeti today, not impressed at all so far... Quote:
I wish my pre-order one would come with all that cool stuff for $430 too. | |
08-31-2014, 08:24 PM | #103 |
I dont remember double drilled, but I do remember the 'universal' ones that had the oval holes. Now that was silly...
08-31-2014, 08:29 PM | #104 |
| Re: Got my Yeti today, not impressed at all so far... I remember my artr Scorpion. $280 for chitty tires, weak driveshafts, fragile knuckles and chubs, no electronics, leaky shocks, a really poor turning radius, and trans outputs that snapped quite easily. But damn was I happy to have it...
08-31-2014, 08:48 PM | #105 |
I think people are missing that the Yeti is a different animal. It's a basher/racer and because of that, it is probably going to see a lot more abuse than the average rig. How many people want to toss the Yeti electronics in their scale rig and take it to the local BMX track or skate park? Do you think even a well built scaler would survive? You can do those things with the Yeti and you know what? It's FUN! People hoping to have a real capable crawler from one might be disappointed. You can't Really expect a low CG car that handles on the track, with a pan chassis, to perform great in technical rock. But that isn't what it was designed for. |
08-31-2014, 08:52 PM | #106 |
If people keep whining they should price something like the Losi SCTE 2.0 and get that to RTR status. $470, no body, no wheels, no tires, no motor, no pinion, no esc, no radio, no servo and you still have to put it together.
08-31-2014, 08:59 PM | #107 | |
its fine in the rocks if setup for it..lock the front diff and disconnect the swaybar. the 20 or so minutes mine was running was in rocks and roots.. tight and technical like an scx, no way, but using a bull in a china shop "when in doubt gas it" driving style blasted me over some cool ledges with better control than my wraith. its just gonna need some tinkering to get it right | |
08-31-2014, 09:28 PM | #108 |
Pebble Pounder Join Date: Jan 2005 Location: B-town
Blk xj actually drove my truck on Friday. And he was absolutly right I didn't check a single screw, ran about 6-7 packs through it so far, only thing that happened was a small piece of plastic about the size of a grain of salt made its way into the spur and had the same noise you described. 30 second fix for me. The truck does handle good I feel. I think the reason it doesn't handle flat dirt roads as good as blk xj was expecting is because it has a locked rear axle, and an unlocked front. So the back end will naturally be more loose then the front. I thought that made it fun to drive. I don't see how anyone can complain though, just to be honest. You are in the hobby of money spending. I just bought the truck, brought it home, and spent another 170 bucks in aftermarket parts the next day, with many many more dollars to spend. In the end of the day it's just like any other axial.... Almost badass out of the box, it just needs a few extras to make it perfect. And no other manufacturer even comes close to that. |
08-31-2014, 09:57 PM | #109 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
So, according to the Axial website, the transmission gears are sintered (heated and compressed metal powder). They should be strong enough, but clearly they will need to be inspected for proper alignment and thorough greasing in every vehicle prior to being run. That's kind of a letdown, but honestly, it's not any worse than the plastic gears that come in the Wraith.
09-01-2014, 06:49 AM | #110 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
I can see RRP coming out with an HD trans gear set if this truck takes off like I hope that it does. I am looking forward to seeing what mine can do once the new hubs come. In the meantime while I am waiting, I am tearing it all down, re-greasing the trans and putting threadlock everywhere it's needed. Got to give it a better chance for round two... I agree that I loved the R35 ripsaws on my Wraith, but I am going to try the Maxxis Trepador tires in R35 on this rig. They will be here later this week as well. |
09-01-2014, 07:31 AM | #111 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
I stripped a rear hub yesterday on my second battery pack, I had it bound up a few times, and throttled out. Would have been nice to see the plastic hubs with a 12mm hex molded in rather then the cross pin. I'll have to get some aluminum hubs now, can't wait to get this truck back on the rocks again, is a blast. I was making some impressive lines in my rock pile. |
09-01-2014, 08:24 AM | #112 | |
Quarry Creeper Join Date: Jul 2007 Location: Australia
Do you mean these?! ;) | |
09-01-2014, 08:51 AM | #113 |
| Re: Got my Yeti today, not impressed so far...
You just run the hexes with no spacers? I was gonna use 25mm wideners on the rear and just go hex all the way around and scrap the plastic hubs all together Sent from my iPhone using Tapatalk |
09-01-2014, 09:36 AM | #114 |
| Re: Got my Yeti today, not impressed so far... I've got standard Axial alloy hexes up front and 20mm?? wide hexes on the rear as well as having the rims offset (gearhead rims can be reversed for different offsets) deeper, it works out that the rear is about 5mm total wider...
09-01-2014, 09:41 AM | #115 |
| Re: Got my Yeti today, not impressed at all so far... |
09-01-2014, 10:23 AM | #116 |
Newbie Join Date: Sep 2014 Location: wv
I received my Yeti on Friday and got three 3S 5000mah packs on it before the plastic hubs let go. I checked and tightened everything before hand. In the Yeti's defense, my daughter and I beat it to death at the local track. We were both very happy with how fun it was to drive and don't regret buying it. I have VP hubs, hexes and steering parts on the way. |
09-01-2014, 10:28 AM | #117 | |
I wanna be Dave Join Date: Sep 2005 Location: *
Did you reverse the fronts or rears??? Those are the wheels I'm using... Never mind I see what ya did there lol Sent from my iPhone using Tapatalk | |
09-02-2014, 12:29 PM | #118 | |
Rock Stacker Join Date: Jul 2013 Location: Somewhere
The reality is the Yeti is a pretty darn heavy truck for something that is made of mostly plastic. I like the Yeti, I plan to get the Yeti kit when it is available, but a truck that heavy with that much plastic has me concerned about long term durability. | |
09-02-2014, 01:41 PM | #119 |
im back.. no real internal "damage" to the transmission making the grinding noise, but i was MISSING a bearing. the idler bearing shaft was only supported on 1 side... after a few minutes i guess it wiggled out of alignment and CRUNCH noise here we come.. i threw a spare traxxas 5x11 in and im back in motion crunch free.. well, mostly. as soon as i grind down the front c-hub screw to clear my wheels im gonna go test run it.
09-02-2014, 01:43 PM | #120 |
Glad you were able to fix it. Makes me glad mine was only missing a lower spring cup.
Got my Yeti today, not impressed at all so far... - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
water yeti.. calling all yeti owners | going2fast | Axial Yeti | 11 | 11-02-2014 05:43 PM |
Wait for a Yeti or get a Slash 4x4 Ultimate today? | BIGNASTY | Chit Chat | 19 | 08-30-2014 10:54 PM |
Yeti captured today | im gunna crawl | Axial Yeti | 4 | 08-28-2014 08:58 PM |
I drove a Yeti today. | Dirt51 | Axial Yeti | 1 | 07-12-2014 08:15 PM |
