11-18-2010, 09:35 PM | #561 |
Rock Stacker Join Date: Dec 2009 Location: Calgary, AB, Canada
Has anyone attempted to set this ESC up on a basic 3PM radio? I am using the radio for Vanquish 3-pos dig and wondering if it'll handle the M2 using the same SW2\Cond2 configuration. I couldn't find any information other than the 3PM-X.
11-18-2010, 09:39 PM | #562 |
RCC Addict Join Date: Feb 2006 Location: ccxc
i just mean a firmware update or something(for the m2)
11-18-2010, 09:43 PM | #563 |
11-18-2010, 10:10 PM | #564 |
RCC Addict Join Date: May 2006 Location: enid
That's funny they demo'd it with a dx3r |
11-18-2010, 10:19 PM | #565 |
11-19-2010, 02:19 PM | #566 | |
Rock Crawler Join Date: Jan 2007 Location: in my bubble
You should be good, What servo ? it seems there is only an issue when you have a high volt servo. | |
11-19-2010, 02:23 PM | #567 |
Is it glitching from the frequency of the spectrum rx and the Esc ? It doesn't make sense that when the CC Bec is hooked directly up to the battery and servo that it would have any affect on the esc. The only common piece between the 2 is the signal wire.
11-19-2010, 06:53 PM | #568 | |
Set sub trim to 0 One touch program Adjust sub trim to allow for the amount of overdrive/underdrive you want. Should work well, havent set mine up yet but I dont see why it wouldnt work. You will probably have to adjust your end points so it doesnt go back into 4wd past full dig but I dont see that being an issue. | |
11-21-2010, 09:27 AM | #569 |
Pebble Pounder Join Date: Oct 2010 Location: Jewel of the Sierra
| Giving Up On Novak M2
I gave up on my Novak M2. I'm running Spektrum DX3R & 3 cell lipo & Hi-Tec High Voltage 7980TH Servo, 14 pinion front, 13 pinion rear, Novak 55s. Burned up 2 Castle Creations BECs. This was wired by CKRC. They contacted Novak about the situation and were unable to effect a solution. CKRC has stopped selling the Novak M2 until compatability with DX3R & CC BEC is resolved. After waiting months for the M2 and watching the demo video using the DX3R, very disappointed. I like using the servo at high voltage. I went back to a single Tekin FX-R and Punk DIG. I am using the E switch as 3 position - forward = front DIG, middle = 4WD, rear = rear DIG. I am using the F switch as 2 position - 4WD or Front DIG. pinckbrown |
11-21-2010, 12:22 PM | #570 | |
Quarry Creeper Join Date: Nov 2009 Location: Sunny cali
11-21-2010, 12:32 PM | #571 |
| Is it posible to run the servo straight to the batt ? If you have a 2s 400mah....it'll be light enough so the weight wont be an issue ! Will that work ? Anyone know how to hook it up ? |
11-21-2010, 02:03 PM | #572 |
Rock Crawler Join Date: Jul 2006 Location: Hobbywing
Hi guys, Sorry for my lack of posting, but I have posted my email several times. csuangka@teamnovak.com I've spoken with Novak Engineering and it looks like they've resolved this CCBEC issue. A 1.3 version update to the firmware is currently available on the Novak site, and "should" work with the NovaLink for the updating purposes. I'll sit down with my PC and a few ESC's that my test group has been running this week and let you guys know as soon as I see improvement. I have not burned up any BEC's doing these installs. I have not had "glitching" of any sort beyond the BEC being turned off "momentarily" when throttle is first applied. Very strange to read about some of these issues for sure. Will try to have all this stuff posted up Monday. Our shop truck exhibits some of what you've been reading here, but really, we see no ill effect from the operation of the truck. Others i've worked with do get the servo "on/off" for a brief moment, and we've found the Dig won't stay engaged at Full Throttle. The fix there was easy, simply increase the Aux EPA by 5-10 points and the problem went away immediately. I'm hoping that the firmware update resolves these issues. See you guys right here Monday Afternoon! |
11-21-2010, 05:42 PM | #573 |
Rock Crawler Join Date: Mar 2008 Location: Not painting
anybody know how to get more propo steps from the dx3r linear set up?...two clicks and i get full lock on front and rear axle....saw it work in the novak demo video with the same set-up i'm running.....dig power settings maybe?
11-21-2010, 06:41 PM | #574 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
I couldn't find any way to do it, but I don't think the problem is with the DX3R, the steps are pretty small. I think it is how the M2 interprets the input. I am experiencing the same thing you are. Hopefully the firmware update will address this issue as well as the compatibility with the ccbec. I would really like to get all the power out of my 7950. Hopefully somebody already has the novalink and can test it out on Monday when they get the firmware update posted on their site. I have to order one |
11-21-2010, 07:37 PM | #575 | |
Adjust "travel" to 75% ,then go to "Monitor" mode you should see this when you dig to front and rear > -1023------0------1023+ Each click on the "Linear" will be about "50",so you should have about 4-5 clicks each plus and minus side to work with! To my application,that work fine for me but if thats still not enough for you you can try to go as low as 60-65% Hope that helps. | |
11-21-2010, 08:05 PM | #576 | |
I now have C=3 pos, A=Linear, D=2 pos and E=throttle trim. Seems like once I put in the Common Sense RC BEC everything works, now I need to test it all in a comp but it's winter (almost) here in the midwest and we only have indoor comps. | |
11-21-2010, 08:07 PM | #577 |
I have the novalink and really want to check out the update asap. Can we expect the novalink m2 software Mon?
11-21-2010, 08:32 PM | #578 |
just tried after a few tries to get it to connect i updated it.........i really really want the m2 software!
11-21-2010, 08:37 PM | #579 | |
11-21-2010, 09:22 PM | #580 |
