08-31-2011, 05:43 PM | #1441 |
Rock Stacker Join Date: Aug 2011 Location: Calexico
So I guess there almost a year for a new futaba radio so I´ll just buy the 4pl
09-01-2011, 10:26 AM | #1442 |
Quarry Creeper Join Date: Dec 2008 Location: La Costa, CA
I love my 4PL... but my finger barely fits in the trigger. Can these be easily replaced. My 3PM trigger fits perfect. Any suggestions? Scott |
09-01-2011, 11:06 AM | #1443 |
| I made a call, I'll check into it. I know there is a wider trigger made, a friend has one in his 4PK however it just came that way. I have NO IDEA how or why.
09-03-2011, 08:35 PM | #1444 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
I think i have found a way to do a momentary front dig. It works on mine but i don't know if its fluke or not. So i have the dual ESC set up with FX-R's front on CH4 and rear on CH2, I set SW1 to TH-OFF DIR:NOR. I tested it and While I am driving if I press SW1 it kills the rear motor and gives front dig. It is a little awkward but i found it works (at least on my setup).
09-04-2011, 05:29 PM | #1445 | |
RCC Addict Join Date: Jan 2009 Location: O.C
Second question. Is it usual to have a little "lag" when applying very little throttle? Basically my front motor turns before my rear motor for roughly the first 10% of the throttle curve. You can even see it on the screen as the bars move up as throttle is applied. Thanks | |
09-04-2011, 07:05 PM | #1446 |
09-04-2011, 11:43 PM | #1447 | |
Thanks again for the help. Last edited by paystin; 09-04-2011 at 11:49 PM. | |
09-05-2011, 08:43 AM | #1448 |
| That's not the way i'd suggest it. Make sure it's all set to zero, and you mixing is set to 100 then recalibrate. You have had something off when you programed it.
09-05-2011, 10:05 AM | #1449 | |
What's the danger of running it with the trim bumped up? | |
09-05-2011, 10:51 AM | #1450 | |
If everything is set to zero and your mixes are at zero then the graphs will move the same and there will be none of the lag you have seen. If you can't figure it out I would suggest starting with a new model to make sure you get it perfect. | |
09-05-2011, 11:03 AM | #1451 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
JUST BOUGHT MY 4PL TODAY , IT SHOULD BE HERE THIS WEEK. I'VE BEN READING THIS THREAD FOR A MONTH SO NOW IT'S TIME TO GO BACK AND READ IT ALL AGAIN. |
09-05-2011, 11:11 AM | #1452 | |
BTW, STOP with the "All caps"! | |
09-05-2011, 11:16 AM | #1453 |
09-05-2011, 12:02 PM | #1454 |
09-06-2011, 02:28 PM | #1455 |
09-06-2011, 02:38 PM | #1456 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
09-09-2011, 09:00 AM | #1457 |
RCC Addict Join Date: Mar 2009 Location: Chilton
I didn't see this in here anywhere but I can be blind at times. I am wanting to run a winch and dig on my pl and was wondering wht the best way to do that would be. I would like to run the both from the switch but I am not sure if you can I figure you might be able to with some kind of mix but I don't know I havn't been able to do it yet. I guess if need be I could use the dial for the winch.
09-09-2011, 09:05 AM | #1458 | |
09-09-2011, 09:09 AM | #1459 |
Newbie Join Date: Aug 2011 Location: Netherlands
09-09-2011, 09:18 AM | #1460 |
| That is what I am not sure of how to do. This is my first radio that I have had to set up like this. The ones I have had in the past have been simple stupid radios but I needed more options to be able to run a winch and dig. I have gotten myself lost I believe and nobody that I know close to me runs anything but simple stupid radios. I have a 3-pm but it was already set-up when I got it used off of here so I didn't have to do anything to it.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
