11-14-2010, 12:22 PM | #481 | |
Quarry Creeper Join Date: Nov 2009 Location: Sunny cali
Sorry my bad(didn't plug the fan in right ) | |
11-14-2010, 12:24 PM | #482 |
A guy I met the other day was having the same issues as some of you are having. The thing had a mind of its own. It had the CC BEC wired into the rx like castle recommends. He rewired it so the bec went straight to the servo and the internal BEC of the M2 powered the receiver and it solved the problem.
11-14-2010, 12:36 PM | #483 | |
Rock Crawler Join Date: Sep 2006 Location: Lititz
I now am using the internal bec, and it works fine. I have been checking the temps by tapping the one touch button. When using the ccbec, I was only getting the blue led to blink 4 times, then the esc would return to neutral. Now that I am using the internal bec, I get two different readings. The green or yellow led will blink four times, indicating a warmer tempurature, then the blue led will blink four times and the esc will return to neutral. I am thinking that the esc is giving me the temp of the internal bec, then the temp of the esc? There is nothing in the directions about the duel readings. Anybody know? If I check it as soon as I power on after it has been sitting, I only get the 4 blue blinks. | |
11-14-2010, 12:43 PM | #484 | |
I burned up a ccbec with this setup. | |
11-14-2010, 02:31 PM | #485 |
Quarry Creeper Join Date: Mar 2008 Location: Columbus OH
11-14-2010, 05:52 PM | #486 |
RCC Addict Join Date: Feb 2006 Location: ccxc
any was to make the f/r proportion steps smaller on a dx3r?
11-14-2010, 05:58 PM | #487 |
RCC Addict Join Date: May 2006 Location: enid
Nope......let me guess the proportional part is like four steps then nothing????Fought htis all night on setting one up for cd13 I think theres something screwy with the esc on the one i was working on |
11-14-2010, 08:31 PM | #488 |
| Here's a vid of the test on the M2 today.I'm running the BEC on the ESC for now(killed the cc/bec) It works ok if you are not in a bind ! So if you gonna comp...you gonna need one! http://www.youtube.com/watch?v=1BH7WkYfcrI |
11-14-2010, 08:36 PM | #489 |
So that's how they're aupposed to work you musta got a lucky one |
11-14-2010, 08:52 PM | #490 | |
Pebble Pounder Join Date: Oct 2008 Location: Appletown
Kaspers is connected that way, the only thing I forgot to try was to run it with the motors unpluged to see if it does the same thing. You can watch the power light on the receiver go from green to red every time it acts up. | |
11-14-2010, 09:08 PM | #491 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
I guess I'm a lucky one,My bec made it thru the day but never got the esc to slow either motor.My tekin and punk dig worked better.
11-14-2010, 09:12 PM | #492 |
11-14-2010, 09:27 PM | #493 |
I'm doing better then that,Futaba 4PK and 2 esc's. I want to control both esc's at the same time and I want 7 volts to my servo,My mistake.
11-14-2010, 09:56 PM | #494 |
11-15-2010, 06:15 AM | #495 |
| Yea it's like 2 steps forward off. Two steps back off. Novak ca you chime in? Firmware update maybe?
11-15-2010, 11:03 AM | #496 |
Quarry Creeper Join Date: Oct 2009 Location: St Louis
that sucks I just Ordered Mine and was hoping all the issue were solved to run with My DX3r .
11-15-2010, 11:07 AM | #497 |
| Matt add me to the roster.......
11-15-2010, 11:34 AM | #498 |
Don't get me wrong. It does work but needs some updates. Hoping Novak shows up in this thread again.
11-15-2010, 04:31 PM | #499 |
Pebble Pounder Join Date: Nov 2009 Location: Germany
Hi, I have the same problem with the Novak M2Dig and CC BEC. If I disconnect the internal BEC, feed the CC BEC into the receiver, and I'm going to slow, then the LED from the CC BEC and receiver are goes short, and he remains for a moment. When I use the internal BEC lead into the receiver and connect only the Servo with the CC BEC, then shrugs at the slow starting of the servo. This all happens when I programmed the drag brake. When I take the drag brake to zero, then everything works fine. In the MOA Losi works well, but for the XR10 I need a drag brake. programmed to get out the drag brake and you will see that it works, but a XR10 or berg with no drag brake is not to drive. The problem is there when the drag brake is set. The CC BEC has a problem with the drag brake. One CC BEC is me already burned down. I hope Novak and CC can eliminate the problem Greetings tom Last edited by highfly; 11-15-2010 at 10:06 PM. |
11-15-2010, 05:14 PM | #500 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
Lets hope we get some help here come on Charlie make this right mine is sitting on the shelf and going back to tekins real soon
