10-27-2018, 06:13 PM | #801 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Re: Have tech questions? Will answer.
Will a TORQUEMASTER EXPERT 550 27t push a heavy truck ? Apparently my motor died, a few guys said my truck is heavy, compared to their rigs, so is that an ok motor to use for a heavy truck ?
10-27-2018, 06:26 PM | #802 |
Yes it will. Trailmaster 27t 550 could be another choice if you want to test you rig weight on a similar but less expensive brushed motor.
10-27-2018, 07:51 PM | #803 | |
| Re: Have tech questions? Will answer. Quote:
I had a 21t silver can 550 , that smoked. I want the TORQUEMASTER EXPERT 550 so i can be more at ease.....LOL thanks JRH. | |
10-31-2018, 04:38 PM | #804 | |
I prefer to use the Crawlmaster 550 motors when I dont need the extra torque, start up and low speed control is a bit better. I have a few of them powering 8-9 lb trucks just fine. EDIT: another thing to consider is gearing, if its too high the motor will cook regardless of weight. I also had a question, I'm working on a Turbo Scorpion thats using a Mamba Max Pro ESC and a Tekin ROC 412 sensored motor and I feel like I might have a bad sensor cable. A few times now I've dialed in the settings in Castle Link and its had great low speed control for a little bit then something happens and it switches over to having no low speed finesse at all. I read in the Castle link smart sense description that if the sensor wire isnt detected it switches over to sensorless mode which I'm guessing might be happening. I still need to check and see if I have a spare sensor wire to test but I thought I'd post this in the mean time. EDIT: I just found a spare sensor wire and swapping it in fixed my issue Last edited by HumboldtEF; 10-31-2018 at 09:08 PM. | |
11-04-2018, 12:42 PM | #805 |
Rock Stacker Join Date: Sep 2017 Location: Germany
Question about the feature of Punch control in the Castle link software: Following the recomendation to run 30% Punch control set via castle link, because otherwise electronics dumped to much energy without a limit set. That sounds quiet comrehensible. I'm running a RR10 with 9 Ib on 2S and ask myself if to much Punch control would limit the acceleration of the rig, because 30% sounds like a high value. Would be the way to bring acceleration the step to 3S? |
11-04-2018, 12:45 PM | #806 | |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
Sent from my SM-G960W using Tapatalk | |
11-04-2018, 05:50 PM | #807 |
Quarry Creeper Join Date: Nov 2006 Location: Lexington Park
I have a potentially dumb question but have yet to find the answer. I searched and checked castles website. Thank you Q: can I run a brushed motor on a Castle mamba x esc? Sent from my SM-G965U using Tapatalk |
11-04-2018, 05:57 PM | #808 |
RCC Addict Join Date: Jun 2017 Location: Canada
Yes Sent from my Pixel 2 XL using Tapatalk |
11-04-2018, 07:57 PM | #809 |
If your buying strictly for brushed motors ask yourself if the aux wire on the mamba x is worth $100. If not then I highly recomend the hobby wing 1080 for brushed for $40. The 1080 is also quieter, but has no throttle curve. The mamba x can handle 6s batteries but brushed motors can't. 4s for brushed motors. Personally I would only buy the mamba x for a sensored brushless motor. I don't think it's a great value compared to the hobbywing's. Last edited by Voodoobrew; 11-04-2018 at 08:04 PM. |
11-04-2018, 08:04 PM | #810 | |
Sent from my SM-G965U using Tapatalk | |
11-04-2018, 08:58 PM | #811 |
On the mamba x, depending on how low your gear ratio is you get a slightly lower initial start speed and less torque. I run my rigs at 80:1 to 100:1 and find that this initial startup speed is below speeds I drive out in the rocks. Although I thought I wanted it originally , I don't think I would notice if it all of the sudden it wasn't there. If I were to buy new electronics I would get a HH Trailmaster 550 21t and a hw 1080 with a 90:1 gear ratio. It is a very capable value. |
11-05-2018, 08:25 AM | #812 |
RCC Addict Join Date: Sep 2017 Location: The OC
Uh, you can definitely set throttle start on the 1080 - it's one of it's best features. That and the drag brake stepping. I just got mine running - with MambaX and TrailmasterProBL 3300kv on 3S. I got talked into this by the group, and while it's certainly fun it is absolutely just stupid-fast even geared down a bit to 11/64. It has already done a few front flips and cartwheels. LOL. Startup and slow speed is everything one could want for crawling. I tried it on 2S last night and going that way as top speed is more manageable and start up is even better. Reverse set to 25% - just fine for crawl work. On 3S the motor gets quite hot - too hot to hold a finger - I don't have a temp gauge, but set the esc to shut down at 170. On 2S it doesn't even get warm. IMO a brushless system is the way to go for a bomber unless you'll ONLY crawl it. It is so much fun with some speed and I think you're missing out on half of what it can do if you put brushed power in it, even worse on 2s. JMHO - oh well. |
11-05-2018, 11:13 PM | #813 |
So before i solder ..... The pic is the HH motor, with fingers pointing on the positive side of the motor(both tabs) and the arrows are on the negative side of the motor. Am i correct, i don't want to solder the wrong tabs(i hope that's what they are called) and mess up the motor? .......lf pic doesn't pop up, its in the Google photo link..... https://photos.app.goo.gl/ob8YqxkjrjbAXMLWA : |
11-05-2018, 11:32 PM | #814 |
I don't think it matters on a brushed motor since you can swap the wires when you plug it to the ESC anyway. Sent from my Pixel 2 XL using Tapatalk |
11-05-2018, 11:36 PM | #815 |
| Re: Have tech questions? Will answer. Quote: I went from full throttle bashing to crawling and trailing in between without ever overheating the motor or ESC. It get a little warm when I got full throttle for almost a full pack in the summer sun... Maybe you have a bad motor mesh? Sent from my Pixel 2 XL using Tapatalk |
11-06-2018, 01:54 AM | #816 | |
On a brushed motor having reverse polarity wires (reversing positive and negative) just makes it run backwards instead of forwards, it wont damage anything. | |
11-06-2018, 02:00 AM | #817 | |
11-06-2018, 05:49 AM | #818 |
I set mambax to shut down at 170* - it has not shut down. A little warmer than I like on full throttle runs but not overheating. On 2s it barely gets warm. If/when I go back to 3s power I'll gear down a little anyway. No problems. 3300kv brushless on 3s with 11/64 gearing is blistering fast. Still crawls great. For 3s I think I would get a 68T spur to start. |
11-06-2018, 08:53 AM | #819 |
Quarry Creeper Join Date: Mar 2007 Location: winchester
I want creepy crawly throttle. I like slow speed technical crawling. I have a 6lb toyzuki V2 running overdrive to front axle. I picked up a new TEKIN FXR esc. I'm running a 3s battery and have the stock scx10:2 kit pinion and spur gear. I'm not sure what my crawl ratio is with the V2 chassis setup but id like to know. I've always ran tekin 45t pro motor but she is worn out and ill rebuild it to be a backup motor. What brushed motor should I go with for my setup and my driving style.
11-06-2018, 09:54 AM | #820 | |
If you liked how it ran why not put another 45T motor in it? Maybe I missed something... | |
Have tech questions? Will answer. - Similar Threads | ||||
suspension tech questions. | Gen3_Teg_88 | General Crawlers | 9 | 07-13-2018 08:29 AM |
axle tech questions | 808eng_rc | Multi Axle Rigs | 4 | 11-07-2013 02:08 PM |
(HH) Tech Questions and Customer support thread | JohnRobHolmes | Holmes Hobbies | 3483 | 02-05-2013 09:08 PM |
2 stupid newbie questions needs answer | Mysterious | Axial XR10 | 21 | 06-18-2012 09:22 AM |
? Who has the answer to thes questions ? | mik236 | Team Losi Comp Crawler | 12 | 05-23-2010 02:40 PM |
