10-24-2014, 07:14 PM | #3661 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: GT3B Hack Question and Answer Thread
Color simply means you chose not to go silver.
10-25-2014, 12:15 AM | #3662 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Pull my finger...... It smells funny
10-25-2014, 02:32 PM | #3663 |
Quarry Creeper Join Date: Jun 2011 Location: panama city
How can I tell which firmware Is on my flysky gt3b? I have 6 channels and trying to program from a 6.1 firmwsre you tube video. But can't get my 3 channel to work my heyok controller and k2 winch.
10-25-2014, 08:29 PM | #3664 |
Quarry Creeper Join Date: Sep 2006 Location: Valpo
Do I need to know or do anything to charged the battery from the computer on my hacked gt3c? thanks for help
10-26-2014, 09:22 AM | #3665 | |
| Re: GT3B Hack Question and Answer Thread Quote:
You need to download the manual and read it. Global setup menu: ================== - enter it by ENTER-long - now menu items MODEL and NAME will start blinking - select requested item by ROTATE and press ENTER - use ROTATE to change value and press ENTER to end value changing - press BACK or END or ENTER-long to end global setup menu, values will be saved to EEPROM - selected menu items are indicated by following symbols: F firmware version (this of course cannot be changed :-) L backlight time 5s,10s...10m...MAX OFF,1m...10m inactivity alarm I LOW POWER! battery low voltage 2.0...10.5V C default number of channels 2..8 E maximum allowed endpoint value 100...150% DANGER - values greater than 120% can damage your servo or will not be possible to transmit to receiver because of 2.4GHz HF module limitation | |
10-26-2014, 09:28 AM | #3666 |
| Re: GT3B Hack Question and Answer Thread |
10-27-2014, 06:43 PM | #3667 |
thanks for your help Jokerswild, it looks like i have 4.o firmware on my gt3b and i cant assign the 3rd chnl trim as a three way switch. do i need to get the firmware from outcry and the 4pin from there too so i can update my tx? I am getting frustrated with this tx. I just want it to run my heyok controler with a k2 winch. i bought a spektrum to rum all my stuff but they glitch so bad with spektrum that i cant run it. now i have this problem. daaaaang it didnt read anywhere that they had problems with spektrum until afterwards. ant help would be appreciated. or should i ditch this winch and get something elase and be done with all this headache? |
10-28-2014, 10:32 AM | #3668 | |
Pebble Pounder Join Date: Sep 2013 Location: Portugal/Lisboa
You can use the USB from you pc, our you can do like I do, I use the mobil charger, the new mobils are stander, the plug is all the same and it fits the GT3C. | |
10-28-2014, 08:05 PM | #3669 |
Pebble Pounder Join Date: Jul 2012 Location: Crawlerado Springs
Ran into a pretty serious snag hacking my gt3b today. Even though it said program successful and verified when I went to turn on tx and have some fun setting up cars it won't even turn on. Anyone else have this problem? Batteries are good they worked fine earlier today. Looking for things to try please.
10-29-2014, 01:04 PM | #3670 | |
I hacked mine and it whent great no problems. have you tryed again, mayby that way it will set it up | |
10-29-2014, 03:56 PM | #3671 |
Well Overkillrc was quick to respond to my email with an answer! Turns out I never selected to firmware to be loaded so basically I loaded all zeroes as my firmware. Be sure you you don't skip this somewhat important step! Let the bashing commence! |
10-30-2014, 12:38 AM | #3672 |
Pebble Pounder Join Date: Apr 2014 Location: Trinidad
Just ordered me a hacked GT3B from OverkillRC.. Don't have any experience with radios other than the stock Axial AX3s.. Can't wait to get my hands on this and take my Wraith to a new level of fun. I wasn't too happy with the idea of using a Lipo in a radio, so I chose the B over the C model. Included the upgraded regulator and bearing mod for the wheel. OverkillRC had responded via email to a question I had and the purchase went smoothly. |
10-30-2014, 07:37 AM | #3673 | |
The winch and controller you have is what ya want...... Heyok and kms are the cats meow... I run em both. As for issues with spektrum..... Donno I have no issues with em. | |
10-30-2014, 07:40 AM | #3674 | |
10-31-2014, 07:31 AM | #3675 |
10-31-2014, 07:47 AM | #3676 | |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
The GT3C LiPo is no different than the pack in most cell phones. 1S so no issues with un balanced cells and it is actually in a hard case. Big mistake I would and have gone with the GT3C over the GT3B. Even when I had the GT3B I had a 3s LiPo pack in it. | |
10-31-2014, 10:27 PM | #3677 |
Quarry Creeper Join Date: Aug 2013 Location: South Crawlolina
I have Two Questions.... 1. What Version Radio is used, green (the latest one), or orange and silver? 2.How long is the waiting list? |
11-01-2014, 10:35 AM | #3678 |
| Re: GT3B Hack Question and Answer Thread Huh? Regulator regulates voltage....... When ya put in a 3 s Lipo it sees a higher volt for longer than your 8 aa batteries putting a strain and burning up factory regulator over time. The recom is better suited to handle said power. |
11-01-2014, 02:47 PM | #3679 | ||
I should have asked for opinions before buying, but I still prefer the non rechargeable way for the radio. | ||
11-01-2014, 03:07 PM | #3680 | |
It's massive though...I should really get some in stock | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
