08-03-2015, 03:13 AM | #141 |
Rock Stacker Join Date: Aug 2014 Location: United States
| re: I need help - we todd did
That's called vapor lock. It's possible. It's not likely unless everything is really hot... If you have fuel lines running across your exhaust manifold, then yeah... |
08-03-2015, 08:12 AM | #142 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
the fuel pump in the is on the side of the cylinder head and runs off the cam cause its mechanical and was getting hot enough that you can not leave your hand on and it sounded like the gas was boiling in the fuel pump now it runs cool to the touch and there is no noise, no longer boiling cause the old thermostat was stuck open a little, replaced it with a new one and I had way to much coolant to water ratio in the radiator, almost all coolant that the boiling was almost maxed out on the scale of the Presstone radiator checker thing not sure the name of it, but its shows your boiling point of your radiator on side and your radiator freezing point on there side and now its more in the middle and closer to 50/50 ratio cause it 80/20 before I Changed coolant Last edited by kgb424; 08-03-2015 at 08:17 AM. |
08-03-2015, 10:34 AM | #143 |
Quarry Creeper Join Date: May 2009 Location: India
kgb424, If possible post a pic of your Toyota. |
08-03-2015, 10:37 AM | #144 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
Oh dear god---something attached to the motor and its getting hot---say its not so |
08-03-2015, 12:21 PM | #145 |
ok I just drove the truck at 45 to 50 miles an hour around my neighborhood for 15 to 20 minutes and after driving the truck, you can touch the fuel pump its cool to the touch and the top of the radiator is no as hot either and it did not run rough or sputter or back fire and it had power and didn't fade then start running rough and then would sputter and backfire I did not do a high speed run so that tells me it was running way too hot and then the carb would cut out it ran fine today Last edited by kgb424; 08-03-2015 at 12:24 PM. |
08-03-2015, 05:10 PM | #146 |
now I'm pissed off I went to a 2 different muffler shops to get a estimate on a price for a short piece of exhaust pipe and small muffler/ glass pack and maybe tack on a couple supports and both places told me, its against a federal law to work on my truck and told me I had to replace the catalytic converter Mark say that's bullshit cause he will put a bolt on exhaust pipe with a muffler/ glass pack I want to move the end of exhaust from under the cab to back under the bed and call it good with no tail pipe just need to pick the right sized muffler/glass pack so that it sounds good and not like the assholes that have watched the Fast an Furious one too many times you can hear from blocks away you think it something bad ass turn out to be lowered piece of shit , Honda or Toyota Last edited by kgb424; 08-03-2015 at 05:20 PM. |
08-03-2015, 05:15 PM | #147 |
That's not bullshit, that's the law. If your buddy wants to break the law, it's his choice. They cannot remove federally mandated smog equipment.
08-03-2015, 05:30 PM | #148 |
Quarry Creeper Join Date: Jan 2012 Location: winder, ga
| re: I need help - we todd did Clamps, pipe, hangers, muffler. No need to take it to a shop. The truck is probably only worth what they will charge. But you wont. 8 pages of this Last edited by donny8594; 08-03-2015 at 05:32 PM. |
08-03-2015, 05:38 PM | #149 |
| re: I need help - we todd did Not only can they not remove it...but they can't work on the exhaust unless it is repaired back to legal operation.....i worked at and ran an exhaust shop...no owner or employee wants to go to jail for you. Period. It IS the law no matter what you or your mechanic buddy think.
08-03-2015, 06:03 PM | #150 |
Pebble Pounder Join Date: Jul 2009 Location: Australia
It's a 10,000 doallar fine for not having a cat here if you get caught. By this stage i would have had a set of sidedraft mikunis on there, some extractors and a warm cam. Anyway Motors dont respond well to just having random things done to them, especially old motors. Sounds like you need to find a mechanic that actually knows what he's doing to go through it. Driving it and running it when its going like shit can damage other parts of the motor. If youre that keen on getting the engine running do it properly. Get the carb rebuilt, to begin with if you know it's leaking. |
08-03-2015, 07:23 PM | #151 |
What year is it? If it's older than 1995, then tell them to just do it. If it's newer... You might need to slip them a few bills for them to look the other way while doing the work.
08-03-2015, 07:42 PM | #152 |
If it came with a converter the it has to have it put on....from 1976 up.....federal law
08-03-2015, 07:42 PM | #153 |
ObdII has nothing to do with it....
08-03-2015, 08:01 PM | #154 |
ok its totally my fault I cut the catalytic converter off after is was suggested by a few people and it was a good call cause the converter has been melting and the melted crap plugged up the exhaust in the muffler |
08-03-2015, 08:26 PM | #155 |
so just to show I'm not a total asshole and care a little about the world but not the other assholes on the planet and so I can sell the truck maybe for 75 bucks and the ride I found this at Parts Geek its almost the same length as the one I cut still going run a short piece of exhaust pipe and a small muffler kind of like this Flow Master not the right one for my truck, but that's style I want up out of the way I will need to talk to Mark and find the right muffler cause he has venders and gets good deals on parts sometimes and going to clamp on every thing cause if I ever need to replace the clutch you got to drop the exhaust and it been clamped is the way to go I found a better deal than Mark on the Converter his lowest price was higher than what I paid and the shipping took longer cause his are factory replacement and twice or more than what I paid the cat I bought is direct replacement for year of truck and engine displacement and now I'm legal Jonny law can go write parking tickets and kiss my ass Last edited by kgb424; 02-04-2016 at 03:44 PM. |
08-03-2015, 08:54 PM | #156 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Ask you mechanic what needs to be done so that you don't damage you cat or muffler again. I know that the cat needs a stokimetric air to fuel ratio to keep it from melting.
08-03-2015, 09:53 PM | #157 |
I 'm not sure if it melted, but you can barely see thru the cat the one guy at the third muffler shop that I called he said it sounded like to him it started deteriorate and plugged up the muffler cause I dropped 2 small stones in the muffler and they rattled around and came out covered in soot then if you flip the muffler and do it again the rocks don't come out and have stopped rattling, and I added more rocks they still never came out so the muffler was plugged also cause my engine temp has dropped since I cut the cat and muffler Last edited by kgb424; 08-03-2015 at 09:56 PM. |
08-03-2015, 09:58 PM | #158 |
Ya keep throwing rocks in there |
08-03-2015, 10:05 PM | #159 |
Here are some pics for Wings of fire you asked earlier it a 87 Toyota 4x4 5 speed nothing special except I love that truck and drive the shit out its also trail truck and its logged a lot of miles in the BLM land that starts up the road from my house and it open country pretty much all the way to Utah and beyond Last edited by kgb424; 02-04-2016 at 03:45 PM. |
08-03-2015, 10:34 PM | #160 |
I use to work for waukesha and another company that serviced installed and set industrial engines and set up emissions systems on industrial engines. So im and expert (has been I know). to keep you new exaust parts healthy you need the have a proper mix of air and fuel. The stuff you removed probably had an mass air sensor oxygen sensor etc those mix the air and fuel to run you truck and also burn off in the cat. Without those items your truck will need to be running very smooth to keep them happy. Older vehicles have had cats without alot of electronics to make them work. So asking your mechanic to help you should insure you don't have to buy the parts again. If only it was the 80's you could go to a muffler shop or mechanic and have them install a red tube called a "diagnostic tube " and that would let you slide if you got pulled over, but not for inspection. I've got a truck without all the emissions stuff also it stays at the deer leese.
Tags |
dafuk? |
I need help - we todd did - Similar Threads | ||||
The Increasingly Poor Decisions of Todd Margaret | JeremyH | Chit Chat | 11 | 10-03-2010 07:00 AM |
