11-02-2014, 10:24 AM | #3681 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: GT3B Hack Question and Answer Thread Quote:
In no way shape or form will the aa see the run times a Lipo will. I can post the rest about efficiency later when I have time | |
11-06-2014, 10:14 PM | #3682 |
Newbie Join Date: Jan 2014 Location: middle river
hi all, i could use a little help. Im trying to program the 3rd channel on the i think you call it the C switch to be a 2 postion for the 2 speed trans in a tf2 but i want to be able to set the end points, can someone walk me though on how to do it thanks. im using a gt3b with 6.1.
11-14-2014, 07:35 AM | #3683 |
Pebble Pounder Join Date: Apr 2013 Location: traverse
Thanks for the information inclosed throughout your thread. I inquired in another thread as to the axial transmitter looking suspiciously flysky looking for confirmation. At this time I run 99% specktrum and a couple traxxas tqi's. Looking into the flysky pricing it may be worth a small investment to switch my only two crawlers over, I can buy a radio and multiple four plus channel receivers for the price of a couple 3 channel specky units |
11-14-2014, 08:13 AM | #3684 | |
Quarry Creeper Join Date: Oct 2014 Location: East
I have yet to look over the electrical differences between the two receivers but I have far less issues using the AX-3 on my GT3B | |
11-19-2014, 10:45 PM | #3685 |
I'll have the GT3C Prototype switches listed on my website soon. They are alittle loose, but do the job. As with the GT3B version, anyone who buys the prototype switches will have the option to upgrade to the final versions for a fraction of the cost. (I'm not looking to make money off you twice) I'm working on getting the size right, it'll be afew more months before the machined aluminum ones will be made. |
11-19-2014, 10:51 PM | #3686 |
Quarry Creeper Join Date: May 2010 Location: Vic B.C Canada
My replacement switches are working far better than the stockers ever did. sent using lipo power from a galaxy |
11-28-2014, 06:23 PM | #3687 |
Newbie Join Date: Jul 2013 Location: Palmer
I finally got my GT3B hacked, updated the firmware, and got it to do 4WS and change to Crab with the CH3 button. I've seen videos of people using the CH3Trim button to also switch between just normal front steering and just rear steering. Does anyone have the "recipe" for this?
11-28-2014, 08:37 PM | #3688 |
This is how I did it back at version 4.0, by version 6.0 I decided to run it manually in rear as to have better control of rear axle ch3 will swap between 4ws and crab ch3 trim will go between rear steer(left), 4ws(mix)(center) and front steer(right) sub menu EPOINT (4) to channel 4, 0%, NOC sub menu rev 3 4WS, NOL, 100%, NOR, NOO sub menu rev C 4WS, SWI, NOR, NPV, OFF Steering Front is plugged into Channel 1 Steering Rear is Plugged into Channel 4 Austin can confirm if this template will work on newer version........ Can't remember if some of those abbreviations changed. |
12-02-2014, 08:22 AM | #3689 |
Quarry Creeper Join Date: Feb 2005 Location: Atlanta
Where can I find a programing manual? Just trying to make my CH3 button an on/off switch.
12-02-2014, 08:32 PM | #3690 | |
Also there have been a few manuals around that others have made to explain more in depth and simplify. Google should net you some of those manuals. | |
12-03-2014, 01:59 AM | #3691 |
Pebble Pounder Join Date: Sep 2013 Location: Portugal/Lisboa
Will a 1050 lipo 3S 20C work for the transmitter pack since I have one laying arround at home, our do I have to go for a 3S 2C?
12-03-2014, 02:21 AM | #3692 |
RCC Addict Join Date: Apr 2009 Location: LA
Yes. The 20c has 10x more available amps but the same volts so it will fine. Sent from the outer limits using alien technology |
12-03-2014, 07:59 AM | #3693 |
| Re: GT3B Hack Question and Answer Thread |
12-03-2014, 01:07 PM | #3694 |
Thanks for the help |
12-08-2014, 05:02 PM | #3695 |
Newbie Join Date: Dec 2014 Location: Scottsdale
I will admit I have not read all 100+ pages of this thread, but could somebody tell me how hard it is to put in the frysky telemetry radio in this? I have no issues reflow soldering, I have a hot air workstation, can acquire the stm8 programmer no problem and think I have all the bases covered, anything I am missing out on would be appreciated, also already have recoms in different flavors but since I am looking at the 3c I don't think that would be an issue. I just can't justify a 3pk/s with a frsky module, when I already have what I think is all I need. Been in and out of the hobby for 30yrs, current brother hobby would be multirotors that I design the frames in solidworks, have them machined in whrever material I feel appropriate and build the fc, usually some modified version of something open source. Have had excellent results w/ the frsky module in my 9cap, but I scored big time on that radio for aircraft and will not replace it until I need a Taranis, which probably won't be for some time, I just feel the frsky radio to be very solid and if I am running a 4s, 1:8 truggy @ 50mph+ I feel it my responsibility to have a solid rd connection (fright will need need some tweaking to get to 50mph reliably, but again solidworks is my friend (along with Ti & 7075-t6 Al and an aerospace machine shop) :-) This will be for a basher Thanks in advance, Bob |
12-08-2014, 05:15 PM | #3696 |
The frsky module requires more voltage than the 3c has (because it runs off a 1s lipo). So you'll need a boost regulator to just power the frsky module
12-09-2014, 10:22 PM | #3697 | |
On another note, anybody run under large solar arrays? I live very close to a school that has solar panels on the buildings and parking structures and while I plan th get a $1M umbrella policy (parks have a horse run ( not sure if that is the correct term ) and I don't know what rf the solar setups put out, if any, but don't want to be the guy that finds out and the horses, well these ones are not are not cheap let alone the injury to the person considering the weight involved....😬 Last, how many channels do the radio/s - 3 & 4 series, in their stock state use and as far as the solar stuff, for the multis I fly, I go 5.8, both both boscam and immersion frequencies. Thanks in advance, Bob | |
12-14-2014, 05:41 PM | #3698 |
Newbie Join Date: Nov 2013 Location: Mulberry Grove IL
Is losikid on vacation or something? Ordered a flysky gt3b 11/28 and I have still not heard anything from him on the order. I emailed him 3 or 4 days ago asking about status and still no response. Don't want to start anything here just don't know how else to get any answers. Thanks
12-14-2014, 06:13 PM | #3699 |
Not sure but I've order quite a bit fro austin. He is quite a busy guy, getting a hold of him sometimes sucks but parts always come through.
12-14-2014, 10:46 PM | #3700 |
Its all good. I gather its a hobby for him. Was just hoping to have before Christmas, its a gift.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
