09-24-2017, 07:10 AM | #4681 |
Quarry Creeper Join Date: May 2011 Location: scituate RI
| Re: GT3B Hack Question and Answer Thread I’m getting a blizzard snowcat and would like to use the gt3c to run it with dual ecs and motors could you explain how to set it up for tank steering
09-24-2017, 08:44 PM | #4682 | |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
| Re: GT3B Hack Question and Answer Thread Quote:
09-27-2017, 01:43 AM | #4683 |
Newbie Join Date: Oct 2014 Location: Czech Republic - Nehvizdy
Hi, I have smoke generator with separate esc. It will mount to truck with sound system also. My question is, if I can setup my hacked GT3C for this function: - Connect smoke generator and sound engine generator to channel 4 (Y-cable) - Possibility to start sound for engine and smoke generator with special key (CH3 trim) and adding it by 10% etc - mixing ch4 (sound + smoke) with throttle (ch2) - it mean, motor (sound) and smoke already started and if I go forward smoke and sound will increase... Is it possible this setup and How I can do it? Or if not, what is the possibilities for best setup for almost the same? Thanks a lot Michal |
10-02-2017, 05:59 PM | #4684 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
Is there a way to use two channels for steering? As in a way to use two channels to two steering servos for a summit without a Y-splitter. Any ideas or ways to do this? |
10-02-2017, 10:36 PM | #4685 | ||
Scroll to d, press enter Scroll to CH1, press and hold enter Press back/end a few times. No, I thought we determined the firmware mod still wouldn't work for you? Quote:
Sure, activate the 4ws mix. | ||
10-03-2017, 12:17 AM | #4686 |
Why do you want manual control of the sound/smoke? For starting and then running sound and smoke generator without moving the wheels. Mixing two ESC can be use for it, Am I right? Best setup for it? Thanks |
10-03-2017, 04:48 AM | #4687 |
| Re: GT3B Hack Question and Answer Thread 4ws would work but if I bump a switch or someone else bumps a switch then I have two burnt up servos. Is there a way to run the 4ws setup but have no switches on it? I tried this with CH8 to adjust an Mx aux wire but as soon as I left the trim settings part it went back to zero so I set it up on the end button so it would have a place and then it held. I'll try a few things today and see, maybe there is something I can set up similar to the tank drive/steering setup? |
10-04-2017, 02:13 PM | #4688 | ||
10-04-2017, 02:28 PM | #4689 | |
Thank you I got it all set up trigger for forward and revers and the wheel reverses the inside track for turning. I had it working and then I messed something up so I had to start a new model. | |
10-06-2017, 10:37 AM | #4690 |
RCC Addict Join Date: May 2015 Location: Price Twp.
All right I give up. First thanks to the people who posted in this thread and losikid for the videos. So I hacked a GT3c last night, had some connection issues and ironed them out after 3 hours. This morning I set out to get this thing working the way I need it, manual in hand. I successfully got my channel 3 set up for a 2-speed transmission. Was feeling pretty good about this and then I moved on. Yep, no didn't move on screwed all types of things up found the global reset and start over. Got channel 3 back. Set the number of channels to 6. Now I'd like to turn the ch3 trim into a channel to rotate a servo back and forth like the steering. What I have is a gun turret that I would like to rotate the stop when I let go of the button, then rotate the opposite direction when I hit the other side of the trim. It doesn't need to center on its own. Last edited by Ditchrat; 10-06-2017 at 11:03 AM. |
10-06-2017, 10:56 AM | #4691 | |||
10-06-2017, 11:24 AM | #4692 | |
Does this help? (page 2) http://overkillrc.com/GT3X-Firmware/...lp%20cards.pdf If it controlled by a servo then use BAR (Buttons-AutoRepeat) and set a set rate of like 1 or 2. Then as you click/hold it will move it around Last edited by losikid; 10-06-2017 at 11:28 AM. | |
10-06-2017, 11:34 AM | #4693 |
You the man
11-18-2017, 11:12 PM | #4694 |
Newbie Join Date: Jul 2011 Location: Canada
Want to start off by saying great work on the firmware, and all your help in this thread. Been reading this thread for what seems like hours now trying to find someone else has tried to setup a winch like I want to. Thinking dig mix might be the way I need to go, tho maybe there's a better way. My idea, Three position control, in - off - out. Button on - off... On would mix the same direction of the throttle. So that way as you apply throttle the winch goes in, and of course out when you reverse. Is it possible ? Thanks |
11-19-2017, 12:06 PM | #4695 |
Pebble Pounder Join Date: Aug 2015 Location: Jackson
Sorry for not reading through 235 pages but can you buy one of these set up for the trx-4? If you can how would I buy one ready to go and how much? Thanks |
11-19-2017, 01:48 PM | #4696 |
| Re: GT3B Hack Question and Answer Thread I have seen a few YouTube videos of guys showing how they have them setup. Tho haven't seen anyone have a preconfigured version for sale. Prolly have to get a controller with the firmware, then set the settings to your rig
11-19-2017, 03:53 PM | #4697 | |
https://www.youtube.com/watch?v=SpIoLgmI1xw&t=5s | |
12-04-2017, 12:30 PM | #4698 |
Pebble Pounder Join Date: Jun 2011 Location: Le Mas Petit 81 France
Hi! I have a problem to hack my GT3B When I connect the programming board and want to write the new firmware, the software tells me that it's protected and I can do nothing. Is there a solution? And does flysky block all of its remotes now? I suppose I'm not the one to ask those questions, but there is too many pages to find the answer |
12-09-2017, 11:47 AM | #4699 |
Rock Stacker Join Date: Mar 2016 Location: Saskatchewan
If you have an Arrma Nero/Big Rock/Fazon (and a hacked Flysky Tx) you might be interested in this video: https://www.youtube.com/watch?v=dIPrXyGPyyY |
12-28-2017, 05:39 AM | #4700 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
Can you set or adjust throttle curves for a hacked GT3C? Sent from my Pixel XL using Tapatalk |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
