11-06-2010, 11:21 AM | #441 |
Quarry Creeper Join Date: Feb 2009 Location: The work bench
I don't see how it could since the 3rd channel can only act as linear or 3 position. And you cannot assign different buttons to perform different tasks like you can with say the 3r. At best you would only be able to perform one function or the other at a time without having to change what way your 3rd channel works.
11-06-2010, 12:42 PM | #442 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
Picked mine up today hope sher works like the model on display at i hobby
11-06-2010, 03:26 PM | #443 | |
My gripe about the DX3R is that you need to switch screens to the Monitor screen to verify your position/trim which doesn't show the timer. A minor thing with the M2 using red and blue LEDs to show which DIG is active. | |
11-06-2010, 03:28 PM | #444 |
11-06-2010, 08:53 PM | #445 |
Rock Stacker Join Date: Jun 2009 Location: High Desert
i am going to order one really soon and was wondering if i will be able to use it with my mx-3 fhss. It only has a 2 position 3rd on it. I know i will not be able to use the proportional dig or the rear dig but will i be able to switch between 4wd and front dig. Im worried it wont program right and i will end up with front dig and rear dig with no 4wd because of the lack of another position on my 3rd channel. I dont have money for another radio right now and would really like to utilize the m2 ... Thanks
11-08-2010, 08:12 PM | #446 |
Newbie Join Date: Mar 2010 Location: inverness
I think that i am having the same problems as many,i have the wrong radios! i got a dx 3s,mx-3,and a dx6 can i use any of these radios on my m2 i thought that a may have a chance with the dx6.is there any hope here? |
11-08-2010, 09:30 PM | #447 |
| I thought this was going to be a problem, but I really haven't needed to look at it. I have the LEDs mounted in the front window, they tell me what dig is active. I have found that two taps of SW B (Linear) gives all of the power I need to overcome clod stall.
11-08-2010, 10:13 PM | #448 |
I hope it works with my 4pk
11-08-2010, 10:37 PM | #449 |
Quarry Creeper Join Date: Nov 2009 Location: Sunny cali
| Got mine working pretty good now that i'm using the M2's bec ! When I used the CC/BEC , It was glitching and popping real bad and finally died ! I'm using 3s....so as soon as I get a new ext. BEC i'll just hook it straight to the servo only. |
11-08-2010, 11:37 PM | #450 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
Well the m2 worked good enough for me to get 4th at Utah state champs this weekend. I ended up just running the internal BEC and it held up to a 7950TH with a 3 cell but thats only running 5min at a time. When I went to fun crawl after the comp I was about 20min into it and I guess the ESC got hot and started messing with the servo. All around great product. Thanks novak |
11-09-2010, 08:45 AM | #451 |
RCC Addict Join Date: Feb 2006 Location: ccxc
Anyone who wired straight to the servo have isssues?
11-09-2010, 03:09 PM | #452 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
Wired mine exactly as diagram and still have a glitch,The bec light flickers and servo glitches.I have one touched program so many times,I can get the dig to work but AUX Linear only moves from 4 wd to dig without slowing the motors. No biased faster or slower |
11-09-2010, 04:11 PM | #453 |
| I did, I noticed when I had the motors under a load (climbing) and was using the servo, the servo would glitch. I installed a CC BEC wired through the RX (Spektrum 3100) set to 6.5V and the problem went away. Just remember when installing the BEC through the RX that you have to remove BOTH red wires going to the RX's Throttle and 3rd channel ports. |
11-09-2010, 09:21 PM | #454 | |
| ... Quote:
You may know this, I was just curious. I will be bench testing mine tomorrow. Using a y-connector on the servo to get power from the BEC directly. You have to add the Red wire back to the ESC so it powers the receiver again. Explains it better here. 7950 problems? .... Last edited by Szczerba; 11-09-2010 at 09:33 PM. | |
11-10-2010, 06:20 AM | #455 |
I wanna be Dave Join Date: May 2010 Location: The east coast
to use the bias control do you need a radio that has trim functions on it's 3rd channel? i have a tq2.4 4ch radio (converted 4/5 channels to true 3-pos switch) but it doesn't have trims. i'm guessing that means i could do front or rear dig but no biasing.
11-10-2010, 11:53 AM | #456 | |
I haven't seen anyone post that they are using that radio of this ESC. If you get it working post a thread on it. | |
11-10-2010, 07:18 PM | #457 |
Newbie Join Date: Mar 2010 Location: ruffsdale
| 4pks and m2 dig
charlie any ideas on set up 4pks with m2 dig tried harleys setup cant do one touch set up with his settings tried both set up one for the dig and dual esc i was told to go with dual fxrs but really like the size of the m2 can some one from novak please help me out
11-10-2010, 07:22 PM | #458 |
RCC Addict Join Date: Aug 2007 Location: Rohnert Park
Charlie's in Thialand announcing for the 1/8 worlds ... He'll be back next week. |
11-10-2010, 09:06 PM | #459 | |
I have never seen or touched a 4pks but here is what you need to do. Ok, turn off all mixing...You dont need any Setup a 3 position switch for the 3rd channel (front and rear dig) Setup a second switch for linear 3rd channel (or you could put in 10% steps or something like that if you wanted) Not sure that the 4pks will let you have 2 switches for one channel so you may have to use one or the other. | |
11-11-2010, 02:01 PM | #460 |
Newbie Join Date: Jun 2008 Location: southeast
anyone using a dx3e, if so how is it working. Thanks |
