11-17-2010, 06:16 AM | #521 | |
Pebble Pounder Join Date: Oct 2009 Location: Dallas
Larry | |
11-17-2010, 07:16 AM | #522 |
RCC Addict Join Date: May 2006 Location: enid
I got a comp this saturday spent all day saturday last week jacking wiith it scraping this project out gonna go another route |
11-17-2010, 07:59 AM | #523 |
11-17-2010, 08:43 AM | #524 |
I have a thought; do you need to have both red wires going from the ESC to the Rx? What if you pulled the red from the AUX lead? This is for the servo powered directly off the CC BEC and not through the Rx. The problem seems to be that the M2 pulls enough current from the battery (3S 850mah 25C) that the CC BEC browns out and the steering stops also the BEC's LED goes out. |
11-17-2010, 08:49 AM | #525 | |
Rock Crawler Join Date: Jun 2010 Location: SENECA
11-17-2010, 09:21 AM | #526 |
11-17-2010, 09:26 AM | #527 |
I will try it with the AUX power disconnected, probabally tomorrow at the earliest.
11-17-2010, 11:12 AM | #528 |
| Oh. Post up how it goes. Im gonna start wiring mine up this weekend. A friend and I have discussed just wiring a small 2S battery to the servo
11-17-2010, 11:13 AM | #529 |
RCC Addict Join Date: Feb 2006 Location: ccxc
11-17-2010, 01:57 PM | #530 |
11-17-2010, 02:08 PM | #531 | |
I was going to play with the proportional settings later. | |
11-17-2010, 02:31 PM | #532 |
Let me know what you find for propo. I think this will be a good esc and just needs some bugs worked out. Hello novalink and firmware update !
11-17-2010, 03:13 PM | #533 |
What about the glitch buster on Novaks site for the M2 options
11-17-2010, 04:04 PM | #534 | |
The glitch buster is just a capacitor to supply a bit of current to gap the shortage. Last edited by AreCee; 11-17-2010 at 04:07 PM. | |
11-17-2010, 04:06 PM | #535 |
11-17-2010, 04:10 PM | #536 |
11-17-2010, 04:13 PM | #537 |
| He has mentioned several times to email him directly. csuangka@teamnovak.com I get responses usually within 24 hours using email. |
11-17-2010, 04:49 PM | #538 | |
11-17-2010, 04:53 PM | #539 |
11-17-2010, 04:59 PM | #540 |
I had been trying to use button D as my linear and decided to try button A instead so I reset my profile completely on the radio, reprogrammed each button and went through the one step setup over and over until I was happy with the results. It took me about 10 attempts but now it works just fine. Before when I was using D as my linear it seemed like my end points were outside full dig front or rear so when I would bump the switch past it, it would go back into 4x4 mode. One click back down and it would be back at dig where it was supposed to be then linear would work as expected back to zero (dig off-no lights). I hope that makes sense. Somehow I think maybe my D switch was causing the problems. I'm now running C as throttle trim, B is steering trim, A is linear aux, D is off, E is 3 pos front/rear dig and F is instant off for the dig. |
