11-21-2018, 10:45 AM | #901 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: Have tech questions? Will answer. |
11-21-2018, 11:50 AM | #902 | |||
Quarry Creeper Join Date: Jun 2018 Location: CRG
| Re: Have tech questions? Will answer. Quote:
I honestly don't have many complaints about the stock RTR powertrain regarding descending. I kinda prefer having to "ride the brake" on technical descents. Thanks for the input, ya'll! | |||
11-21-2018, 12:06 PM | #903 |
RCC Addict Join Date: Jun 2017 Location: Canada
I'm running a 550 trailmaster Sport 21T with a hobbywing 1080 on 3s. Gearing is 11/64 but I also have a 10T pinion I need to try. So far it's awesome for low speed control and torque. I think the top speed is decent for a crawler oriented bomber. If I ever want more speed, I would go brushless with a puller pro and a Mamba x. Sent from my Pixel 2 XL using Tapatalk |
11-21-2018, 12:40 PM | #904 | |
11-21-2018, 03:18 PM | #905 |
RCC Addict Join Date: Sep 2017 Location: The OC
MambaX is dabomb. The pc setup interface is great.
11-21-2018, 07:05 PM | #906 | |
Brushed performance is mostly only affected by pwm frequency and features imo. Higher pwm frequency are smoother and lower frequencies are louder and puncher. Castle esc's all are low pwm frequencies holmes hobbies and the hobbywing 1080s are adjustable pwm, the ble also has a dithered mode that's a hybrid and is really good. Last edited by Voodoobrew; 11-21-2018 at 07:22 PM. | |
11-22-2018, 07:45 AM | #907 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
Does anybody know if I can still use the Castle link with old outdated Vista machine? It's all I have with windows and don't really want to get a new laptop just for a Castle link.
11-22-2018, 09:22 AM | #908 | |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
Sent from my SM-G930V using Tapatalk | |
11-23-2018, 07:43 AM | #909 |
| Re: Have tech questions? Will answer. Works on my Win10 Surface. You could always borrow a laptop or even take your esc to a friend’s house. Vista?? Lol
11-23-2018, 09:51 AM | #910 |
The free windows 10 update, why did I listen to General Ackbars advice |
11-23-2018, 10:17 AM | #911 |
11-23-2018, 06:09 PM | #912 |
just need to confirm, wiring two 2S packs in parallel will double amp hour rating, but will C rating (amp output rating) also double?
11-23-2018, 10:58 PM | #913 | |
Don't know what c ratings are exactly. But it probably doubles. Everything doubles except voltage and sag. | |
11-24-2018, 12:12 AM | #914 | |
Sent from my SM-G960W using Tapatalk | |
11-24-2018, 03:28 AM | #915 |
If amps/Ah=c rating then the c-rating will stay the same. But you will have 2x Amps and 2x Ah.
11-24-2018, 05:23 AM | #916 |
Batteries in parallel is like getting a bigger pool, it's more total volume but the flow is the same If you put them in series, it's like getting a bigger pump, same volume with more flow. Sent from my Pixel 2 XL using Tapatalk |
11-24-2018, 06:49 AM | #917 | |
11-24-2018, 06:56 AM | #918 |
I don't think it doubles the amps I thought they would just become a bigger reserve but not more amps Sent from my Pixel 2 XL using Tapatalk |
11-24-2018, 09:02 AM | #919 |
In my mind if you double capacity (Ah), C rating should stay the same, because it is Amps / Ah, but since both amps and amp hours should double, the C rating should stay the same. Right? A 30c 2Ah battery can't put out as many amps as a 30c 4Ah battery, I think. Sent from my SM-G960W using Tapatalk |
11-24-2018, 09:12 AM | #920 | |
I could be wrong Sent from my Pixel 2 XL using Tapatalk | |
Have tech questions? Will answer. - Similar Threads | ||||
suspension tech questions. | Gen3_Teg_88 | General Crawlers | 9 | 07-13-2018 08:29 AM |
axle tech questions | 808eng_rc | Multi Axle Rigs | 4 | 11-07-2013 02:08 PM |
(HH) Tech Questions and Customer support thread | JohnRobHolmes | Holmes Hobbies | 3483 | 02-05-2013 09:08 PM |
2 stupid newbie questions needs answer | Mysterious | Axial XR10 | 21 | 06-18-2012 09:22 AM |
? Who has the answer to thes questions ? | mik236 | Team Losi Comp Crawler | 12 | 05-23-2010 02:40 PM |
