08-03-2015, 10:39 PM | #161 |
| re: I need help - we todd did
Diagnostic tubes were outlawed years ago....
08-03-2015, 11:15 PM | #162 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
snaponboy its 22R with a Weber carb, no smog nothing its all gone the O2 sensor is still in the exhaust manifold and it is still connected to the ignition control module and is working and functioning properly there is about 2 feet of exhaust between O2 sensor and Cat the Cat mounts under the drivers seat under the cab there is heat shield welded to cab so the cat goes in that area then after the cat there is pipe and a muffler the previous owner could not get it to pass smog and whole system needed replaced I removed the smog crap then installed a Weber carb, and left the cat and O2 alone and in the county I live in Nevada there is no smog and its legal for me to remove the crap I sell the truck to another person in my county or another person in a county in Nevada that has no smog, there are a few in Nevada cause I asked at a used car lot next to the muffler stop that's why I'm putting the cat back on to be legal Last edited by kgb424; 08-03-2015 at 11:35 PM. |
08-03-2015, 11:32 PM | #163 | |
| re: I need help - we todd did Quote:
For the price of a the crap going into this project a harbor freight welder could be in the gatage and some parts store exhaust bends could have already been boogered under the truck. | |
08-04-2015, 12:35 AM | #164 |
that would be a waste of money and my time I don't know how weld or even tack with a wire feed welder and again I want to clamp it so it comes apart cause sooner or later I'm going to need to replace the clutch and why would keep cutting it and have keep re-welding it back together when I can unclamp it and pull it apart and then clamp it back together and the truck has always ran rich so that could have a lot to do with the cat and muffler plugging up Last edited by kgb424; 08-04-2015 at 12:40 AM. |
08-04-2015, 12:54 AM | #165 |
I got maybe less the $200 buck it in and the last shop I went to when I had problems with my 95 GMC with a 6.5 liter diesel was not Marks, it was a RV repair place the only place in town that work on diesels, he was out of town on a family problems wanted to charge me $90 dollars a hour, there was a minimum of 2 hours Mark only charges me around $50 to $60 for labor and fixed it in half the time the other place quoted me I buy my own parts and bring them with me to save him time of not having to order parts and my trucks are usually down a few hours to a few days and all the parts I have replaced have saved me money cause Mark is not charging me to replace them or some other shop and I saved money on the labor too, by doing a lot of it my self my Time I got nothing but time I can't work my back has permanent nerve damage so working on the truck is believe or not is in enjoyable to me cause I love working with my hands just don't get too do it all the time that's why it takes me forever to finish a RC out cause once it down I got nothing to work on Last edited by kgb424; 08-04-2015 at 01:12 AM. |
08-04-2015, 12:57 AM | #166 | |
If it always ran rich, then there's half yer problem. The exhaust unbolts from the collector on the manifold and again at the cat (front and rear). Too rich washes down the cylinder walls and wears out rings quickly....also runs like chit, wastes gas and will choke you out at traffic lights or while crawling down a sweet trail. | |
08-04-2015, 03:08 AM | #167 |
Quarry Creeper Join Date: May 2009 Location: India
kgb424, Thanks for posting that pic. I imagine, it could be a nice 1:1 crawler. |
08-04-2015, 07:50 AM | #168 |
nope the cat was welded on both sides so I had to cut it out that's why I want to clamp the exhaust to together no cutting or welding needed Last edited by kgb424; 08-04-2015 at 07:53 AM. |
08-04-2015, 10:43 AM | #169 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
Hate to see what happens when a light bulb doesn't work |
08-04-2015, 04:33 PM | #170 |
My dad left me a Lincoln 225 ac arc welder and a oxygen an propane gas welder setup that was used for heating and bending and cutting more than welding I was going to buy a MiG / wire feed welder and the bottle setup to weld aluminum but I decided that I would not use it enough to justify spending a few hundred dollars on a welder and not us it Last edited by kgb424; 08-04-2015 at 04:38 PM. |
08-04-2015, 09:11 PM | #171 |
Pebble Pounder Join Date: Jul 2009 Location: Australia
My welder has been the most usefull thing i have ever bought. If you where near me i would buy that truck. Lift it, put it on 33's, paint it black,put a 3rz in it and do a replica of marty mcfly's truck. |
08-04-2015, 09:53 PM | #172 |
McFly's Toyota was a 85 mine is a 87 different grill and body style I traded a 84 Toyota truck that I blow up the clutch and when the clutch went so did something in the tranny and didn't want to put another $1000 in it for a new clutch and maybe a rebuilt tranny My mechanic Marked wanted it badly for his son 16th birthday we traded won't give details his son didn't want it so Marks keeping it for him self to drive if he ever gets the time to work on it and tear down the tranny and see what's broke cause there was a loud bang some grinding noises then nothing just the motor making a change in pitch cause the load from the tranny was gone the engine just freewheeled no clutch no forward no reverse no tranny Mark pulled the inspection plate for the clutch and the was no clutch disc and he could see chunks of chewed up metal so something happened to the clutch and tranny Last edited by kgb424; 08-04-2015 at 11:17 PM. |
08-04-2015, 10:17 PM | #173 |
Still basically the same shape though. I found this one on the side of the road on a property, i approached the bloke but he wouldnt part with it. It was destined to be a Mcfly truck. It's still sitting there so maybe i can talk him around one day. I just love the fat boxy look of the older hiluxes. The one i found also had the same yellow paint and shitty 80's graphics mine has. These trucks respond well with a 3rz in them. Not an overly hard conversion and ten times nicer to drive. |
08-04-2015, 11:22 PM | #174 |
When I was working construction and had to commute to work I bought a 82 2 wheel drive Toyota pickup with a 22RE and drove the shit out of too until I got hit head on one night sitting at red light with my buddy in the truck a guy jump an island and was doing about 50 plus miles per hour I seen him coming at the last minute and could not get my seatbelt and door open fast enough the truck was pretty much done I sold it to a salvage yard for what I paid for it Last edited by kgb424; 08-05-2015 at 03:53 PM. |
08-04-2015, 11:43 PM | #175 |
one of my neighbors had 78 or 79 Toyota Hilux and I asked him for years to sell it too me he always said no they ended up moving and the truck was gone Last edited by kgb424; 08-04-2015 at 11:45 PM. |
08-05-2015, 11:38 AM | #176 | |
With all of the emissions equipment ( crap, as you call it ) and stock carb gone, it ISN'T working properly. The system has been torn apart so it will no longer function. This is what a few people are trying to get you to understand. | |
08-05-2015, 02:52 PM | #177 | |
Yep. | |
08-05-2015, 02:55 PM | #178 |
none of the smog equipment worked when I got the truck the stock carb is still screwed up, I could not find anyone to rebuilt it and if I did, it still would not work correctly cause none of the smog bullshit worked because it would cost more to replace to the smog equipment then the truck was worth that's why the previous sold it too me and could not get it smogged in California and was denied an exemption I live in a county in Nevada that there is no smog and it is perfectly legal for me to remove no functioning smog equipment , I asked a few times and was I told its legal to remove the smog bullshit that's why I left the 02 alone, because it part of the ignition control module I know it would run even shitter with out a 02 sensor and I bought a replacement catalytic converter and here in Nevada there are a shitload of desert trucks and rock crawlers and off road stuff, driven on the highways and city streets with all the smog bullshit removed and the catalytic converter cut out running Webers and Holleys and Elderbrocks and some have mufflers some don't, some got spark arresters some don't and its all good here in the desert and its run what you brung and the truck has ran a 100 percent better with the weber then it did with the stock carb it won't even idle that's how ****ed up the truck was and it would keep stalling and really hard to start so by me removing dead smog equipment and throwing on a Weber I made it drive able again and have driven it for a little over 3 years without any major problems until now and the Truck has got to be close to hitting 300,0000 miles I can't tell you what the mileage is, cause I changed out, the original instrument cluster for one from a SR5 Land Cruiser that has a Tachometer and it had 200,0000 miles plus on it plus the 3 years of me driving it so it was time for the catalytic converter to go out same with the original ignition coil I replaced Last edited by kgb424; 08-05-2015 at 03:35 PM. |
08-05-2015, 03:21 PM | #179 |
Quarry Creeper Join Date: Jan 2012 Location: winder, ga
[QUOTE=kgb424;5274295] I got head one night sitting at red light I seen him coming at the last minute and could not get my seatbelt and door open fast enough |
08-05-2015, 03:24 PM | #180 |
Lol
Tags |
dafuk? |
I need help - we todd did - Similar Threads | ||||
The Increasingly Poor Decisions of Todd Margaret | JeremyH | Chit Chat | 11 | 10-03-2010 07:00 AM |
