Thread: Sensored Outrunner motors- Revolver S
Old 02-09-2015, 12:20 PM   #861
Default Re: Sensored Outrunner motors- Revolver S
Can anyone offer some input...
Just installed my Revolver in my wraith 56/14, unbelievably smooth startup and crawling capabilities, just absolutely no top-end. My 3 year-old could practically outrun it. From what I've read in previous review, this shouldn't be the case???
What settings are you running on your MMP, 3s?
Thanks for your time,
Ryan
jeeprc is offline   Reply With Quote
Old 02-09-2015, 12:27 PM   #862
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
You should have decent wheelspeed, but what motor are you comparing it to and what battery are you running?
Be sure you don't have the power limits set in the MMP, that you are getting solid red or green lights with full throttles, and run it in smart mode with 10 to 15 degrees of sensorless advance.
JohnRobHolmes is offline   Reply With Quote
Old 02-09-2015, 12:39 PM   #863
How does it compare on top end to a 13t crawl master?
fr8cture is offline   Reply With Quote
Old 02-09-2015, 01:07 PM   #864
Ryan
Gear taller. . This motor crawls well with stupid tall gearing.
Also 4s works great with it.
holycaveman is offline   Reply With Quote
Old 02-09-2015, 01:15 PM   #865
This is 4s with 25/80 gearing. 6.5lb rock buggy.
Highwalling: http://youtu.be/eOAHYRQDQU0
Old 02-09-2015, 01:35 PM   #866
I am giving out my secrets so I hope you guys appreciate it! LOL
The revolver s has a ton more crawling torque than a roc412. So the trick is to gear them tall to gain the wheelspeed. For competition I don't run a 4s just a three s because start up will always be better with a lower voltage.
Always check your heat of course. But i have only managed to get this motor hot on 6s. Otherwise it never gets hot. I have no doubt it would pull 30/80 gearing easy enough. But i have no need for that much speed.
Old 02-09-2015, 03:52 PM   #867
Any recommendations of what I should start with?
Old 02-09-2015, 03:54 PM   #868
Is there a company that makes a steel spur that high
Old 02-09-2015, 04:20 PM   #869
You can switch to 32p gears.. 56/17 or 56/18 would build you the same gear ratio..
winnerone23 is offline   Reply With Quote
Old 02-09-2015, 05:35 PM   #870
I'm running a 32P 56T RRP Spur so I'll order their 18T pinion a try. Any other combos worth trying?
Old 02-09-2015, 05:37 PM   #871
I'll check my limits, lights, and add the timing, thank you John. I know I currently have it set a 0 timing as I thought that was recommended
Old 02-09-2015, 06:17 PM   #872
holycaveman, this may be the motor I am looking for based on your above statement.
My stock axial setup is roughly 55:1, my other setup with a rc4wd disruptor tranny yields a 48:1 setup, the new setup I am trying to figure out is using the new rc4wd scale transmission which is only a 30:1 drive ratio- I have found the 30:1 ratio too fast for scale low speed crawling. However given the info you posted maybe I am ok, I just need the correct motor?
L.R.
LoneRanger is offline   Reply With Quote
Old 02-09-2015, 06:29 PM   #873
L.R.
Yes. It should pull it no problemS. But if you have a 14lb truck then that may be different.
Old 02-09-2015, 06:34 PM   #874
when I am done I will have a 9# truck-
see this thread:
Stupid Scale Early Bronco
L.R.
Old 02-09-2015, 06:41 PM   #875
I'm considering replacing my Tekin redline 13.5t with one of these on a U4RC build. I am also running an AX2 transmission so I have a crawl gear and a high speed gear. Was running (and will likely continue running) 60/14 32P gearing on it. Any thoughts? Can this motor handle the high speed sections plus kick ass in the rocks?
Wes
WesTX is offline   Reply With Quote
Old 02-09-2015, 11:52 PM   #876
Wes
You can't throw a motor in that has 1600 less kv's and not expect to change gearing.
The good news is if you get this motor you will no longer need a two speed.
I would gear this motor 60/20 on your u4 and run 4s. Now you will be doing something!
Old 02-11-2015, 09:36 AM   #877
JRH, any chance of a combo deal with a Revolver S and an ESC on your site? Just seeing if I can save a few pennies.
Wes
Old 02-13-2015, 10:33 PM   #878
Super newb question here but a friend of mine said my 1300 35c(CD) 60C (Burst) lipo pack has too small of a burst rate for the MMP/540 Revolver any truth to this, If so What should I Get?
dezrik is offline   Reply With Quote
Old 02-15-2015, 08:32 AM   #879
You should be ok unless it's a really heavy rig and geared tall.
on the stubby I ran a 350 mah with a 5.5lb wraith. Batter got warm but not horrid.
Old 02-16-2015, 07:32 AM   #880
Location: Turn the mayflower around.. it will never work
What's your take on the 540 vs stubby? On heavy rig? Wheel speed and ta?
JokersWild is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136315-sensored-outrunner-motors-revolver-s.html
Posted By For Type Date
Outrunner for rock crawler - Kv and low-speed smoothness, is my theory sound? - RC Groups This thread Refback 10-07-2011 12:03 AM
Sensored Outrunner motors- Revolver S - Similar Threads
are all sensored brushless motors work with any sensored esc? jebster Electronics 8 01-02-2012 10:47 AM
outrunner motors toka100 Axial SCX-10 1 07-05-2011 10:37 PM
Sensored Motors cyberdog Electronics 1 01-08-2010 01:33 PM
